![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Camaro 2SS/RS Join Date: Jul 2009
Thoughts on 2012 suspension (previously owned a 2010)
After about 700 miles on my 2012 SS- i thought some people might like a somewhat decent review comparing the two-
My 2010 2lt/rs rode very smooth and would easily hug a sharp on/off ramp on the freeway at 40-50+ MPH without any body roll or tire grinding (the point where the tires starts to loose traction- most know what im referring to)- The v6 (2010/2011) had a better rated weight balance ratio than the SS- many said it handled noticeably better as well. The ride on the 2010 was very smooth (possibly slightly attributed to the larger RS tires). The 2010 just had that glide around the turn feeling where it wouldnt even break a sweat as opposed to other cars ive attempted the same turns in. The 2012 SS- handles better than my 2010 did. Both are RS- no difference there. The SS seems to be able to handle the turns even better than the 2010 could, with less stress on the tires. What i mean by this is- the tires stayed planted and dont squelch/ begin to break loose etc on the same ramps the 2010 would slightly begin to on at the same speeds. The ride is every bit as smooth as the 2010- not better, but just as good. Im mainly impressed with the cars ability to take a sharp turn and turn into a turn that feels like im running on rails. No tipping/ body roll/ loss of traction/ anything. Overall the ride quality of my 2012 SS IMO is just as good as the 2010 LT's which were always rumored to have better ride quality than 2010 SS's- and the 2012 handles better than 2010 v6's which have repeatedly been rumored as better balanced/ handling. The engineering crew did a great job with the refinement of the suspension- a big improvement. Hope this helps some of you who were questioning this.
2LT/RS M6 CGM VIN#53104 SOLD
2012 Black 2SS/RS w/ Hurst- Mods: Corsa catback, SSE, Vararam |
The thin blue line
Drives: 2012, 2SS/RS,LS3,IOM/Beige Join Date: Aug 2011
Mike25,
Thanks for your review. I had wandered if the new SS suspension was indeed better than the suspension on previous year SS models. You just added more anticipation to the wait for my 2012. |
Your going to like it- a vast improvement!
![]() Drives: 2016 Camaro Hyper Blue 2SS Join Date: Mar 2011
So it looks like I need to go get some lower control arms and sway bars
** The above post is by someone who is not an expert **
2005 Pt Cruiser panel Conversion 2016 2SS Camaro Hyper Blue white interior 1937 Chevy truck. Full custom. Build in work https://www.teamalini.com |
#6 |
![]() Drives: 2011 Camaro Join Date: Apr 2010
I think it would be more appropriate to compare the FE4 with the FE3, as opposed to the FE4 to FE2 comparison we have here.
#7 |
![]() ![]() ![]() Drives: 2011 Dodge Charger Join Date: Apr 2009
Thanks for that review. Though as some have stated it would be nice if someone could chime in that's had an FE3 suspension and went to and FE4.
2011 Dodge Charger
#8 |
TRI COUNTY TAMPA
Drives: 2011 1SS/RS VR/BLK A6 Join Date: Jan 2011
Stock for stock the SS handles much better in the scenarios your describing than the V6. You really can't compare. The 2012 FE4 has a few minor improvements over the FE3. Under steer would be the biggest one addressed.
It's a nice review just is an apples to oranges type thing. |
#9 |
Drives: Camaro Justice Join Date: Jun 2007
1. Starting with the run of Verts, the engineers at GM improved the rear sub-frame bushes.
2. The location of the rear sway bar endlink connection closer to the wheel and a slight increase in bar diameter improve the balance. 3. The damper map, the bound and rebound in the struts, was revised. IMO, the damper map change is the most significant improvement. If you want to upgrade your 10 or 11 Camaro the new struts would be the money parts. |
#10 |
TRI COUNTY TAMPA
It has larger stabilizers to control body roll more and re tuned dampers front and back. Minor changes to help with roll and under steer. Other than that it's basically the same suspension as the FE3.
You can add a few upgrades onto the FE3 from say Pedders or Pfadt and outperform the FE4 all day long. |
#11 |
Based off what I've read..there's very little difference between the fe2 and fe3- still though, I understand it jut isn't the fe3- just though I'd offer my review
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS/RS - 2004 Silverado Join Date: Mar 2010
Does anyone know if the ride height is different on the 2012 SS compared to the '10-'11 SS?
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80 2004 Black Silverado 1500 2WD Regular Cab, Short Bed -5.3 LM7, 4L60E, 3.42, G80 2014 White Caprice PPV -6.0 L77, 6L80E, 2.92, G80 |
| 5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 06:52 PM |
| 2012 FE4 suspension 1st glance | R6P | Suspension / Brakes / Chassis | 151 | 08-17-2011 07:54 PM |
| New Guy with question about 2012 FE4 Suspension | JJKJ | 5th Gen Camaro SS LS LT General Discussions | 2 | 05-26-2011 02:55 PM |
| Latest Camaro Products - March 2010 | Sean@Phastek | V8 Bolt-Ons & Tunes | 26 | 08-04-2010 05:42 PM |
