Old 08-25-2011, 10:37 PM   #1
TekScrew
TekScrew's Avatar
Drives: 2010 Rally Yellow 2LT/RS
What exactly is a non-fouler?
Ok I know that a non-fouler is used to trick your ECM into thinking your O2 sensor is reading correct if you've modified your exhaust. But I have never actualy seen one. Is it a spacer that you thread into the O2 sensor bung to pull the sensor out of the exhaust stream a little, or is it a resister of sorts that plugs in between the sensor and the wiring harness. Does any one have any pics of one, or can someone explain how they work. My CEL just came on and I'm exploring my options. I'm not ready for a tune yet.
TekScrew is offline   Reply With Quote
Old 08-25-2011, 10:38 PM   #2
BSR-1
BSR-1's Avatar
Drives: 17 ZL1 M6 Black
http://cgi.ebay.com/ebaymotors/Brand...item35b4818a5f
BSR-1 is offline   Reply With Quote
Old 08-25-2011, 10:51 PM   #3
LLT'MARO
Drives: 2010 Camaro V6/6Spd
I believe you are thinking of an o2 simulator. Which is used to trick the ECM in to thinking either the rear O2 is there if it has been "lost" for some reason....or to make the ECM thinking the rear o2 is operating within normal bounds when it is not
LLT'MARO is offline   Reply With Quote
Old 08-25-2011, 11:04 PM   #4
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
They are like $4 at autozone, but I can save you the trouble and let you know they don't work for our cars.
What mods do you have?
Old 08-25-2011, 11:04 PM   #5
Hicompression
Rumbly Bumble Bee
Hicompression's Avatar
Drives: 2010 2SS Camaro
This:
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW!
Hicompression is offline   Reply With Quote
Old 08-26-2011, 06:09 AM   #6
LLT'MARO
Here's a quick read on what a o2 simulator is. (BTW not advocating their products)
http://o2sensorsimulator.com/
You can build one yourself if you are into electronics.
Old 08-29-2011, 06:00 PM   #7
TekScrew
TekScrew's Avatar
JBA Shortie Headers, SLP Loudmouth II mufflers, SLP Backwing Intake.
Spark plug fouler for LT headers??? Wileytrigger21 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 03-04-2010 03:12 PM
