Rob
Drives: IBM 2012 1 LT Convertible/RS Join Date: Oct 2011
SS Fog lights
Ok Nub question. I recently purchased my 2010 SS Used and It came with no Manual. I have downloaded my manual and read most of it. However i still have one question.
I have the HID lights and I love them but why don’t I have an option to turn on or off my Fog lights or turn them on along with my normal lights? I see in the manual where you push the center button for Fog lights but My SS does not have that option. There is no push the only time my Fog's are on is when the Auto lights are on and it’s too light outside for the HID's to come on. So essentially the Fog lamps are only Daytime running lights? Is that the case or was mine Mod’ed somehow? |
TRI COUNTY TAMPA
Drives: 2011 1SS/RS VR/BLK A6 Join Date: Jan 2011
You dont have fogs. You have daytime running lights as you have the hid. The drls will come on automatically.
Let's go Rangers!
+1. And just to add, you have no control over the DRL's unless you add an aftermarket option/harness.
Rob
But what is the real diferance other than when they come on. are the FOG's pointed difrently? Has anyone added the option to controll them?
TRI COUNTY TAMPA
You can however rotate the dial to the right to manually turn on the halos and ahut off the drls. I do all the time.
#6 |
Rob
Yes but I also would like an option to have it all on, the Halos and drls on at the same time.
#7 |
TRI COUNTY TAMPA
You will need a special harness to do that i believe. Look in the diy section for options to do that.
#8 | |
Let's go Rangers!
Here is a link to the harness, contact the OP for buying options: http://camaro5.com/forums/showthread.php?t=170142 Here is a cheaper way to do it as well. People have done it this way with no issues, I pesonally don't like it becasue of the potential backfeed. http://camaro5.com/forums/showpost.p...67&postcount=2 |
#9 | |
Rob
#10 |
Smoked by a GIRL
This is one thing I dont like about the RS package. I have blackouts on my HID lights so on cloudy days the HIDs comd on auto so I either have to remove the covers, run w no lights or take a chance and burn a hole thru my covers. Sounds easy to remove the covers but its really a pain. May have to change the harness...
2014 2SS/RS Summit White w/ IOM interior "Powder 2.0"
#11 | |
Let's go Rangers!
http://www.headlightarmor.com/10-11-...ction-kit.aspx |
#12 | |
Smoked by a GIRL
#13 | |
Let's go Rangers!
On a side note, I did not notice you were referring to your headlights, I thought you were talking about your DRL's. I can certainly understand your heat concern with the HL. |
#14 |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
Theres also a thread around here somewhere with soldering the DRL's to the HL's I think so they come on when the halos are on or when the Headlights are on, its a super easy mod, and I think its the only way to get them to come on at night if u have the RS package
| Non-RS: Disable your DRL and auto turn on your fog lights with a p-n-p harness | caverman | Cosmetics and Lighting Modification Discussions | 37 | 09-16-2013 02:45 PM |
| Selling 2011 ss fog lights 55$ | dxy2jbaby | Exterior Parts & Accessories | 10 | 03-24-2011 11:10 PM |
| Non-RS: Disable your DRL and auto turn on your fog lights with a p-n-p harness | caverman | Cosmetics and Lighting Modification Discussions | 0 | 03-23-2011 06:15 PM |
| How do I get my Fog Lights to act as my Day time Running Lights??? | Camaro Freak | 5th Gen Camaro SS LS LT General Discussions | 8 | 10-12-2010 05:16 PM |
| Anyone installed the BFXenon Fog Lights or their HID upgrade for headlights? | bferrell99 | Cosmetics and Lighting Modification Discussions | 8 | 04-29-2010 10:53 PM |
