Old 08-27-2011, 10:59 AM   #1
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
SJM line lock VS convertible strut tower brace
First and foremost let me send a shout out to Speed Inc. for their insanely great price o this WITH free shipping, I saved about $25 going through them and I had it on my door step in a couple of days!
Now, I'm guessing I'm one of the first to try installing this on a convertible or a coupe with the GM strut tower brace (STB) installed. It looked like it was going to be a tight fit, but having been modding LSx cars for about 12 years now I'm sure I could make it work.
The instructions are very easy to follow and strait forward. They come printed as a booklet with each page being half of the paper in landscape mode. At first glance i thought the pictures were going to be too small, but they weren't. The instructions were fine, I wouldn't change a thing.
I took off the STB for room to work and bolted everything up the exact way the instructions said. It was a very good fit and looked great. I went to put the strut tower brace back on and it was a NO GO. The SJM line going from the ABS block to the line lock solenoid was interfering with the STB. It was a relatively easy fix. I just moved one of the lines around a little bit, a bend here, a twist there and it fit perfectly.
You just have to Move the inlet line over between the second and third line instead of the first and second. The outlet you can just install and bend over until it clears.
This is how the SJM fits on cars with out the GM STB
Here is the pics of my install.
The first pic is installed as is and you can see how the STB won't clear the line. The STB was about 2" from where it was supposed to be.
The rest of the pics are after I moved and tweaked the lines.
SUX2BU is offline   Reply With Quote
Old 03-12-2012, 11:01 PM   #2
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
Although, a different brand I have a strut tower brace as well I may have to do some adjustments as well.
Where did you place the switches?
Good job.
calbert1999 is offline   Reply With Quote
Old 03-12-2012, 11:24 PM   #3
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Good job.
I like the stock sleeper look so I used the cruise control button and hid the rocker switch/LED that came with the SJM kit in my A/C vent.
http://www.camaro5.com/forums/showth...cruise+control
Old 03-12-2012, 11:40 PM   #4
calbert1999
Camaro SS Lover
That's a cool idea. I'm thinking of getting a totally different black switch (size of a nickel) with a built in LED. I'll place it in the pillar pod, and I'll get the momentary switch that is mounted on the shifter shaft.
Where did you put the momentary switch?
Old 03-12-2012, 11:50 PM   #5
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
I used the cruise control cancel button. Click on that link, it shows you how to do it.
Old 03-12-2012, 11:58 PM   #6
calbert1999
Camaro SS Lover
Yeah. I heard of that option. I rather keep the systems separate. But, that is a great idea.
I also like where you have the primary switch too in the vent, I just prefer to have it done the quickest easiest way possible.
Official 2011 Camaro Convertible Details and Specs released! The Viz Camaro Convertible Forum 140 12-08-2018 08:47 PM
ALL NEW DESIGNED BMR 4 POINT STRUT TOWER BRACE - YES TO THE V6!!!!! Erik@Torq Suspension / Chassis / Brakes 0 04-01-2011 11:05 AM
BMR Front 2 and 4 Point Strut Tower Braces! FREE SHIPPING! AJ@ECSMotorsports Suspension / Chassis / Brakes 8 11-13-2010 04:45 PM
Strut Tower Brace? Phadt or Anyone Elses JohnnyrSS Suspension / Brakes / Chassis 7 10-22-2010 06:36 PM
MTI Racing Strut Tower Brace MTI Racing Kevin Suspension / Brakes / Chassis 0 06-28-2010 01:57 PM
