Old 08-31-2011, 10:06 AM   #1
CamaroCorvetteFerrari
Drives: 2010 Chevrolet Camaro 1LT RS
How do I replace the right rear turn signal?
I got an alert today on the gauge that I should check the right rear turn signal, after I signaled to merge into the right lane. I didn't positively confirm it, but I suppose it's reporting it's not turning on..
Assuming the bulb is bad, what kind of bulb do I need? And how do I replace it? Is there a diagram for the location and kinds of fuses, as well?
Thank you very much.
CamaroCorvetteFerrari is offline   Reply With Quote
Old 08-31-2011, 10:08 AM   #2
2010camarolt
2010camarolt's Avatar
Drives: Victory Red 1LT
this happened 2 me a few weeks ago i bought it 2 chevy and it was covered under warrenty
2010camarolt is offline   Reply With Quote
Old 08-31-2011, 10:12 AM   #3
Thank you.
We had a hail storm in my area (NY) and I had to bring it into the shop (covered under insurance). I just got it back and, a few days later, today in fact, the turn signal is out. So, I may just complain to my insurance, since the work is guaranteed. If it fails on deaf ears, I'll talk to the dealer.
Old 08-31-2011, 11:00 AM   #4
Camaro21
Drives: SOLD - 2013 M6 ZL1
It is easy to do. Just open the trunk and there is a Black plastic cover on the right side that has 3 push pins that need to be removed, remove the cover and you can see the tail light sockets. Turn then Counter Clockwise about 1/4 turn and you can pull them out of the lens assembly. Replace the bulb and use reverse procedures to re-install !! It should take about 5-10 minutes for someone that has never done it before.
Camaro21 is offline   Reply With Quote
Old 10-19-2011, 12:05 PM   #5
Yeah, I did this completely wrong. I thought it was those three turn knob things and that was definitely not it. Now I see what you are talking about. There are these things that like screws but there's nothing to "grab" onto. These must be the push pins of which you are speaking. They are surrounded by what look likes a plug, which twists off. How do I remove these push pins???
Old 10-19-2011, 03:56 PM   #6
ffrcobra_65
push pins...u just take a sharp skinny whatever and stick it in under the head of the push pin and lift up.
Old 10-19-2011, 03:59 PM   #7
The Stig
knows 2 facts about ducks
The Stig's Avatar
They're called scrivets and you can pop up the center piece with a small flat head screw driver.
Click to view my build thread
fuse, rear, replace, signal, turn
Rear end "popping" noise, need help and opinions Fiftydriver V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 35 09-19-2013 09:47 PM
Push Start button? CG'sSS Camaro DIY & HOW-TO instructions & discussions 158 06-06-2012 08:27 PM
DIY - 2010/11 Camaro AAC LED Side Markers Install with Turn Signals GearHeadPeter Camaro DIY & HOW-TO instructions & discussions 0 03-03-2011 02:30 PM
PWA "The Lounge" DGthe3 Off-topic Discussions 143773 11-06-2010 12:00 PM
