Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 06-14-2011, 06:01 PM   #1
FASTRNL
FASTRNL's Avatar
Drives: HyperBlue20162SS
Parting out my 3rd gen and have alot of stuff.
Mods please close
1987 IROC vin (8) tpi
Computer w/prom $85
MAF sensor $80
long tube headers $75
Short tube headers wraped $70
TPI Snorkel and rubber ext. $25
a/c delete pulley (serp) $15
Ford 9" rear end full direct bolt in with torque arm mount 35spline axels,
calipers, rotors (does not include center section...) $550
flowmaster muffler and 3" crome tips $100
700r4 600hp capable fresh rebuild only used 250 miles $600
TCI street fighter torque converter 300-3400 stall $275 (same usage as trans. 30 spline)
26x10.5 16 m/t et streets 50% life $75
Anything esle you might need just ask
All prices DO NOT include shipping...
Thanks, FASTRNL
FASTRNL is offline   Reply With Quote
Old 06-15-2011, 04:54 PM   #2
stayinit73
Drives: 1984 Z28
Are the headers for a S/B V8? If so do they allow clearance for spark plug wires?
stayinit73 is offline   Reply With Quote
Old 06-15-2011, 07:08 PM   #3
Supercamaro64
Right, right.
Supercamaro64's Avatar
Drives: 79 Z28, 86 Camaro, 94 Burb 4x4
if that flowmaster would fit the 2.8l v6, ill take it!!
"You wanna lay the fate of the world on the kids camaro? Thats cool."
"When reporters asked what it was, one official stated, 'It's a small, vicious animal that eats Mustangs.'"
The Creampuff Fleet-
Supercamaro64 is offline   Reply With Quote
Old 06-15-2011, 10:16 PM   #4
FASTRNL
FASTRNL's Avatar
I had these on my 5.7 tpi. So yes they should fit I do remember the shorty's being close.
Old 06-15-2011, 10:19 PM   #5
FASTRNL
FASTRNL's Avatar
With slight modification it will fit just fine. The inlet is larger on the v8 so you will need your pipe bumped up to fit which any exhaust shop should be able to do.
Old 06-16-2011, 10:32 AM   #6
Supercamaro64
Right, right.
ok, i will check how much it would cost for them to do that. i usually do all my own work and dont have much spare $, but i can probably swing it ill get back to you later!
Just to be sure- it does sound good right? loud but not TOO loud, nothing wrong with the muffler or pipes, etc?
Old 06-16-2011, 11:16 AM   #7
FASTRNL
FASTRNL's Avatar
Yep sounds real good not crazy loud and is in very good shape.
Old 06-16-2011, 04:56 PM   #8
Supercamaro64
Right, right.
sounds good, so how do u want to do this?
Old 06-17-2011, 10:24 AM   #9
FASTRNL
FASTRNL's Avatar
PM sent
Old 06-17-2011, 07:09 PM   #10
4g63t
Drives: 1990 rs 3.1 v6
will your fuel pump work in a 1990 rs camaro 3.1 v6
4g63t is offline   Reply With Quote
Old 06-17-2011, 08:30 PM   #11
FASTRNL
FASTRNL's Avatar
I have a walbro 255 in it. It should work but I would look into it first.
The may have a different fuel pressure requirement.
Old 06-17-2011, 09:42 PM   #12
4g63t
either way the 255 has more pressure then the stock, and with the 255 im going to be pumpin more gas for nothing unless i decide to turbo/supercharge it witch im not planning on doing
but do you have the stock
Old 06-20-2011, 07:04 PM   #13
FASTRNL
FASTRNL's Avatar
Unfortunately I do not sorry.
Old 07-03-2011, 10:17 AM   #14
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
Do you have a head liner?
chevy 3 is offline   Reply With Quote
