Old 08-17-2011, 07:20 PM   #1
Sam The Plumber
Sam The Plumber's Avatar
Drives: 2012 Black 2SS/RS Auto
vinyl stripes bubbling up
Does anyone who has vinyl stripes over the mail slot have problems with the corners,of the mail slot, bubbling up? in each corner i have a large bubble.
Sam The Plumber is offline   Reply With Quote
Old 08-17-2011, 07:21 PM   #2
Witwicky
I AM NOT FAMOUS ANYMORE
Witwicky's Avatar
Drives: 2010 2LT
What was the question?
Witwicky is offline   Reply With Quote
Old 08-17-2011, 07:22 PM   #3
Jose
Jose's Avatar
Drives: 2010 Camaro 2SS/RS White S/C
Are they the factory ones? If that's the case, then WARRANTY with them.
"It does not matter if you win or loose, what matters is if I win" Carl Fogarty
Jose is offline   Reply With Quote
Old 08-17-2011, 07:33 PM   #4
Sam The Plumber
they are aftermarket. i had them done by a reputable place. they tried to fix them but they continue to bubble in that area. i was just wondering if anyone knew why they continue to bubble in that area
Old 08-17-2011, 08:07 PM   #5
IAINIDIRIEIWI
Automobile Rookie
Drives: 2011 Victory Red LS Stock Camaro
Pictures? I might be able to help, I had the same issue with the stripes I installed myself.
IAINIDIRIEIWI is offline   Reply With Quote
Old 08-17-2011, 11:08 PM   #6
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
MARINE1991 is offline   Reply With Quote
Old 08-18-2011, 07:41 AM   #7
suplex
suplex's Avatar
Drives: 2011 Coupe, 1LT, A6, No RS Package.
What you should really do is stripes on the hood only, not going over to the front bumper. The less bends the stripes have to make...the better.
Either that or get them painted on.
Never Underestimate The Power of Forums
suplex is offline   Reply With Quote
Old 08-18-2011, 07:44 AM   #8
Russell James
Russell James's Avatar
The only thing you can do is pop the bubble with a pin and try to press it down. Sometimes that works. If it doesn't, the install shop should be stepping up to a redo.
Old 08-18-2011, 08:06 AM   #9
f5journal
Senior Camaro Fanatic
f5journal's Avatar
Drives: 2011 SS/RS manual - White
My installer refused to do the heat gun thing necessary to install without cuts in that area. He said it would eventually bubble up. So, if you look closely there are cuts with pie shaped filler pieces in mine. It doesn't bother me
f5journal is offline   Reply With Quote
Old 08-18-2011, 08:06 AM   #10
Xello
Xello's Avatar
Drives: 2010 CGM 2SS/RS
If the place that installed them is reputable then they should keep trying to fix them until they get it right.
Xello is offline   Reply With Quote
Old 08-18-2011, 11:23 AM   #11
heRS
Raised by Wolves
heRS's Avatar
Drives: IBM 2010 2LT RS M6
Meybe there's something on the surface of the decal or paint that is preventing it from sticking - poor prep work? Might be they need to pull those decals off, prep it right and put new ones on for you.
Tori
Old 08-18-2011, 01:00 PM   #12
thebighar
Drives: 2018 1LT RS V6 Nightfall Grey
Probably wasn't clean when they installed them. Nothing is going to stay down now. They would probably have to be replaced I would think.
thebighar is offline   Reply With Quote
Old 08-18-2011, 05:37 PM   #13
Caspers2SSRS
Caspers2SSRS
Drives: Summit White 2010 2SS/RS Camaro
Yes...and its a common issue. Caspers Mail slot insert area is covered with the carbon fiber film....looks great. But heat lends a hand and it seems to shrink in the last 1" or so of the corners, and appears to lift as though its too tight. Though the actual edges of the corners are tight. "Surface retention" in the curved area of those corners is poor, no matter the film or amount of skill applied. Plenty of prep work before the install too............I have replaced the film twice "self installed" and the same results occur in a matter of a few weeks. These products simply do not have enough give 'expansion" in them for curved inside corner applications. These areas are subjected to a sort of tug or war, when-ever temps vary between the material and the surfaces they are applied to. These areas warm and cool, the materials and surface doing so at different rates..and thus the failure. Its only noticable only on close inspection.......This is problematic in the same fashion as window tint applied to curved glass is, especially rear windows. The heat destroys the adhesives, ie advancing the problematic results. Its easy to imagine how the heat sources ( Radiator, Engine, the Sun ) are affecting the materials and there longevity applied in the mail slot area.
Caspers2SSRS is offline   Reply With Quote
Old 08-20-2011, 06:30 PM   #14
Sam The Plumber
pic
Vinyl Racing Stripes? or Painted stripes any opinions on which to go with? ChvyBoss Exterior Parts & Accessories 10 11-11-2010 05:33 PM
Vinyl racing & hockey stripes cheap looking Larz29 USA - Great Lakes 8 11-06-2010 02:20 PM
Rally stripes - Vinyl vs. Paint Richochet83 Cosmetics and Lighting Modification Discussions 22 06-29-2010 07:24 PM
Stripes - painted or vinyl?? jabbar Cosmetics and Lighting Modification Discussions 11 04-07-2010 11:24 AM
Vinyl vs Painted stripes in the desert sun 5th Gen SS Cosmetics and Lighting Modification Discussions 6 08-02-2009 04:42 PM
