Hey all
I have a 2010 LT/rs with the interior trim package and I noticed something the other day. The dash piece closest to the driver's door appears to be loose, if I press on it, the top corner will flex back as if it isn't secured. It doesn't do this on the passengers side, so I am guessing that it isn't normal. Can anyone tell me what I can do to fix this?
knows 2 facts about ducks
I would just pull it off and check that all the tabs are in place. It's really easy to get off, just pull a bit; and don't worry you won't break it.
Which way should I pull? Up, down, or to the side?
Switchin' n Twitchin'
Drives: 2011 Camaro Join Date: Nov 2010
Pull straight out... towards you
I am not childish, you're just being a poopy head!
| Tags |
| interior panels |
| Loose 02 sensor on long tubes | Agent WD-40 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 8 | 11-15-2010 09:45 PM |
| Rear Spolier Loose | Bob | Suspension / Chassis / Brakes | 13 | 05-11-2010 12:25 PM |
| Distributor loose? | 1_2Many | General Automotive + Other Cars Discussion | 5 | 12-12-2008 05:32 PM |
