Old 09-01-2011, 11:24 PM   #1
lionssfan
lionssfan's Avatar
Drives: 2010 2ss camaro
whipple injectors help
I'm buying a whipple and need help on injectors size. I know they come with upgraded 63lbs, but if I put a cam in later will I need bigger injectors. I heard the duty cycle of the injectors is what they change depending what the motors needs. So going bigger now without a cam is ok due because they will just back off on the duty cycles. So what size do you think would be best. 85lb injectors? best brand? I will be in the 575hp to 700hp horsepower range. I've read of brand names F.A.S.T and ID what is better and why? thanks guys you alway pull thru for me.
lionssfan is offline   Reply With Quote
Old 09-01-2011, 11:36 PM   #2
shines
Drives: 2010 Camaro SS/RS
The stock Whipple injectors will get you to 650 rwhp with the right fuel pump. If you need more injector after that, go with the ID850's from Injector Dynamics.
shines is offline   Reply With Quote
Old 09-01-2011, 11:52 PM   #3
lionssfan
lionssfan's Avatar
buyer
thanks shines........!
Old 09-02-2011, 11:28 AM   #4
boostedyards86
boostedyards86's Avatar
Drives: Cummins 3500
DO NOT USE FAST INJECTORS
85 Buick TType - 5.3l GT4202r 10.86 at 126
boostedyards86 is offline   Reply With Quote
Old 09-02-2011, 11:36 AM   #5
Louis @ LG Motorsports
Drives: 2010 SS/RS 2009 CG Z06
We stock ID850s
Currently have 4 cars in the shop with them, and wouldnt use anything else.
Louis @ LG Motorsports is offline   Reply With Quote
Old 09-02-2011, 12:08 PM   #6
lionssfan
lionssfan's Avatar
Originally Posted by Louis @ LG Motorsports View Post
We stock ID850s
can you pm me for set ID850s thank you
Old 09-02-2011, 03:20 PM   #7
MudderFinger
MudderFinger's Avatar
Drives: 2011 IOM SS/RS
I would not use those injectors past 600hp, go with the ID-850's just as someone one said. That is what I am running and I have a whipple and a blower cam. Also look into buying a LPE dual fuel pump or ADM.
MudderFinger is offline   Reply With Quote
Old 09-02-2011, 04:44 PM   #8
lionssfan
lionssfan's Avatar
forget the boost pump then? and go with a lpe or adm? thanks for you help I'm narrowing it down.
Old 09-02-2011, 06:35 PM   #9
BAPs are troublesome, and a bandaid. I would run the LPE twin if it were a build we were doing.
Old 09-03-2011, 08:52 AM   #10
JANNETTYRACING
JANNETTYRACING's Avatar
I sell the Whipple Tuner kit, then include, a CAI cold air kit, Injector Dynamics ID-850s, A ZR1 Map Sensor, an MSD fuel pump voltage booster for up to 600 RWHP, and an SCT hand held tuner With my Custom Tune.
For over 600 RWHP with Our Blower Cam, I take out the MSD and replace it with an LPE dual Fuel Pump System and a Smaller Pulley and a Different Tune.
This whole system is backed by our Stellar Customer Service.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 09-03-2011, 02:08 PM   #11
lionssfan
lionssfan's Avatar
Ted.
Thanks Ted again, your header tune has worked out well. I'm looking at a used whipple. I will have to get back with you for complimentory parts. thanks again Ted
Whipple Superchargers from the Largest Volume Install shop in The USA - TORQ! Erik@Torq Forced Induction 25 08-07-2012 04:01 PM
Whipple Superchargers from the Largest Volume Install shop in The USA - TORQ! Erik@Torq Forced Induction - V8 27 10-24-2011 10:34 AM
Vengeance Racing Whipple S/C Packages!!!!! Check these out!!!! Kevin@V Forced Induction 10 09-09-2011 03:42 PM
Will EV14 LS3/9 injectors work with the whipple. jasycz28 Forced Induction - V8 6 06-16-2011 06:42 AM
Whipple Superchargers In The House!!! HP Addicts Forced Induction - V8 1 04-27-2011 09:26 PM
