Old 07-08-2011, 04:47 PM   #1
Juan C
Drives: 2011 Camaro 2SS Convertible
After Market Exhaust Does Not Fit!!!
I just installed the cherry bomb cat back exhaust on my 2011 Camaro SS Convertible but the supporting braces did not fit are they necessary & please help I don't know what to do
Juan C is offline   Reply With Quote
Old 07-09-2011, 12:06 AM   #2
Drago77
Treasure Coast Camaro 5
Drago77's Avatar
Drives: 19 2SS vert, Mosaic Blk, A10
I addressed this issue here:
http://www.camaro5.com/forums/showthread.php?t=131860
When I first got my vert in Feb. Some do, some don't. Some have come up with vert-modded systems (Magnaflow cat back, Flowmaster-axel back only.) I believe Corsa, Borlas and SLP Cat backs also all fit. Stainless Works makes a 3" w a special adapter kit and Solo Performance has 2 systems about to release.
If the pipes fit but the braces wont, look into the stainless works convertible brace package, that may be the best route if you really are set on that particular system. Perhaps a few washers from home depot if the gap isn't too drastic.
Flowmaster took my system back with a 100% refund, as long as I provided photos of the obstructions. They were great about it.
Good luck, took me almost 6 months to decide on an exhaust, a lot of great ones out there, but still few specifically for the verts.
Drago77 is offline   Reply With Quote
Old 07-09-2011, 03:32 AM   #3
phdjent
Evan "FRESHAYR"
phdjent's Avatar
Drives: 2014 Stingray Z51, 2014 Jeep SRT
Yeah Drago77's got the right info. I had a Borla that fit. Now I've got the American Racing Catback. Return it and get one that we know fits. By the way, my Borla S Type is still for sale if you're interested.
phdjent is offline   Reply With Quote
Old 07-09-2011, 07:49 AM   #4
rjtssvert
rjtssvert's Avatar
Drives: 2011 2ss rs convertible
I'm not sure if this will help your situation but I have a magnaflow system on mine that would hit the braces going over bumps, so I just spaced them down with washers and am having no problems at all now.
rjtssvert is offline   Reply With Quote
Old 07-09-2011, 08:06 AM   #5
Drago77
Drago77's Avatar
Yours hits? I've got the Magnaflow Competition Cat-Back- I have about 1" + of clearance from all braces!
Just a tip for anyone doing a home install; loosely secure the bolts until the entire system is in place, then use a jack to "raise" the system up, close as possible to the undercarriage while you then completely tighten all the bolts.
Not claiming it'll cure all the clearance problems, but it'll help give that little extra that causes the occasional rubbing
Old 07-09-2011, 09:59 AM   #6
rjtssvert
rjtssvert's Avatar
Mine has the same amount of clearance but was still cluncking over hard bumps and dips. I have the street series on now but I also have a comp series still in the box I'm debating to put on.
Old 07-09-2011, 10:05 AM   #7
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
Originally Posted by Finsfan View Post
Call the company you bought them from. Similar issues when the 2010 came out with different aftermarket parts.They should make good on it.If not return them and post who they are so someone else doesn't have the same issue.
+1
Old 07-09-2011, 05:20 PM   #8
Drago77
Drago77's Avatar
I've never heard the street series, but I love my comp! About to throw headers on too... a friend had headers and cam- sounds sick!
Old 07-09-2011, 07:02 PM   #9
MARTYBMW
MARTYBMW's Avatar
Drives: 2011 2LT/RS RJT Convertible
RJTSSVert:
I need to do the same thing with my magnaflows, do you happen to know the washer size? How many did you have to add? And finally was it difficult?
Born On 04/01/11
MARTYBMW is offline   Reply With Quote
Old 07-09-2011, 11:53 PM   #10
rjtssvert
rjtssvert's Avatar
Originally Posted by MARTYBMW View Post
RJTSSVert:
3/4 size washers, it wasn't difficult I jacked up the back of the car to make it a little easier. Under the front brace I used 6 washers and under the smaller one in back of it I used 4. The bolts are plenty long enough.
Old 07-10-2011, 12:46 AM   #11
MarylandSpeed
Drives: 2012 ZL1 & 2010 2SS/RS
Pretty much all 3" systems, and any systems with huge boxy mufflers do not fit the convertible.
MarylandSpeed is offline   Reply With Quote
Old 07-10-2011, 08:49 PM   #12
MARTYBMW
MARTYBMW's Avatar
Thanks for the info... I find it easier to get info from completed projects rather than try to reinvent the wheel.
Born On 04/01/11
Old 07-17-2011, 03:56 PM   #13
2011SSvert
Drives: 2011 SS Convertible
Does aftermarket exhaust void my warranty? Sorry, I'm no motorhead I just finally bought the car I'vd wanted since '69.
2011SSvert is offline   Reply With Quote
Old 07-17-2011, 05:17 PM   #14
Drago77
Drago77's Avatar
No.
However if you mess with the tune also, then yes. Only the portion potentially linked to that mod.
V8 Camaro Aftermarket Exhaust Video Clips Compilation tjbusa Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 591 07-06-2022 08:38 AM
Annoying Vibration with After Market Exhaust cshaw2049 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 33 09-12-2010 03:14 AM
After market exhaust benefits? JSC81 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 05-09-2010 06:08 PM
EXHAUST Milk 1027 Wiki 2 03-07-2010 09:20 PM
