Old 07-12-2011, 08:56 PM   #1
txrracing2003
txrracing2003's Avatar
Drives: 2001 Camaro
water boiling?
I have a 2001 carmaro. I drive it home from work and noticed the water was boiling. It seems to be losing pressure in the water system. I checked the heater core its fine. then I checked the oil to see if the head gasket was leaking. no water in the oil. someone told me that on the 3600 v6 motor that the intake manifold gasket is weak on that model and i was wondering if that could be it. or could it still be a head gasket. btw the compression in all my cylinders are fine. (if that helps)
Thanks
Mike
txrracing2003 is offline   Reply With Quote
boiling, heater core, water
What song are you listening to right now Muscle Master Off-topic Discussions 6760 11-08-2025 02:54 AM
Washing/Detailing for Newbies MRK III Z28 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 124 02-05-2024 10:55 PM
Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 TAG UR IT Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 58 12-01-2019 10:54 PM
Forced Induction Supplements radz28 Forced Induction - V8 3 11-04-2010 12:13 PM
Car Washing.................... Angelo@Autopia Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 5 03-08-2010 07:48 PM
