Old 10-15-2011, 07:58 PM   #1
ssmike
BL1ZZRD
ssmike's Avatar
Nitto Invo 315's on 10" wheel
Anyone have pics of Invo 315's on a 10" wheel? I'm considering the Nurburgring 9" and 10" wheels but want to go with Nitto Invos 275 front and 315 rears! I just want to know if there would be an issue with the 315's being buldgy on the 10" wheels. I read somewhere that the Invos come a little narrower than other 315's. Any help would be appreciated!
Old 10-15-2011, 08:14 PM   #2
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
I am doing it on my 10 inch wide wheels next week, tires on order...
MARINE1991 is offline   Reply With Quote
Old 10-15-2011, 08:15 PM   #3
ssmike
BL1ZZRD
ssmike's Avatar
Cool! Let me know how they fit and post pics if you can!
Old 10-15-2011, 08:17 PM   #4
MARINE1991
MARINE1991's Avatar
Don has it on his car... he loves them...
http://www.camaro5.com/forums/showthread.php?t=172146
Old 10-15-2011, 09:32 PM   #5
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
315 minimum safe recommended wheel width is typically 10.5 inches. Also, the Nurburgring has very aggressive offsets and anything wider than a 295 tire on that particular rear wheel will stick out past the fender lip.
Fquick.com/NineBall
Old 10-15-2011, 09:33 PM   #6
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
I honestly don't know why so many people insist on NOT following the manufacturer's recommendations. You are only causing unnecessary wear and damage to an already expensive tire. 10.5" minimum for this tire.
blazzin1 is offline   Reply With Quote
Old 10-15-2011, 09:40 PM   #7
ssmike
BL1ZZRD
ssmike's Avatar
That's exactly why I'm asking the question. I don't want to exceed specs! So to use 315's on the rear I need 10.5 or 11's correct?
Old 10-15-2011, 09:54 PM   #8
blazzin1
blazzin1's Avatar
Yes, the 315/35R20 Nitto Invo requires a 10.5" wheel minimum. But you may be able to find another 315 tire out there that will fit on a 10" wheel, it really depends on the manufacturer. But yes, generally, "most" manufacturer's do recommend at least a 10.5" wheel.
Old 10-16-2011, 11:35 AM   #9
BestWheelDeals
Drives: 2010 Camaro SS
Perhaps we can let the pics below talk for themselves...
Got my axis zero wheels from best wheel deals ....thanks to Bryan for the good service and cooperation !!!!
315/35/20 rear and 275/40/20 front.
We can make this happen with Nurburgring... Contact us when ready.
Camaro5 Vendors since 2010. Authorized Distributors: Stance | Rohana | Niche Wheels | XO Luxury | TSW | RSR | MRR | VS-Forged | Vertini | Ferrada | Ace Alloy | BC Forged | Forgestar | Foose | Continental | Michelin | Nitto | Mickey Thompson | Hankook and all major tire brands
Contact: Mike 954-205-3624 | mike@bestwheeldeals.com
BestWheelDeals is offline   Reply With Quote
Old 10-16-2011, 11:48 AM   #10
oldfriend
Drives: Fiat 500 E
Do you use that headrest just to cross the bridges and tunnels over there [last photo] so you can use the car pool lanes ,huh ?
Old 10-16-2011, 07:07 PM   #11
Nito
Nito's Avatar
Drives: 2016 1SS White MT
+1 295 is the route Im taking when my stock tires go.
Nito is offline   Reply With Quote
Old 10-18-2011, 07:37 PM   #12
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
I would agree. I have the Nurburgrings and with their offset I feel the 295 would work best... maybe a 305 depending on the brand. I think with that offset they will stick out if you do the 315.
newagemuscle is offline   Reply With Quote
Old 10-18-2011, 07:45 PM   #13
ssmike
BL1ZZRD
ssmike's Avatar
What tires did you use?
Old 10-19-2011, 09:35 AM   #14
newagemuscle
Philippians 4:13
I am currently running the stock tires. I have the 9 inch tsw up front and the 10 in the rear. I am using the stock tire set up. 245 up front and 275 out back. If I go with a nitto, I will probably do a 305 555r and more the 275 up front. If I go Nitto invos in spring I will probably find a 295 for the rear and maybe a 265 for up front. I'm not exactly sure what the invo sizes are. With the nurburg offset I would stay away froma 315... I dont car what people are doing on a 10 inch wheel. The nurburg offset is to aggressive especially if you want to lower. JUst my two cents.
Post pics: 315 Nitto Invo's on 10 inch wheel. newagemuscle Wheels and Tires Talk Sponsored by The Tire Rack 28 08-15-2012 12:24 AM
What size Nitto Drag Radial will fit stock wheel? HufferSS Dragstrip and Launch Techniques Discussion 12 06-10-2011 06:31 PM
Tires loosing pressure joepitt Wheels and Tires Talk Sponsored by The Tire Rack 22 12-11-2010 06:00 PM
Nitto Invo Tires (2) 315/35/20 + (2) 275/40/20 Only 500 miles Z71456 Local Marketplace 5 11-02-2010 12:46 PM
