Old 09-20-2011, 10:00 PM   #1
InfernoMan2011
Drives: 2011 Inferno Orange 1LT
Tire Pressure? Owners Manual fails again!
Well, the cooler weather this last weekend here in Arkansas set of the TPMS on my car off. Tire pressure light on the dash as well as the annoying message in the DIC every time you turn the car on. All tires were at 28 psi after the temp drop. I finally was able to get by a decent Shell station today and paid my 75 cents to air up the tires. I spent 20 mins literally looking for the recommended psi to inflate the tires to and never found it in the Owners manual. The section on TPMS said about everything about tire pressure except for the the recommended psi. It just said that the recommended psi is on a sticker attached to the car. Real specific there....it didn't say where on the car said sticker is. I ended up just inflating to 32 psi on all 4 tires and that got rid of the lights and DIC message. I know the inflation psi will vary slightly depending on tires, but there should be a psi for the stock equipment. My car actually came with Goodrich tires on it rather than the Pirelli's which I was actually happy about. Anybody know what the recommended PSI is? I read that this is not determined only by the tire inflation recommendation on the tires, but also by the vehicle weight.
-infernoman2011
InfernoMan2011 is offline   Reply With Quote
Old 09-20-2011, 10:08 PM   #2
Flashpoint135
Flashpoint135's Avatar
Drives: 2016 SS
35 PSI. The sticker is on the drivers door jam - open drivers door and look at the door frame halfway up near the latch. Yellow sticker.
Flashpoint135 is offline   Reply With Quote
Old 09-20-2011, 10:18 PM   #3
NASCR3
NASCR3's Avatar
Drives: Synergy Green 2SS/RS/HURST
What ever the the tire pressure label inside the drivers door jamb says regardless of tire brand is the correct pressure for the car to obtain the ride and handling characteristics that GM designed the car with. To muddy up the water even more 30 to 34 psi is a safe pressure on 95% of passenger cars, but like I said the label is the correct. If it says 30 or 35 psi follow it, especially since the TPMS are calibrated on those numbers and like you said the DIC message is really annoying for you.
By the way, Tire Pressure Loading Info labels have been inside the doors of cars for many many years. It is easier for the manufacturer to reference the label rather than bury it in the manual, not so much a fail as much a universally accepted practice across the entire auto industry.
2011 2SS/RS - Factory Hurst - Synergy Green - Cyber Gray Rally Stripes - Jet Black Interior - Born on 10/4/2010
2G1FT1EW7B9128807
Ordered: 8/6/2010
1100: 8/6/2010
2000: 8/23/2010
2051: 8/10/2010
2500: 8/24/2010
3000: 8/25/2010
3100: 9/8/2010
3300: 9/8/2010
3400: 9/11/2010
3800: 10/4/2010
4000: 10/4/2010
4200: 10/4/2010
5000: 10/13/2010
6000: 10/14/2010
NASCR3 is offline   Reply With Quote
Old 09-20-2011, 10:20 PM   #4
Parag
Drives: 2010 camaro 2SS LS3
The sensors trip at 31 psi
Parag is offline   Reply With Quote
Old 09-20-2011, 10:27 PM   #5
vinman
The BBOMG fill-in husband
vinman's Avatar
Tires say 36psi
UPSTATE C5 MEMBER
Old 09-20-2011, 10:36 PM   #6
InfernoMan2011
Thanks for the info. I was aware of that sticker, but didn't think that it would have the tire pressure info on it. Thanks again.
-infernoman2011
Old 09-20-2011, 11:07 PM   #7
NASCR3
NASCR3's Avatar
2G1FT1EW7B9128807
Ordered: 8/6/2010
1100: 8/6/2010
2000: 8/23/2010
2051: 8/10/2010
2500: 8/24/2010
3000: 8/25/2010
3100: 9/8/2010
3300: 9/8/2010
3400: 9/11/2010
3800: 10/4/2010
4000: 10/4/2010
4200: 10/4/2010
5000: 10/13/2010
6000: 10/14/2010
Old 09-20-2011, 11:12 PM   #8
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
-infernoman2011
I think, though I could be mistaken, that it's pretty standard procedure for all manufacturers to have that sticker in the driver's side door jamb.
So next vehicle you're looking for PSI on - check there first.
Old 09-20-2011, 11:16 PM   #9
xXSilencerXx
Butter Bar!
xXSilencerXx's Avatar
Drives: 2011 SS, 1998 Trans Am
I'd that's a safe bet. I've never come a across a car that didn't have that info on the sticker. Mine went of this weekend too. Was cracking me up how it had the picture of the car with the low tire blinking like it was a video game. haha
2011 Camaro SS, White/Orange, LSR Short Throw, CAI
1998 Trans Am, Red, H/C/I, 3200 CircleD Stall, full suspension
2004 GSXR 1k, Matt Mladin Edition
xXSilencerXx is offline   Reply With Quote
Old 09-21-2011, 06:27 AM   #10
babaron
Totally into it
babaron's Avatar
Drives: '67 427vette/'11 Pacecar/'02 BMW ci
You can also check the sidewall of the tire itself for the Max pressure. Many inflate to this to get the best mileage.
babaron is offline   Reply With Quote
Old 09-21-2011, 09:23 AM   #11
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
That is a terrible idea. You get a harsh ride and reduced contact.
Rock-It Man is offline   Reply With Quote
Old 09-21-2011, 09:40 AM   #12
Russell James
Russell James's Avatar
No fail on the owner's manual, it gives the correct answer - see the sticker. Keep reading a little further, it refers you to another page in the manual that tells exactly where the sticker is, gives an example of what it looks like.... has tomorrow's lottery numbers and KFC's secret chicken spices. It's all in there, just gotta dig.
Old 09-21-2011, 10:53 AM   #13
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Don't forget, the pressure reccomendation is for COLD tires.
Old 09-21-2011, 12:19 PM   #14
Johnnyma45
Former Camaro Owner
Johnnyma45's Avatar
Drives: 2011 Dodge Charger R/T
Which means whenever you inflate, inflate to 1-2psi more than the recommended (unless you are inflating at home). Also go to a tire shop like Discount Tire, they usually have a bay where you just pull in and they fill up your air for free. Fast and easy, especially when it's cold out.
6/9/10-3/30/11. RIP ROXY... :(
Johnnyma45 is offline   Reply With Quote
Colorado members check in here 2010 SS RS USA - Rockies / Midwest 8853 06-13-2022 08:45 PM
Tracking All Currently Known US VIN and Window Stickers - Order Tracking Thread UCF w00t Camaro Price | Ordering | Tracking | Dealers Discussions 4242 02-17-2014 09:57 PM
Acronyms at C5 hokie2012 5th Gen Camaro SS LS LT General Discussions 34 08-10-2011 04:56 PM
now logging actual line pressure in A6, less than 100psi in 3rd parish8 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 02-20-2010 10:46 PM
I think i'm done waiting. pinkcamaro10 Off-topic Discussions 332 05-13-2009 05:56 PM
