Old 08-12-2011, 08:43 AM   #1
chevy454
chevy454's Avatar
Drives: '69 Yenko Camaro - 11.73 @ 118
6 speedauto: easiest way to change shift points
Ls7 with auto in sig...whats the easiest way to adjust shift points? We sent the tcm with the trans when rpm built it, but they built it for the milder engine/cam we started with...but its the stock 6k shift point, and our engine now peaks at 6700...
'69 Yenko Camaro - 11.73 @ 118, on F70-15 Polyglass tires, Pure Stock
'10 Yenko Camaro - 11.75 @ 117, LS7+A6+Converter
chevy454 is offline   Reply With Quote
Old 08-12-2011, 10:04 AM   #2
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
what tuning software
Tampa Tuning is offline   Reply With Quote
Old 08-12-2011, 10:23 AM   #3
chevy454
chevy454's Avatar
Ty Mason up in Michigan was the last to tune it, I believe he uses Hp Tuners...I'm trying to get in touch with him. Car made 500rwhp @ 6500 and 450rwtq @ 5500...should I simply leave the shift point as is? Anything launch-wise we can do?? Converter is 2800 Precision...
Old 08-15-2011, 04:46 PM   #4
Tampa Tuning
He can change the shift points in a couple minutes.
Old 08-15-2011, 05:24 PM   #5
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Its an easy fix, the mph and rpm have to both be right to shift at the commanded rpm though, he may need to have the vehicle to get it right on.
Rhino79 is offline   Reply With Quote
What song are you listening to right now Muscle Master Off-topic Discussions 6774 04-06-2026 12:33 PM
how to get best 0-60MPH on L99 Moonlight Dragstrip and Launch Techniques Discussion 52 01-03-2012 09:59 PM
Press Release: Shift Light for Camaro MTI Racing Kevin Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 05-04-2010 11:01 AM
Car "waking up" after oil change..is this due to the fuse pull? CamaroFemme 5th Gen Camaro SS LS LT General Discussions 6 10-05-2009 03:44 PM
Obama Climate Change Advisers Holdren and Lubchenco Are Told Global Warming Is Over bigralph Off-topic Discussions 15 02-06-2009 07:07 PM
