Old 07-16-2011, 01:43 AM   #1
6spdLs3
6spdLs3's Avatar
Drives: 2011 camaro ss
Exclamation Engine wire harness clip can damage wiring
Just solved a blinking reverse lamps problem that turned out to be caused by a metal clip that holds the engine wire harness. I guess problems could vary since it depends what wire the clip cuts into. On my car it happened to be the reverse lamp wires. I could see this clip being responsible for a number of different intermitent problems on 2010 - 11 LS3 camaros.
The clip is located on the passenger side front cylinder head. It is below the oil filler cap as seen in photo 1.
Photo 1 shows the offending clip
Photo 2 shows the metal 1/2 moon that can nick the wire harness
Photo 3 shows the damaged harness
Photo 4 shows the nicked wires
6spdLs3 is offline   Reply With Quote
Old 07-16-2011, 02:18 AM   #2
KnightRiderSS
Voodoo Medicine Man
KnightRiderSS's Avatar
Drives: Black 2SS with RS package
interesting...did you have any aftermarket parts installed to that stud that holds that clip? I recently had a problem there and will check my harness out to see if it is doing that.......
KnightRiderSS is offline   Reply With Quote
Old 07-16-2011, 08:54 AM   #3
6spdLs3
6spdLs3's Avatar
No mods at all, started doing it with less than 300 miles.
Old 07-19-2011, 02:07 PM   #4
caramaro1969
caramaro1969's Avatar
Drives: 69,82,84 & 10 camaros,87 GMC,07z06
thanks for the heads up,i just checked mine,it looks ok for now,but i can definitely see how this could be a problem in the future! i pushed mine away from the motor and wiggled the clamp a little
caramaro1969 is offline   Reply With Quote
Old 07-19-2011, 02:55 PM   #5
shiftz33
shiftz33's Avatar
Drives: 17 SS Sedan, 04 SSR
I checked this same wiring clip on my L99 and sure enough it was starting to cut into the outside wiring cover. It had not broken through just yet, but in another 2K miles or so, I would have a cut wire as well. I have just under 8K on my 2010 1SS L99 now.
I simply loosened the negative cable nut and then the nut holding the clamp under the negative cable. I rotated the wiring harness clamp and reshaped it a bit to be "round" again. Now it looks good. Before I tightened anything up, I also made sure the wiring harness clamp that goes down from that same mount point was positioned correctly around the wiring harness that it holds in place too.
Thanks for the heads up on this one!
shiftz33 is offline   Reply With Quote
Old 07-19-2011, 03:47 PM   #6
Nessal
Drives: Exige, Miata, Ghia
I could have sworn that there was a bulletin for this.
Nessal is offline   Reply With Quote
Old 07-19-2011, 04:57 PM   #7
shiftz33
shiftz33's Avatar
There is a TSB for a problem in this same general area, but it's the hose clamp located just below this wiring harness that might have the edges of the hose clamp digging into the wiring harness. If the hose clamp is not touching the harness no action was to be taken by the service tech.
HVAC Reprogram, Engine Harness Position Inspection, Rear Spoiler Fasteners.pdf
Old 07-19-2011, 06:04 PM   #8
6spdLs3
6spdLs3's Avatar
If you look inside the mounting clip, there's a 1/2 moon piece of metal that needs to be flattened. No clue why they would have designed the clip that way.
The clip shown in the TSB Photo is not the one that gave me a problem. It's the clip behind it, visible from the passenger side, in-line with the oil filler cap.
Instructions for Wiring AAC Halos The Stig Camaro DIY & HOW-TO instructions & discussions 9 04-01-2013 03:59 AM
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ AutoAgenda Exterior Parts & Accessories 14 02-06-2013 09:43 PM
New Texas Speed & Performance Engine Machining Center! Trevor @ Texas Speed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 01-16-2013 04:46 PM
Roto-Fab | Cold Air Intakes | Engine Covers | Washer Reservoir Relocation Kit | Fuse+ AutoAgenda V8 Bolt-Ons & Tunes 7 07-11-2011 07:50 PM
