Old 07-10-2011, 11:49 AM   #1
tcwells
tcwells's Avatar
Drives: 2010 2LT Camaro
MRT 1.0 Exhaust Installation
I was wondering which way I should get my MRT 1.0 exhaust installed. Should it be with the clamping or welding? Not really sure the difference between each but would assume that the welding would cost a bit more.
Thanks
tcwells is offline   Reply With Quote
Old 07-10-2011, 12:17 PM   #2
BigJake707
Resident Cynic
BigJake707's Avatar
Drives: "Shakira" 2010 Camaro 1LT V6
Depends on your local shops...My usual exhaust guy's shop charges time and a half for pre-designed kit installation. Run down to your local shop and get some estimates for welded installation as opposed to doing it yourself at home.
Current Mods- Injen CAI, Trifecta tune, Doug Thorley shorties, MRT v1 w/ res delete, 20" Boss 338's (Grey), SS Bumper, Heritage Grill, Pfadt Racing Lowering Springs
Upcoming Mods- MPD1 Spoiler
Planned Cosmetic Mods- Modern Yenko Stripes, Window Tint
BigJake707 is offline   Reply With Quote
Old 07-10-2011, 12:23 PM   #3
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
I just clamped it on myself... didn't want to get it welded until I knew I'd be happy. I'm thinking about getting some DT shorties and having them both welded at the same time.
Sterling is offline   Reply With Quote
Old 07-10-2011, 12:52 PM   #4
tcwells
tcwells's Avatar
I'll probably go with the clamping then.. I think I read somewhere that with it being clamped the pipes or something with the exhaust can shift? I may be wrong but just checking.
Old 07-10-2011, 04:19 PM   #5
BenningJ
BenningJ's Avatar
Drives: 2013 AGM 1SS/RS LS3
Yes if you do clamp them and do NOT clamp them tight enough then they can shift a bit. Usually it is the passenger side that shifts. However, if you have them sticking out passed the diffuser about 3/8" to 7/16" and tighten the clamps as much as possible (it is a good idea to have someone help you at this point; they hold the tips center in the opening while you wrench away) then you will not have any problems. You can refer to my threads about installation and spacing distances. I have them re-situated and clamped tight now and they have not moved since. If you do decide to weld them I would not pay more than $100.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts
BenningJ is offline   Reply With Quote
Old 07-10-2011, 05:21 PM   #6
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Welded. IMHO. Never have to worry about them moving again. I don't plan to change them out so easy choice for me.
Old 07-10-2011, 05:32 PM   #7
tcwells
tcwells's Avatar
Thanks for the advice.. I'm considering to just go ahead and weld them on. Hopefully the place I decide to take it to isn't to expensive. I would be happy with around $80 but yes like you said benning 100 and over would be a little too much
Please help me choose.... sfgiantsfan9 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 25 11-22-2010 11:34 AM
For Sale: V6 MRT version 2 exhaust BRAND NEW chmccarty V6 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 7 11-06-2010 01:00 PM
Curious about the new v6 / exhaust diameter sizes WCFB-Russ Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 16 10-28-2010 09:14 PM
MRT 1.0, 2.0 or Solo...that is the question TJ91 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 21 04-11-2010 04:06 PM
2LT exhaust options Guardian1816 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 3 01-12-2010 10:28 PM
