![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: COTW 8/29/11 2010 CAMARO Join Date: Jul 2009
HOW DO I REMOVE THE AUTO PART OF THE CENTER CONSOLE
Hello, how do I remove the automatic plastic part of the console so I can send it for Hydropainting??
thanks.. |
#2 | |
TRI COUNTY TAMPA
Drives: 2011 1SS/RS VR/BLK A6 Join Date: Jan 2011
Now the hard part. You can either unbolt the screws you see on the white plastic piece that the shifter bezel ring is attached to, unhook wiring and remove whole unit or you can just remove the silver bezel while leaving the rest on the car. the silver bezel has multiple tabs that attach it to the white plastic. the ones on the sides are the ones you want to get to. Use a screwdriver or something to get down to the tab and GENTLY push it in while pulling up on the bezel. Should see and hear it break free. repeat on other side and massage the piece off It has lots of tabs and is held on tightly. I have seen some people have luck removing it by the large tabs on the front and rear. You can see the rear one in the photo i provided. I could not for the life of me get these to release so used the side ones and got it off. Use care not to push on anything hard. DO NOT BREAK THE SMALL BEZEL WITH PRNDM on it. You CANNOT BUY THIS PART BY ITSELF NEW. Only comes with entire shift assembly and isn't cheap and very hard to come by. Hope the PM's helped and let me know if you need more help. This mod your going to love. So much better than the silver.
#3 | |
Moderator.ca
moved to DIY & how to
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
How did you cover the "p,r,n,d, and m when you painted it?"
#6 |
Drives: 2010 Camaro 2LT VR/RS CGM Rally's Join Date: May 2009
How did u cover the lights?
#7 |
anyone??
#8 |
![]() Drives: 2010 camaro Join Date: Dec 2011
#9 |
i am trying to get mine off now its hard too do i am having no luck :(
#10 | |
http://www.phastekperformance.com/Hu...ter-auto-1.htm go to instructions |
#11 |
| New! 2010-11 Camaro Large Center Console Painted any Body Color! On Sale! | RPI Designs | Interior Parts & Accessories | 35 | 05-03-2016 10:13 AM |
| How to Install QTP Electric Cutouts | Quick Time | Camaro DIY & HOW-TO instructions & discussions | 73 | 05-03-2010 01:19 PM |
| Camaro SS vs Evo X | MAROobsession | Chevy Camaro vs... | 275 | 08-28-2009 04:49 PM |
| Camaro does the Nurburgring test track in 8:20 | 2sharp | 5th Gen Camaro SS LS LT General Discussions | 45 | 07-23-2008 04:17 PM |
