Let's go Rangers!
For all the V6 owners buying a lower grade octane, you are not saving much!
The octane question has come up so many times, should I use 87 over xx? I’ve posted the below calculation in a couple of treads but thought it should have it's own thread to highlight the actual savings of buy lower octane gas.
It’s a documented fact that when using a lower grade octane, the car pulls timing. It’s also a fact that higher octane gas tends to give better gas mileage, this is not just on the Camaro but all cars. I can also 100% say I felt a big difference the 2 weeks I tried to use 87 octane, it was very noticeable. Obviously I quickly switched back! Maybe you have a specific reason to use a lower grade octane and that’s great. But if you are doing if for monetary reasons (other then you just cannot afford it), I think you’d be surprised at what you are actually saving against the performance gains you will get using a better octane. Here is the breakdown: 15,000 miles a year (Based on the National Avg.) 20 MPG average (am I am going low here, the avg should be a bit higher) =750 gallons a year + .30 difference from 87 -> 93 octane 750*.30 = $225 a year ($204.54 a year if you calculate 2MPG higher for the better octane). So really, is your car not worth $225 a year more for better gas, especially when is DOES help the Camaro run and respond better! Last edited by nyrfan; 10-08-2011 at 12:44 PM. |
![]() Drives: 2010 2SS/RS Coupe Join Date: Feb 2011
I figured since I can afford to drive a car like this, I can afford to spend the few extra cents a gallon for premium.
2010 CGM 2SS/RS
love. my. car.
I thought the timing was only pulled for the V8 engines that require premium fuel??? And the V6's timing table is for 87 only?
![]() ![]() ![]() Drives: 2010 IBM Camaro SS Join Date: Jun 2007
The V6 should not be pulling timing since it is designed to use 87 octane. It will not benefit from higher octane gas either.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
#5 | |
Let's go Rangers!
Also, it was designed to use 87 or higher octane. Last edited by nyrfan; 10-07-2011 at 01:58 PM. |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Truck Join Date: Apr 2010
I drive my car less than 3k miles a year. I use 93. Why not?
#7 |
ace5.org
I think this is going to be a continued issue.
I don't see why timing would be pulled when the car was designed to run off 87. I think I'm going to run a tank of 93 through and see if I actually notice something.
Stock...For Now.
#8 |
For me it's whatever I can afford to put in it. I never used 87 only 89 but many have said that the car performs the same with 87 and there is no difference. So it's whatever.
#9 |
Do you have a link to where this has been 'documented' ? It doesnt make sense for a car to pull timing using the gas it is designed to use.
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 ZL1 - #670 Join Date: Jun 2009
Look in the manual ... If the vehicle has the 3.6L V6 engine (VIN Code V), use regular unleaded gasoline with a posted octane rating of 87 or higher. I've tried both and can't really notice a difference, so I just run 87 ...
#11 | |
The SS is rated for 91 or higher, it doesnt pull timing at 91 vs using 100. It only pulls timing if you go below its rated 91.
#12 | |
#13 |
Let's go Rangers!
Give it 2 tank fulls (if you don't mind), also be sure to track you MPG's.
#14 |
My Dream Car
Drives: 2011 SIM LS3 1SS Join Date: Jul 2009
yep only do 4-5k a year as its not my daily driver so i have always used premium for the most part
CAI intake/ADM Scoop/Stainless Power Headers/Dynatech cat back exhaust/Vitesse Throttle Control/ Ported Throttle Body/QTP Electric Cutouts/ 3.91 gears and janetty rear posi/ Tuned by Janetty racing
| OK...I'm starting a better V6 exhaust examples thread!! | KMPrenger | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 612 | 09-06-2024 09:00 AM |
| Why you should never let your wife take your ss | BIGSWOLE | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 54 | 05-07-2011 01:42 PM |
| V6 fuel switch 87 to a higher grade | gghg | 5th Gen Camaro SS LS LT General Discussions | 117 | 12-06-2010 06:52 PM |
| using higher octane on v6 | need4spd | 5th Gen Camaro SS LS LT General Discussions | 66 | 06-02-2010 03:24 PM |
| What kind of gas are you filling up with in your '10 Camaro? | JewelZ | 5th Gen Camaro SS LS LT General Discussions | 42 | 08-02-2009 10:31 AM |
