Old 04-17-2010, 06:43 PM   #1
Moonlight
Drives: 2010 Camaro 2SS/RS
how to get best 0-60MPH on L99
Hi
i dont have much experience in racing cars. so i was just wondering how you can get the best times on a stock 2SS? traction and stability all off? Use S or manual? if manual how to shift? do I floor the gas from the beginning? does temperature have a big impact here? etc.etc..
I would really appreciate if someone can help me cuz now im getting around 6 sec which is ridiculous.
thx
Moonlight is offline   Reply With Quote
Old 04-17-2010, 09:23 PM   #2
tom692010
Drives: 4 wheels
ya mean 16 sec right? 6 sec would be ridiculous but in a good way>
tom692010 is offline   Reply With Quote
Old 04-17-2010, 11:26 PM   #3
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
place right foot on skinny petal and push to floor lol
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 04-18-2010, 12:17 AM   #4
Moonlight
I meant 0 - 60mph. already edited the thread
thx for pointing that out
Old 04-18-2010, 06:28 AM   #5
CFD
Drives: 2SS/RS L99 BLACK
I've been racing cars and bikes for years so I have some experience, for what it's worth I've been playing with my stock 2SS/RS L99 and have found that my best 0-60's have been with trac/ctrl of, starting in 1st with a slight brake torque to get rpm's slightly up, right after launch 1st-second shift must be fairly quick, these damn transmission take so long to shift you'lle hit the rev limiter way to fast.
CFD is offline   Reply With Quote
Old 04-18-2010, 06:47 AM   #6
Indpowr
Drives: Corvette C6
Drag radials...
Old 04-18-2010, 11:14 AM   #7
Moonlight
emm this is interesting. I will try it as soon as i get a chance. Right now if I start in M1, then the tires would slip for the entire gear. your method sounds good, it may limit that slip.
thx
Old 04-18-2010, 11:16 AM   #8
Moonlight
Originally Posted by Indpowr View Post
Drag radials...
im sure that would improve the times a lot. but I just had it for a month and not planning on doing mods any time soon....(the real reason is I have no cash cuz i spent everything i have to buy it)
Old 04-18-2010, 02:58 PM   #9
Scott@Bjorn3D
You are actually better of loading the car up just a tad with the car in M/Sport Mode and do not use the tap shifts. The computer will out run tapshifting.
Scott@Bjorn3D is offline   Reply With Quote
Old 04-18-2010, 03:36 PM   #10
CFD
I've found the launch is much stronger in M1 as long as you don't mash the pedal to the floor and smoke em up, mine seems to do a real good hole shot around 3/4 throttle, but the 1St-2ND shift with tap shift takes a bit of practice, it's so slow. Too bad you can't take off in M1 without tap shift
Old 04-20-2010, 08:57 AM   #11
RefrigerationGuy
Drives: 09Sierra10Suburban 2SSRSbk/io
you should be able to take off in M (sport mode) without tap shift. Just don't touch the tap shift buttons and it will shift like a normal automatic,except with the different shift pettern(ie. sport mode). if you touch any tap button, then it is in manual shift mode and to get it back to sport mode, you have to shift back to D and then back to M again. also if you start off in D you start in 2nd gear, i M you start off in 1st gear.
RefrigerationGuy is offline   Reply With Quote
Old 04-20-2010, 09:11 AM   #12
Moonlight
I'm quite sure that in M or S you start off in 2nd gear also. unless you manually tap shift it to M1 then its all in your hands
Old 04-20-2010, 09:44 AM   #13
GoldBowtie
GoldBowtie's Avatar
Drives: 2021 Yukon Denali, 2018 ZL1
NO, you always start in FIRST --- unless you touch the tap button. Just pull it from neutral to M and leave it, so it shifts by itself. You'll start in first and downshift to first at a stop ---- UNTIL you touch a tap button!
2018 ZL1
GoldBowtie is offline   Reply With Quote
Old 04-20-2010, 10:51 AM   #14
toehead93
Drives: 2014 2SS/1LE
Gold Bowtie is right about when it will start in 1st or 2nd gear. I also agree that you can get the exact same launch in M (Sport) and M (Manual). Only D-mode will be slower.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3656 11-01-2025 01:41 PM
Stock L99 A6 Supercharger options, opinions, & experiences 2010 Bumblebee Forced Induction - V8 110 01-25-2019 04:23 PM
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 10:40 AM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 01:00 PM
L99 engine specifications Tran Wiki 0 10-19-2008 11:40 AM
