Old 11-20-2010, 04:14 PM   #1
KKJ
KKJ's Avatar
Drives: 2011 Camaro 2SS/RS
the notchy 3rd gear issue
I know a lot of people are complaining about notchy shifting in their tremec t6060's. (vettes, mustangs, and dodge's too) I have the same issue with my 2011 ss. It has done this since the day I brought it home. I drained my stock fluid and replaced it with mobil 1 synthetic atf. I can't say that it is any better or worse. It feels the same to me. I have been reserching this for a while, and it seems like the t56's also had this problem. I just wanted to bring up the point that I installed a richmond 6 speed in my 69 nova and it was notchy going into 3rd gear also. I dialed in the bell housing well within spec, so everything should have been installed 100% correctly. Do you think this is just a "6 speed thing?"
KKJ is offline   Reply With Quote
Old 01-05-2011, 10:15 AM   #2
USMCss
USMCss's Avatar
Drives: 2010 Camaro SS/RS RJT
I also grind from 2-3 30% of the time even after changing to Mobil 1 syn ATF. It does it when it's cold and up to full op temp but between its smooth as butter. Also, I can tell when it is and is not going to grind when I'm leaving 2nd because it will grind slightly leaving 2nd before going into 3rd. If it's smooth leaving 2nd, smooth into 3rd.
2010 Camaro SS/RS RJT LS3, Black/Beige interior, MGW shifter, Muffler Delete, JBA High Flow Cats, CAI inc. intake, Diablo tune, Hotchkis lowering springs, 35% tint
USMCss is offline   Reply With Quote
Old 01-05-2011, 04:34 PM   #3
ss=scuba steve
ss=scuba steve's Avatar
Drives: 2011 1SS Cyber Gray Metallic
Mine is also notchy going into 3rd. The weird thing is it doesn't do it ALL the time, sometimes it goes in smooth but most often it feels like theres a little knuckle in there about 1//2 way into third. I would love to see if anyone knows why this happens....
ss=scuba steve is offline   Reply With Quote
Old 01-05-2011, 09:11 PM   #4
Alain
Alain's Avatar
Drives: 2016 Challenger Hellcat, 2018 ZL1LE
the mystery continues !!!
Alain is offline   Reply With Quote
Old 02-27-2011, 06:15 PM   #5
USMCss
USMCss's Avatar
Just put amsoil torque drive in yesterday and all the problems are gone I really can't believe it, shifts like butter at any temp/rpm. I posted this in a couple other threads too to let everyone know what worked for me, just seemed like no one was trying the torque drive, just Mobil and Royalpurple. I had a rough feel/engagment in my clutch too and that's even gone. I picked it up for 37bucks plus tax from a local amsoil dealer. Hope the fix isn't short lived.
Old 03-01-2011, 04:18 PM   #6
ssmike
BL1ZZRD
ssmike's Avatar
Update! I actually had a chance with a break in the weather to really give the new transmission a good shaking out! I must say I'm pleased so far! 2nd gear is smooth as silk and 3rd, although notchy when cold, seems to be acceptable after up to temp, not perfect though! I'm hoping it will only get better as I break it in and the weather warms up! Thank you GM for stepping up and replacing my trans!
Old 03-01-2011, 04:42 PM   #7
SleepWarz
Banned
Drives: 1991 New Yorker, 69 Tbird, ABM2SSRS
Mine did this from the start. Replaced fluid with RP tranny fluid. Still does it, however when the fluid warms up the notch is gone.
SleepWarz is offline   Reply With Quote
Old 03-04-2011, 06:49 PM   #8
mtbikerinme83
mtbikerinme83's Avatar
Drives: 2010 2SS/RS LS3-M6
Mine grinds bad most of the time but 3 Chevy dealers later they all say that they dont find anything wrong. The notchy shifting with griding is the only thing that I hate about my car. It's so bad that it makes me think about getting rid of the car because it takes the fun out of driving it when you're grinding gears all the time. Just drove a friends Mazda Speed 3 and it has a super short throw, no notchiness, and is supper supper smooth shifting. I could throw that thing in any gear I wanted at any time without thought or effort, wish I could say the same about my car. It's agrivating that Mazda can have a great shifting 6speed but GM cant.
Sorry, rant over
Currently:
2010 CGM 2SS/RS GFX LS3-M6, 3.91 1LE diff, Kooks LTH w/ cats, Borla Touring axel back, CAI intake with race scoop, and custom dyno tune
Previously:
2010 IBM 2SS LS3-M6
CAI intake with JRE race scoop, VMax TB, Solo HF Catted Mid pipes, and JRE SCT tune
mtbikerinme83 is offline   Reply With Quote
Old 03-04-2011, 09:26 PM   #9
njdad61
njdad61's Avatar
Drives: 2020 Satin Steel 2SS Coupe
Sorry, rant over
Does yours grind more when it's cold? Mine is really bad and grinds 100% of the time when cold, but intermittent when warm. I'm supposed to see the dealer for the second time Monday morning just to confirm the problem and let the service manager see it. I'm driving that sucker up there Sunday night, leaving it, and meeting them as soon as they open to be sure the car is cold enough that the problem will be present on the test drive. Also helps to call the hotline and talk to a GM Service Rep. They'll get you a service number and follow up with you and the dealership to make sure everything's straight. I definitely would have gotten the cold shoulder if I didn't do that first.
  • TPW 8/5/19
  • Built 8/2/19
  • Arrived 8/13/19
  • Home 8/16/19
njdad61 is offline   Reply With Quote
Old 03-05-2011, 10:25 AM   #10
mtbikerinme83
It is worse when cold so every time I dropped it off the night before so it would be cold in the morning for them. I guess the next step is call GM.
Currently:
Previously:
2010 IBM 2SS LS3-M6
Old 03-08-2011, 02:19 AM   #11
Blk_SS
Drives: black on black 2SS/RS
i have the same problem with my 3rd gear and it only sometime that it does it, i drop it off to chevy and they said they cant find a problem with my tranny..... im puzzle..... maybe i should give the amsoil a try out and see how it work
Blk_SS is offline   Reply With Quote
Old 03-08-2011, 07:30 AM   #12
ssmike
BL1ZZRD
ssmike's Avatar
If you use the Amsoil fluid please let us all know if it helps!
Old 03-08-2011, 04:05 PM   #13
booenson
Drives: 2010 1SS/RS M6
I made a thread about this earlier:
http://www.camaro5.com/forums/showthread.php?t=97186
From my experience, I took it to the dealer and had them check it while it was in for stripes, and said it was operating as designed, but the car wasn't fully broken in yet and to give it a few more miles, and if it still did it then to bring it in.
booenson is offline   Reply With Quote
Old 03-12-2011, 01:05 AM   #14
piticu667
Drives: 2010 Camaro
Good luck to all those that have an M6
piticu667 is offline   Reply With Quote
V6 AY6 M6 2nd Gear Problem - Report Your Issue Here CAMAR0 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1606 10-25-2012 03:18 PM
2011 Mustang Info (Keep all threads here) RealQuickCamaro General Automotive + Other Cars Discussion 2648 04-15-2010 08:09 PM
3rd gear release... HzMajesty V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 4 03-10-2010 03:42 AM
Clarification Please! L99 and 1st gear Ace 5th Gen Camaro SS LS LT General Discussions 6 05-22-2009 03:34 AM
Do you think it was right that the mustang got to use the trackpack in the comparison perfxn Chevy Camaro vs... 91 03-30-2009 09:44 PM
