Old 08-11-2011, 07:01 AM   #1
Bill 1ss/rs m6
Bill 1ss/rs m6's Avatar
Drives: 2015 1SS/RS M6
3M clear bra care?
About to wash, clay, polish and wax car. What do I do and don't do for the clear bra?
Bill 1ss/rs m6 is offline   Reply With Quote
Old 08-11-2011, 01:23 PM   #2
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
treat the clearbra just like the rest of the car. There are some specialty products to help protect/clean the clear bra. But wash it, wax it, protect it.
Plexus is a very good protectant/polish
you could even us PC and fine machine polish with white pad (tape off edges of clearbra)
You don't want to put a powerwasher on the edges of it, you could peel it up.
Old 08-11-2011, 02:26 PM   #3
Pro-Tect Mobile
Drives: 2007 Jeep SRT-8
Wash it and wax it. Do not use Plexus as it does burn the film out. Plexus has butane in it which is not good for film. Its more for hard plastics. There has been a lot of testing to back this up so do not use anything petroleum based on the film. Also I would avoid clay bars... not sure that it would do any good and if it gets into the edges it is very difficult to get out. I have been installing film for 9 years now so I have a little experience with it.
Pro-Tect Mobile is offline   Reply With Quote
Old 08-11-2011, 03:05 PM   #4
Bill 1ss/rs m6
I would have thought that polishing would be too abrasive especially with a PC?
Old 08-11-2011, 04:57 PM   #5
Pro-Tect Mobile
Correct Bill. And that is only OK on certain films. All films are not alike. I NEVER recommend any of my clients polish their film. There is simply no reason to. My advice to you is ask your installer befroe doing anything drastic. A simple wash and wax is sufficient... anything more can lead to trouble.
Old 08-11-2011, 07:59 PM   #6
Bill 1ss/rs m6
Problem is I have some water stains and marks on it. How can I get them off safely?
Old 08-12-2011, 07:10 AM   #7
Pro-Tect Mobile
It depends on the type of film. All films are a little different and have different clear coats on them. So knowing the type of film will make it easier to give advice... but again I always recommend you ask your installer first.
Old 08-12-2011, 02:42 PM   #8
jdber94
jdber94's Avatar
Drives: 2011 LT2 RS-6Sp. Ordered 11/24/10
Pro-Tect, I'd appreciate some help. I have a clear bra by VentureTape and must left a Florida Bug on it a little too long (really only a fews days). It has now turned a light yellow where the bug once was. I've tried some Adam's products on it and nada. What's next?? Thanks.
2LT/RS Summit White/Inferno Orange, 6 sp Man
11/24/2010 - (1100)
12/01/2010 - (2000)
12/01/2010 - (3000)
01/03/2011 - (3800) Born
01/03/2011 - (4000)
01/03/2011 - (4150)
01/03/2011 - (4B00)
01/08/2011 - (4200)
01/17/2011 - (4800)
01/20/2011 - (5000)
01/20/2011 - Took my new girl home!!!
01/26/2011 - Clear bra installed
02/12/2011 - Windows tinted 35/20
jdber94 is offline   Reply With Quote
Old 08-12-2011, 02:48 PM   #9
zkdreads
zkdreads's Avatar
Drives: 2010 Camaro LS V6
i agree simple wash and wax and your good. ive had mine for a year now and it still looks like it was just installed. since im in florida i use a fabric softner sheet to get the bugs off.
C-LO or Sonic
"Without Struggle there is no progress"
I am your best nightmare!
zkdreads is offline   Reply With Quote
Old 08-12-2011, 11:36 PM   #10
Pro-Tect Mobile
To get out bug stains take some isopropyl alchohol and dab it onto the film. Do not rub it as it will ruin the finish. The IA will soak into the film and lift the stain out as it dries out. After about 30 minutes wipe of the rest with a detailer. Again just let the alchohol soak in a rag and then dab the film. It will pull it out. Once it is removed I would recommend using a good sealant on the film. It wil help prevent staining in the future.
Old 08-13-2011, 05:21 PM   #11
Wizzer
Drives: 2010 Cyber Grey
wax and wash with zip wash car wash. My wife has clear bra on hers for 5 years and still works. Over time they will harden depending on how long they are in the sun but you peel it off and put new back on. I will never own a car with out the clear bra.
Wizzer is offline   Reply With Quote
Old 08-13-2011, 07:54 PM   #12
third_shift|studios
third_shift|studios's Avatar
Drives: Like I Stole It!
Never use alcohol or a claybar on them-that will mar the finish. Use a heat-gun to 'cure' the bra. It will remove any swirling and hazing that has accumulated overtime and restore the bra to a high-gloss. See "treated" area below.
third_shift|studios is offline   Reply With Quote
Old 08-13-2011, 08:13 PM   #13
jdber94
jdber94's Avatar
Thanks, took about 70% of the yellow out. Someone else told me it will go away by just leaving it in the sun. Hope that takes out the rest.
11/24/2010 - (1100)
12/01/2010 - (2000)
12/01/2010 - (3000)
01/03/2011 - (4000)
01/03/2011 - (4150)
01/03/2011 - (4B00)
01/08/2011 - (4200)
01/17/2011 - (4800)
01/20/2011 - (5000)
Old 08-13-2011, 10:42 PM   #14
Pro-Tect Mobile
The sun will take the rst of it out. Once it cures use a good sealant on it to help minimize any more staining. Not sure if you get love bugs down there but they are notorious for staining clear bras. So a good sealnt will help prevent that.
Third Shift - a heat gun will really help "heal" light swirl marks with some films. You just have to make sure to be very careful as you can blister the film if left on one spot for too long.
Zaino and 3M clear bra j0hnny007 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 2 04-02-2010 04:37 PM
Clear Bra for your new Camaro Redlands Clear Auto Bra Wash/Wax/Detailing and Cosmetic Maintenance Parts 6 03-29-2010 09:15 PM
Spray on clear bra - Dominion Sure Seal Crystal Clear 2K Chip Guard sen10l Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 3 03-11-2010 01:00 PM
Clear Bra for your Camaro Redlands Clear Auto Bra USA - California 2 03-09-2010 04:26 PM
