Old 09-29-2011, 09:47 AM   #1
Yazeed
Drives: Camaro 2LT / RS
Thumbs down problem with my MRT V2.0
Hey guys !!
So I installed my MRT yesterday to my V6 camaro and I was so excited the sound is AMAZING .. But I noticed evertime I take a left turn while I'm stepping on the gas a little bit ( RMP is between the 1 and 2 and maybe above the 2 by a little bit ) I hear a rattiling noise coming from the passenger window or my rear windshield .. Is this normal and did u guys have this problem and what should I do ?
Thanks !!
TEAM LLT !!
MRT V2.0
CAI
Yazeed is offline   Reply With Quote
Old 09-29-2011, 09:49 AM   #2
c_LoW29
Drives: 2011 2SS/RS, 2010 Mustang GT
Originally Posted by Yazeed View Post
Hey guys !!
Thanks !!
Not sure if this has to do with the exhaust but get under the car with a socket and tighten down the bolts on the clamps really tight may just be a little loose.
c_LoW29 is offline   Reply With Quote
Old 09-29-2011, 10:04 AM   #3
stray bullitt
Drives: Bentley Continental GT.
I was going to say the same thing. Also with a new exhaust, they will tend to sound a bit more raspy,until the carbon residues build up inside.
stray bullitt is offline   Reply With Quote
Old 09-29-2011, 11:58 AM   #4
Yazeed
They're tightt but I'm pretty sure its a window rattiling tho its sounds like glass
TEAM LLT !!
MRT V2.0
CAI
Old 09-29-2011, 12:07 PM   #5
BenningJ
BenningJ's Avatar
Drives: 2013 AGM 1SS/RS LS3
^^^^This.... You think they are tight but it took me a lot of force to get them to clamp down properly and yeah they will sound a bit hollow until the carbon builds up.
The mufflers do add a bit more cabin vibration so it could very well be the window rattling. I would recheck the clamps, drive around for a while to let the mufflers break in, and then if you are still having this issue take the car to the dealership to have them look at it.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts
BenningJ is offline   Reply With Quote
Old 09-29-2011, 02:13 PM   #6
vcamarorosinski
Drives: 2010 synergy green
It is called drone. Common problem with MRT.
vcamarorosinski is offline   Reply With Quote
Old 09-29-2011, 02:21 PM   #7
stray bullitt
Not with version 2 it isn't. It's louder, but there definately isn't an annoying resonance at any speed in my experience.
Old 09-29-2011, 02:40 PM   #8
testmule
Drives: 2011 camaro
Just be prepared that if you call MRT everything will be your fault.
testmule is offline   Reply With Quote
Old 09-29-2011, 02:42 PM   #9
Birm
Birm's Avatar
Drives: Florida Speed & Power
Get it welded! Also MRT V2 has quite a bit of drone in the 2k range but for a v6 it sounds awesome WOT
Birm is offline   Reply With Quote
Old 09-29-2011, 02:43 PM   #10
Birm
Birm's Avatar
Yea there is for someone not use to performance sounding exhaust there is actually quite a bit. Most of us are just use to it or enjoy it
Old 09-29-2011, 02:45 PM   #11
Mr.Maro23
Mr.Maro23's Avatar
Drives: 2010 2lt chevy camaro
MAYBE THE WELDING DIDNT GO SO GOOD CUZ I HAVE THE SAME THING AND SOUNDS GOOD HAD IT FOR COUPLE OF MONTHS AND STILL GOING
Mr.Maro23 is offline   Reply With Quote
Old 09-29-2011, 02:54 PM   #12
stray bullitt
Ha Ha! I guess I do get a kick out of a meatier exhaust sound, but really in 5th or 6th at say 70, my car is not raucus inside.
Old 09-29-2011, 03:34 PM   #13
Yazeed
Yeah mine isn't welded..
TEAM LLT !!
MRT V2.0
CAI
Old 09-29-2011, 03:56 PM   #14
cyberLS
cyberLS's Avatar
Drives: 2010 Cyber Grey LS
Go to the dealer and ask them to check your rear and window someone i know had the same sound of window rattling with the bass turn up she took it to the dealer and they said they have to tighten something i am not positive of what it was but it doesnt hurt to check.
cyberLS is offline   Reply With Quote
Share your own experience ,How your camaro brake noise problem was solved ? M-SS Suspension / Brakes / Chassis 30 10-31-2011 02:41 AM
Pulled the Trigger MRT v2.0 :) 5thgencamaro11 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 41 05-27-2010 04:42 PM
ARH Longtubes,Trifecta Tune and MRT V2.0 Blade Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 36 05-01-2010 07:11 PM
MRT v1.0 vs. v2.0 JChen Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 8 03-07-2010 10:39 PM
Somewhat Annoying Back Seat Problem! ZNOLMT 5th Gen Camaro SS LS LT General Discussions 5 06-21-2009 10:22 AM
