Old 09-19-2011, 11:35 AM   #1
Maro99
Maro99's Avatar
Drives: Heel toe express..
Any way to know if I have TPMS installed without removing tires?
I am just installed some new OEM 20" wheels that I bought off ebay. They had tires installed when I got them and the owner is not sure if they have sensors or not. I tried the TPMS relearn method as described in the manual with no luck. So my question is, is there a way to tell if the TPMS are installed without removing the tires? I dont want to buy a set of TPMS and have the them installed just to find out I have TPMS installed already and waste more money. Any ideas?
Camaro SOLD :(
Maro99 is offline   Reply With Quote
Old 09-19-2011, 11:39 AM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
If the relearn procedure did not work than you probably do not have the TPMS sensors.
Click to view my build thread
Old 09-19-2011, 11:49 AM   #3
Maro99
Maro99's Avatar
I feel like I may have been doing it wrong even though it is pretty straight foward.. I set it to learn and went to the front driver tire and used a key to release air from the tire for about 20 sec. but did not hear any "chirp" like described in the manual. Does that sound like I did it right?
Camaro SOLD :(
Old 09-19-2011, 11:56 AM   #4
The Stig
The Stig's Avatar
That sounds right. When you clicked relearn on the DIC, did the screen change? It should say something like "30 seconds to relearn" or something similar.
Old 09-19-2011, 12:06 PM   #5
Maro99
Maro99's Avatar
Yeah it said "Tire Learning Active".
Camaro SOLD :(
Old 09-19-2011, 12:11 PM   #6
The Stig
The Stig's Avatar
Hmmm, I would maybe try it again. When releasing the air from the tire you don't want it to come out super fast. Nice and slow, I just use my fingernail to depress the pin thingy a tiny bit.
Old 09-19-2011, 12:23 PM   #7
Maro99
Maro99's Avatar
I did let alot out lol.. I'll put some air in and try it again later today. Thanks
Camaro SOLD :(
Old 09-19-2011, 12:28 PM   #8
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Stop by a tire shop and see if they have a TPMS scanner tool. Mine will beep and flash the lights on the tool if if senses a sensor inside the tire. It helps identify the frequency/type of sensor.
Fquick.com/NineBall
Old 09-19-2011, 12:33 PM   #9
Maro99
Maro99's Avatar
Thanks, I will try that as well.
Camaro SOLD :(
Old 09-19-2011, 02:29 PM   #10
Maro99
Maro99's Avatar
Mystery solved.. There are no sensors in the tires. I took the car down to a tire shop and they couldnt detect them. Just to make sure I had them remove one of the tires from the rim. Need to buy some sensors now .
Camaro SOLD :(
Savini Wheels -Beware! Dr Jkel Vendor and Seller review / feedback / experiences 661 08-01-2014 07:41 PM
Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow KILLER74Z28 General Automotive + Other Cars Discussion 25 07-22-2011 11:51 AM
20" polished wheels, tires, tpms sensors and lugs - $650 Red67Stang Wheels / Tires 17 05-17-2011 10:26 PM
Perfect 18" Winter Set! wheels, tires, lugs, and TPMS sensors! rsinmaine Wheels / Tires 15 12-26-2010 08:32 PM
