![]() Drives: 2011 2SS/RS Inferno Orange Join Date: Aug 2011
Anyone running 245/45/20 tires on all 4 corners on the SS model ?
I have a 2SS/RS and I want to replace the P-Zero's with Continental DWS all season tires on the stock wheels. The Continental DWS 275/40/20 rear tires are on back order but it seems there are plenty of the 245/45/20's.
What are the pros/cons of running the 245/45/20's on all 4 corners ? My car is a daily driver that I have no intention of taking to the track. I see some people on here running the 245/45/20 size winter tires on all 4 corners so what about all seasons ? |
knows 2 facts about ducks
I'm running 245/45/20 on all four wheels with my winter tires. So far I haven't had a problem with that set up.
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
You'll be perfectly fine running 245/45/20 on all 4 corners. You'll just be giving up a little traction off the line and around turns (oversteer - back tires sliding out). |
Master of All Things
Drives: '26 Corvette Stingray Join Date: Jul 2009
and if nothing else, so that you could actually rotate them.....IF you get anotherset of FRONT wheels so that all four WHEELS are the same as well.
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Dec 2009
Yes. I sold a set of four fronts to a member up north who wanted to use them as with snow tires.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10. ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller. |
#6 |
Thanks guys for your feedback, it is helpful to know that this should work- much appreciated !!
| 5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 06:52 PM |
| SS 20" Wheels and Tires, Midnight Silver, 4k Miles | Z71456 | Local Marketplace | 2 | 08-09-2011 01:13 PM |
| SS Steering wheel for LT Model | Steppenwolf1980 | Cosmetics and Lighting Modification Discussions | 10 | 12-22-2010 09:03 AM |
| Winter Tires for 2010 SS | dtodd | Wheels and Tires Talk Sponsored by The Tire Rack | 25 | 10-24-2009 11:37 AM |
