Old 08-05-2011, 08:28 AM   #1
Ruhlman Race Cars
Ruhlman Race Cars's Avatar
Drives: 2011 2SSRS 6spd Synergy Green
Will dyno tune eliminate low octane fuel table issue?
Will getting a dyno tune eliminate the issue with the low octane fuel table issue where the fuse pull procedure is necessary? I'm scheduled for a dyno tune next wednesday and I wanted to make sure what is and is not done during the tune.
Any info/ experiences would be appreciated.
2011 Synergy Green 2SSRS LS3 with Kooks coated step headers, Kooks high flow cats, Corsa cat back, Vararam, Sprint throttle booster, Retro shifter, skip shift eliminator, Retro SS badges.
Ruhlman Race Cars is offline   Reply With Quote
Old 08-05-2011, 09:26 AM   #2
Synner
Drives: cars
It can be fixed if the tuner actually does it.
Old 08-05-2011, 09:57 AM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Do any of the tuners actually tune out the low octane table? IMO, they shouldn't. It's a fail safe mechanism incase you get bad gas or have to use lower octane, for whatever reason. There's not an issue with the lower octane table, just that some early cars had a tendency to stay in that table once there or were there from the factory. The latter was the case most of the time and the fuse pull was a way to force it back into the high octane table.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 08-05-2011, 11:01 AM   #4
CamaroFemme
CamaroFemme's Avatar
Drives: 2010 Black Camaro 2SS/RS
How? What would I need to ask my future tuner to do to make this happen?
I would think Axis is right - there's ALWAYS the possibility of lower-quality gas somehow getting into your car, and the lower table is the failsafe on that.
My boyfriend don't mind it.
CamaroFemme is offline   Reply With Quote
Old 08-05-2011, 11:03 AM   #5
The Stig
knows 2 facts about ducks
The Stig's Avatar
Exactly. Tuning out the low octane table is the same concept as taking the net out from underneath a tight-rope walker. You may know what you're doing, but what if some punk kid yells "don't fall" while you're up there? Similarly, if someone thinks they are doing you a favor and ends up topping your car off with 87. If you tuned out the low octane tables, well; congratulations because you just won the need to purchase a new motor (possible/worst case).
Click to view my build thread
Old 08-05-2011, 11:13 AM   #6
Patrick G
Drives: 2009 Pontiac G8 GT
I don't think it's a good idea to make the low octane table the same as the high octane table for a street driven car running pump gas. Smart tuners will modify the octane scaler so the ECM will not be as aggressive in dropping timing down to the low octane table. The real key though, is tuning the high octane table well enough so you don't have excessive spark knock (which drops you down to the low octane table).
2013 Corvette Grand Sport A6 Forged 416, Greg Good ported TFS 255 LS3 heads, ECS NOVI 1500 blower, 222/242 .629/.604 121LSA EPS cam, ARH 1 7/8" headers, NPP exhaust, 747rwhp/709rwtq on 93 octane, no meth, w/stock street manners.
2014 GMC Yukon XL Denali, Air Raid MIT, tuned.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph Texas Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 Texas Mile
LS1,LS2,LS3,LS7 Custom Camshaft Specialist
Patrick G is offline   Reply With Quote
Old 08-05-2011, 11:14 AM   #7
NoUCantDriveIt
Drives: 2SS RS M6 CGM/Black Rally
I haven't found when this was resolved, either by after VIN# or production date. Lots of info on the subject, just nothing about a fuse pull no longer being needed to reset the table. Does anyone know?
NoUCantDriveIt is offline   Reply With Quote
Old 08-05-2011, 11:17 AM   #8
CamaroFemme
As far as I know it was never resolved. Keep at least 91 in it and it won't be an issue.
Old 08-05-2011, 11:21 AM   #9
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
Yes, make sure you tell your tuner that is your expectation.
Leaving the Low Octane table alone is not wise because it will need tuning too with significant mods. Setting it equal to the tuned High Octane table is the easiest solution. You just need to be careful about gas and make sure not all the Knock Retard is tuned out.
I imagine you could do a differential on the High and Low tables (stock) and apply it to the tuned High table for the new Low table. (If that's not convoluted anough. )
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 08-05-2011, 11:48 AM   #10
east TX Muscle cars
east TX Muscle cars's Avatar
Drives: 2x 05 Vettes/65'AC cobra/68 camaro
the low act table is there so if the computer sees a TON of knock or a few other issue it goes to that table to save your motor, it is NOT good to have that table up high. usually when we tune a car that table is 6-8* LESS that the high oct table
east TX Muscle cars is offline   Reply With Quote
Old 08-06-2011, 02:46 AM   #11
thebrainhart
thebrainhart's Avatar
Drives: '10 Camaro 2SS/RS CGM LS3 A6
Yeah, as annoying as it is sometimes, its best to not tune it out, for safety reasons.
A lot of tuners will turn off a lot of things and codes such as catalytic converter efficiency codes, lean/rich codes, O2 sensor codes, etc, instead of changing the testing parameters to be compatible with the long tubes and other mods. Leaving them active causes a pain tuning at times, only because their tune job isn't good enough to work with them. When they turn them off, the computer doesn't run the tests to determine if the engine is running safely or not, either for the engine, or for other components, such as catalytic converters.
There was a big stink a little while ago about cats going bad with long tubes. If they had tunes which enabled proper testing, the computer would have set the SES light, indicating the tune sucked, and is ruining the cats.
Most of the stuff in the factory tune is a pain, but is there for a very good reason.
- 2010 Camaro 2SS/RS CGM LS3 A6 "Lurch" - FLYNGSS -
Some ProCharger, Alky, CompCams, Brian Tooley, Holley, Livernois, K&N, Ridetech, DSS, Kooks, JDP Motorsports, Pfadt, BMR, Prothane, Weld, M&H, Mickey Thompson, RKSport, Elite, Garys, Defenderworx, Anvil, etc.
thebrainhart is offline   Reply With Quote
Anybody Spray'n their SS yet - nitrous ? WeeZee Forced Induction - V8 37 12-29-2012 10:56 PM
E85 TUNE RESULT!! bmorecam Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 327 10-13-2011 07:22 PM
Nitrous System ?????s PoleCat2SSRS2010 Forced Induction - V8 29 12-08-2010 06:55 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
