Old 04-07-2009, 08:44 AM   #1
arozar
Drives: 2007 Tahoe
Black 21" wheels
I just talked to my dealer, and I guess that the 21" wheels are dealer install item, does this mean I come away with two sets(RS wheels and 21" black)? I hope so, also would it be up to me to re-program the cpu for the new wheel size? Thanks.
Past f-bods
1989 IROC (350/L89)
1995 Trans-AM M6
2001 Trans-Am WS6 M6
http://site.despair.com/governmentmotors/
arozar is offline   Reply With Quote
Old 04-07-2009, 08:48 AM   #2
Chevyrocker
Weekend Rockstar
Drives: Depends on the day...
The dealer will definitely handle the reprogram, and you should tell the dealer you want the old wheels. Otherwise you'll never see them again.
Chevyrocker is offline   Reply With Quote
Old 04-07-2009, 08:51 AM   #3
arozar
Drives: 2007 Tahoe
will do, thanks.
Past f-bods
1989 IROC (350/L89)
1995 Trans-AM M6
Old 04-07-2009, 08:52 AM   #4
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
This has been discussed already, but for your information, you're paying over $4k for that set of wheels and tires, so yes, you get to keep the old 20's. In addition, the rim/tire combo doesn't change the overall outside diameter of the tire, so you don't have to reprogram the computer at all.
Old 04-07-2009, 08:58 AM   #5
HOTRIDES1
Drives: 2006 CTS
Chevyrocker is correct...Take off wheels are yours for the asking....If you do not ask they will keep....Dealer is paid to re-program your 21's...On another note : Tires are unidirectional.....When you pick up you Camaro check the Pirreli's to make sure they say "OUTSIDE".
HOTRIDES1 is offline   Reply With Quote
Old 04-07-2009, 09:10 AM   #6
arozar
Drives: 2007 Tahoe
Thanks, I will make sure they give me the original wheels, and have the direction right.
Past f-bods
1989 IROC (350/L89)
1995 Trans-AM M6
Old 04-07-2009, 09:11 AM   #7
HOTRIDES1
Drives: 2006 CTS
WHEEL UPGRADE RE-PROGRAM
20's require no re-program...Other wheels do...See attachement for breakdown..
Old 04-07-2009, 09:13 AM   #8
Chevyrocker
Weekend Rockstar
But they do need to change your set up because the 21's with the lower profile will require a different PSI than the 20's and therefore require that the dealer updates your Driver Information Center via the tech 2 machine. And chances are there will be a small difference in diameter after the upgrade.
Old 04-07-2009, 09:33 AM   #9
CamaroSkooter
I guess. Does anyone know if there is a difference in recommended tire pressures between the 20's and the 21's?
Old 04-07-2009, 03:59 PM   #10
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Originally Posted by arozar View Post
will do, thanks.
Get that in writing. That's what I did.
Lighter wheels = much faster? 1_2Many Wheels and Tires Talk Sponsored by The Tire Rack 41 01-31-2011 12:28 AM
SEMA Camaro: Camaro BLACK Tran Camaro Photos | Spyshots | Video | Media Gallery 159 12-28-2010 06:27 PM
Ordering polished wheels Dakota Kid Camaro Price | Ordering | Tracking | Dealers Discussions 14 03-28-2009 12:08 AM
Couple of Questions Camaro Black, stripe/wheels Banshee Camaro Price | Ordering | Tracking | Dealers Discussions 3 02-08-2009 04:53 PM
Will the 20" Wheels from the LS7 Camaro at SEMA be offered as an accessory? HotRodPilot Wheels and Tires Talk Sponsored by The Tire Rack 20 02-08-2009 03:07 PM
