![]() Drives: 2010 Camaro 2SS RS, Black Join Date: Sep 2009
Rotating Front Tires Side to Side?
I'm getting my chromed OEM wheels installed tomorrow. The rear tires are getting replaced, but my front are still good around 50% so they are going to be reinstalled.
I've read a few threads suggesting that it might be a good idea to rotate the fronts side to side for longevity. It does look like the outer edge of the front right is slightly more worn than the left side. I'm wondering if there is any NEGATIVES to rotating the fronts? Obviously, because there is an "outside" to the Pirelli tire they will be going in reverse from what they have been thus far. |
![]() ![]() Drives: 2010 1LT/RS Join Date: Nov 2009
Dealer told me not to, I'd ask your dealer
2010 1LT/RS Eibachs, Doug Thorleys, Flowmasters, Stillen, hmm a few other things...
![]() Drives: IOM 2SS/RS & 2014 Mustang GT 5.0 Join Date: Jul 2009
Rotate side to side
![]() Drives: 2011 Camaro 2SS/RS Join Date: Apr 2011
My dealer said do the side to side every 7,500 miles while it's also in for an oil change. Only done it once so far, but wear is even on all tires. They do the same for the rears.
Red hood spears; Corsa cat-back exhaust; Roto-fab intake; Engine bay black/red theme; Black outs including both bowties, tail lights, tail light bezels, and side lamps; gill stripes; 35% window tints; Side SS badges; Hurst-equipped badge. |
What should I name my car
Drives: 2010 Camaro 2SS RS IOM Join Date: Jul 2009
Question:
When doing this. Do you have to swap just the tire (remove both front tires from rims then swap) or can you lift the front, and swap both front wheels and call it a day? I don't understand the whole asymmetrical tire tread one directional thing. Sorry if it's a no0b question.
Performance: ARH 2"/"3 headers + ARH 3" HF catback system, SS brake lines, hawk HP+ pads, motul RBF 600 fluid, K&N CAI (w/custom insulation), plug wires, air scoop, Hurst STS, Pedders Track II suspension, 18x10 wheels, 295/45/18 Nitto NT05s
Looks: powder coated iom calipers, LED foglights w/ always on harness, custom painted bowties, window tint, smoke tinted tail lights etc, oem gfx w/ custom outlets, painted taillight bezels, all weather trunk mat |
#6 |
![]() Drives: Camaro 2015 RS CRM Join Date: Apr 2009
I have 2 sets of tires and rims. The Perellis for about 8 months of the year and Yokohama Prada spec -x All seasons for the winter. I have swapped tires, front to front and back to back 4 times so far and I have never worried about a tire being the right front or the left front as I do not mark them. I have never had an issue. All 8 of my tires are showing better than normal and even wear.
IOM 2SS/RS manual
1100 - 4/7/09 3000 - 5/27/09 6000 - 7/17/09 See my Thread in New York Metro Area. http://www.camaro5.com/forums/showthread.php?t=33878 Last edited by Wild Bill; 08-25-2011 at 11:23 AM. |
#7 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
If you swap tires and wheels from side to side, what affect does that have on the TPMS? Right side might look like low pressure, but it would really be the left...
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 1969 & 2016 Camaro SS Join Date: Oct 2008
Any time you swap the wheel locations, you will need to do the TPMS relearn procedure to make sure they are reading the proper location. Check your owner's manual for that procedure.
I don't see the benefit of swapping tires side to side. Not unless you are a NASCAR driver and only take left turns. The front (and rear) tires should be wearing nearly identical if your alignment and air pressures are correct.
Fquick.com/NineBall
#9 |
Black Ice
Drives: 2SS/RS Black w/ silver ice stripes Join Date: Jul 2009
![]() Look up Radial Pull. The tires normally wear to fit them selves to the car and the road. The natural road crown on the road causes the tire to develope its own wear pattern. If you swap a tire side-to-side, you will create what is known as Radial Pull. Your stearing wheel will be off center a little and it will have an un-natural pull to one side. I wouldn't do it. This is coming from someone that has done alignments for over 20 yrs.
#10 |
Thanks for the info guys.
I won't be swapping from left to right.
| Add HUD to your 2010 | 2SSRS@Gen5diy | Camaro DIY & HOW-TO instructions & discussions | 1993 | 03-30-2019 09:02 AM |
| X5 Camaro exterior styling - front grille & side rockers | Sean@Phastek | Exterior Parts & Accessories | 2 | 04-18-2013 01:10 PM |
| DIY: Removing side markers Front and Rear | CamaroNewb | Camaro DIY & HOW-TO instructions & discussions | 10 | 02-25-2011 10:05 PM |
| Rotating Tires 2LT RS | camaromaybe | Wheels and Tires Talk Sponsored by The Tire Rack | 4 | 09-14-2010 12:17 AM |
| Recommendation for Skinny Front Tires | Camcam16 | Dragstrip and Launch Techniques Discussion | 2 | 06-03-2010 07:54 PM |
