Old 08-01-2011, 09:30 PM   #1
GoBlue20
GoBlue20's Avatar
Drives: 2011 Inferno Orange 2SS/RS A6
L99 Passing Gear Issue?
I apologize if this is listed somewhere but I couldn't find it. It seems like my SS has been "falling on it's face" lately. It feels like its not downshifting enough when it drops into passing gear. For example, if I floor the car at any speed other than 15 mph... it's only jumping up to 3000-3800 rpm. This seems really low to me. At 15 mph, it hops up to 4500 rpm. At 20 mph though... 3000 rpm. Is this normal? I've done the fuse pull and am running 91 in it. It has been 100+ outside, but in the morning when its cooler I'm still having the same issue. Its 100% stock. Any advice?
GoBlue20 is offline   Reply With Quote
Old 08-01-2011, 10:28 PM   #2
nitto85
Caffeine Injected
Drives: 13 Ram - 05 Widebody 1050rwhp Vette
are you driving in D or S mode?
nitto85 is offline   Reply With Quote
Old 08-01-2011, 10:44 PM   #3
GoBlue20
GoBlue20's Avatar
Typically in D... but I have tested both and it doesn't matter what mode I'm in... I always get the same result
Old 08-01-2011, 11:13 PM   #4
nitto85
Caffeine Injected
I've never drove in D much, but I remember my stock SS never really did that.
Did you buy your camaro new or used?
Old 08-01-2011, 11:16 PM   #5
GoBlue20
GoBlue20's Avatar
I got it new. It has 3100 miles on it.
Old 08-01-2011, 11:18 PM   #6
nitto85
Caffeine Injected
If used I thought maybe someone messed up a transmission tune.
Hmm, sounds like you need to take it to the dealership. They'll probably want to drive it and see if it does it for them.
The key thing is, it has to do it for them in order for them to work on the car under warranty.
Old 08-01-2011, 11:19 PM   #7
sasquash1984
502 RWHP N/A
sasquash1984's Avatar
Drives: The yeti
tune is the answer stops that hesitation when letting off gas
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
sasquash1984 is offline   Reply With Quote
Old 08-01-2011, 11:21 PM   #8
GoBlue20
GoBlue20's Avatar
Its like clockwork.. I might have to do that
Old 08-01-2011, 11:24 PM   #9
GoBlue20
GoBlue20's Avatar
I thought a tune may help. It not a hesitation thats the issue though... the car is falling on its face and not downshifting enough IMO. If your L99's didn't downshift and rev up to only 3000-3800ish rpm then that tells me theres an issue. If I keept it floored it will really start to go once it hits 4500 rpm but should be a lot closer to that rpm when it 1st downshifts IMO...
Old 08-01-2011, 11:30 PM   #10
nitto85
Caffeine Injected
Edit, nevermind, re-read your first post, your putting premium.
Old 08-01-2011, 11:35 PM   #11
GoBlue20
GoBlue20's Avatar
Yes.. 91 is premium here. I go out of my way to get to the gas station that sells it because most of them run 90. Shell, however, has 91.
Old 08-02-2011, 08:52 AM   #12
n116ebo
n116
n116ebo's Avatar
Drives: 2010 2SS YELLOW TRANSFORMER AUTO
I have the SS auto also but do not punch mine enough to help you on your question. I do feel for you on the 90-91 octane. In my home town nearly all stations are posting 91. I know of one fina that has 92 posted, but I also know they are mixing ethanol. I keep thinking tune, but loss of warranty and if you can only find 91 octane. Like they said may have to take to dealer. I have had my 2010 for 16 months and knocking on wood have not had to let the dealership touch mine. Hope you find the answer. Happy motoring.
n116ebo is offline   Reply With Quote
Old 08-02-2011, 09:57 AM   #13
Patrick G
Drives: 2009 Pontiac G8 GT
If your TCM has been tuned, your tuner may have not altered the part throttle downshift tables. This is where you will see the downshifts to 1st gear up to 30mph.
2013 Corvette Grand Sport A6 Forged 416, Greg Good ported TFS 255 LS3 heads, ECS NOVI 1500 blower, 222/242 .629/.604 121LSA EPS cam, ARH 1 7/8" headers, NPP exhaust, 747rwhp/709rwtq on 93 octane, no meth, w/stock street manners.
2014 GMC Yukon XL Denali, Air Raid MIT, tuned.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph Texas Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 Texas Mile
LS1,LS2,LS3,LS7 Custom Camshaft Specialist
Patrick G is offline   Reply With Quote
Old 08-02-2011, 10:07 AM   #14
ABM/IOM
Drives: aqua blue ls and inferno orange ss
I know i saw an article on an independent gasoline study on this site about how many gas stations posting 91 octane were only testing at about 89-90. Check the general discussion topics on here.
If you are putting in 91, you may only really be burning 89 or 90 octane and in that case your ss will run like shit. I live in Florida where we can get 93 on every corner. Superchips has a handheld tuner that has a tune in it for 91 or 93 octane. That's what i use in mine. The transmission tune alone is worth the cash. It will fix that downshifting problem.
ABM/IOM is offline   Reply With Quote
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 92 06-02-2021 05:17 AM
the notchy 3rd gear issue KKJ V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 23 05-03-2011 04:26 PM
L99 sounds like it is in to high of gear, then BAM it take off like a bat out of HEll speed racer Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 03-12-2010 02:55 AM
Clarification Please! L99 and 1st gear Ace 5th Gen Camaro SS LS LT General Discussions 6 05-22-2009 04:34 AM
Do you think it was right that the mustang got to use the trackpack in the comparison perfxn Chevy Camaro vs... 91 03-30-2009 10:44 PM
