Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 08-01-2011, 05:44 AM   #1
BARRYJAPAN
Drives: 85 CAMARO BERLINETTA
85 BERLINETTA
I just got an 85, and it doesn't want to stay idling, also, when I changed the plugs, the 2 front ones had oil on them, but not any others. Any ideas would be greatly appreciated.
BARRYJAPAN is offline   Reply With Quote
Old 08-01-2011, 09:17 AM   #2
Nvincent4708
Drives: N/A
If it was sitting for a while it's likely oil seeped down the valve guide seals..that could cause oil to get in the cylinders on the plugs.
Which engine is in it?
I know the 2.8's were good for clogging the fuel filters after sitting and that would cause it to not idle.
How long was the car sitting?
Nvincent4708 is offline   Reply With Quote
Old 08-01-2011, 11:55 AM   #3
BARRYJAPAN
The gent I got it from said it had been sitting for about 2 months, prior to that it was his daily driver. He has owned it for 15 yrs. It is a 2.8.
Old 08-01-2011, 01:21 PM   #4
Nvincent4708
Drives: N/A
2.8.. there should be a filter in the back of the carb where the fuel line screws in.. bet it needs replaced
Old 08-01-2011, 01:33 PM   #5
BARRYJAPAN
Ok i found the filter right underneath the rear passenger seat, i will go and buy a new filter later today and hope that fix's the problem. thank you very much for your help. I will post whether it works or not. Fingers crossed.
Old 08-01-2011, 01:45 PM   #6
Nvincent4708
Drives: N/A
filter under the seat?
maybe it changed from 82 to 85. I remember back of carburetor.
Old 08-01-2011, 03:13 PM   #7
BARRYJAPAN
Mine is FI, well just put a new filter on it and it was idling for about 8 mins before it shut off, which is 7.9 mins longer then what it was doing. it is still running a little rough but it does need an oil change and it is probably still running on the old fuel that was left in the tank. Thank you ever so much for helping me, because a lot of other people said that it was the idle air control valve and the MAF, and a bunch of other parts that cost a lot so u just saved me a lot of money thank you again
Old 08-01-2011, 11:46 PM   #8
Supercamaro64
Right, right.
Supercamaro64's Avatar
Drives: 79 Z28, 86 Camaro, 94 Burb 4x4
i have an 86 berli with the 2.8. i have had extremely few problems with this car, especially considering i got it for really cheap. treat them right, and these little engines wont let you down! new oil/oil filter/gas can go a long way!! good luck with the car!!
"You wanna lay the fate of the world on the kids camaro? Thats cool."
"When reporters asked what it was, one official stated, 'It's a small, vicious animal that eats Mustangs.'"
The Creampuff Fleet-
Supercamaro64 is offline   Reply With Quote
Old 08-02-2011, 07:21 AM   #9
Nvincent4708
Drives: N/A
Try to drain the tank and put fresh fuel. Then see if it'll start and idle. If not, check the fuel pressure if you access to a gauge. I'm sure it is something fairly simple.
Berlinetta Control Pods Supercamaro64 3rd Generation Camaros 32 02-23-2015 09:42 PM
FOR SALE - 1984 BERLINETTA B2k4E 3rd Gen Marketplace 3 07-31-2011 12:49 AM
Got A Berlinetta Digital Dash F/S Motorhead79 3rd Gen Marketplace 14 02-24-2011 01:03 AM
79' BERLINETTA Camarino 1st & 2nd Generation Camaros 34 04-19-2009 11:10 PM
1986 Berlinetta. Help? Supercamaro64 3rd Generation Camaros 4 02-13-2009 01:00 PM
