Old 10-05-2011, 09:50 PM   #1
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
Plasti Dip.
Guys I Plasti Dip'd my Tail Light Bezels today and it feels and looks very grainy. Ive put about 5-6 coats on each bezel. is that enough or to much? also when I tilt the bezel on the right light I can still see some chrome on it.
What am I doing wrong? Is the results I got Normal? what do I need to do correct??
Thanks in advance!
Old 10-05-2011, 09:58 PM   #2
GEEo
OKCamaros
GEEo's Avatar
Anybody?
Old 10-05-2011, 10:22 PM   #3
Andys562
Andys562's Avatar
Drives: Black 2011 2LT RS
Did you clean the bezels before you applied the coats?
Andys562 is offline   Reply With Quote
Old 10-05-2011, 10:28 PM   #4
GEEo
OKCamaros
GEEo's Avatar
yup sprayed it with Adams All purpose cleaner and wiped it down dry.
I applied a coat every 20 mins.
I'll post up pics tommrw.
Old 10-05-2011, 11:22 PM   #5
TaylorRyanSS
COTW: 12/13/10
TaylorRyanSS's Avatar
Drives: 1969 Camaro
I did not do my bezels but I did my bumper blackout with plastidip. I only applied one thick coat and let it dry.
If I were you I would just paint them with adhesion promotor and black spray paint, thats what I did.
Old 10-05-2011, 11:23 PM   #6
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
you need to do really light coats.
Old 10-05-2011, 11:24 PM   #7
PoorMansCamaro
Drives: Really Slow
wow, really? i've plasti dipped my rims and tail light bezels, and used a bunch of thin coats. i was told that if you went too thick, it would cause bumps. heh, interesting.
Old 10-05-2011, 11:39 PM   #8
TaylorRyanSS
COTW: 12/13/10
Drives: 1969 Camaro
One thick coat, smooth and even.
Old 10-06-2011, 12:52 AM   #9
MikeGstayUp
MikeGstayUp's Avatar
Drives: 2013 SS in the future
I'd say that's 3 coats too many. Peel it off. Doesn't the can say wait an hour between coats?
MikeGstayUp is offline   Reply With Quote
Old 10-06-2011, 01:18 AM   #10
scythezo6
Virologist in the making
scythezo6's Avatar
Drives: 2010 VR SS/RS LS3
Don't spray too far away. The closer to the object the smoother the texture.
Old 10-06-2011, 06:29 AM   #11
zombi
zombi's Avatar
Drives: 2011 Black 6 Speed
Less coats, and hold the can closer. I just do two coats, one light, one thick.
:fighting0040:Injen CAI, MRT V.2, Doug Thorley Headers, Hurst SS, RX Catch Can with Breather, Heritage Grill, Matte black vinyl hood and trunk, Custom interior, Iggee seat covers
zombi is offline   Reply With Quote
Old 10-06-2011, 07:04 AM   #12
ZombieEatsYou
ZombieEatsYou's Avatar
Drives: "Bmblbee" 2010 RY 2SS/RS. VIN 12043
Originally Posted by GEEo View Post
Anybody?
8 minutes before your first and second message? Impatience may be your problem.
Seriously, I rotated the bezels as I applied each coat to avoid that coverage problem but still missed a small patch. But since you can only see it from about an 80 degree angle from 3 inches, I'm not sweating it. From an angle and distance normal people look at things I think they look great. I applied I think 3 light coats about 20 minutes apart. There's really no way, I think, to avoid some appearance of "grainyness," it's not paint but synthetic rubber so it's going to have the same texture as rubber-coated hand tools. I'll post some pics of mine if I can get around my workplace firewall.
ZombieEatsYou is offline   Reply With Quote
Old 10-06-2011, 07:38 AM   #13
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
I did two heavy even coats. I did notice one thing. I bought two cans of the stuff. I did three of the bezels using the one can and they came out with more of a glossy look. I did the last bezel with the other can and it came out much more textured, so I had to redo it with the other can. Maybe that is the problem. Take a look at my second picture. This is before I re-did the fourth bezel. See the lower right bezel. I don't know how well you can make it out, but the texture is much ruffer than the others in the pic.
newagemuscle is offline   Reply With Quote
Old 10-06-2011, 07:41 AM   #14
The Stig
knows 2 facts about ducks
The Stig's Avatar
You want to start with light coats, and then go heavier on the later coats. The further away you hold the can the more textured it will look/feel. You only want to wait 5 minutes or so between coats. I posted a thread called "plasti dip application tips" search for it. It'll answer pretty much all of your questions.
Click to view my build thread
how to plasti dip rims? TJ's MARO Wheels and Tires Talk Sponsored by The Tire Rack 23 07-17-2014 01:45 PM
Some thoughts on ideas about plasti dip CamaroC-17 Cosmetics and Lighting Modification Discussions 16 11-23-2011 06:41 PM
Lower Lip Plasti Dip Black out [HI RES PICS] SSdude Cosmetics and Lighting Modification Discussions 12 10-02-2011 07:59 PM
Plasti dip on a silver Camaro? RetroXI Cosmetics and Lighting Modification Discussions 7 08-29-2011 11:54 PM
Plasti Dip Injen CAI? zogster Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 11 08-23-2011 10:31 PM
