Old 10-28-2011, 05:13 PM   #1
Flashpoint135
Flashpoint135's Avatar
Drives: 2016 SS
TPMS relearn tool
Has anyone actually used a TPMS relearn tool, where did you get it and how much was it?
I've searched this site and the internet. I know the older cars you could "relearn" by dropping tire pressures, but that does not work on the newer cars. I know there is supposed to be a GM tool for $40 - $60 for this, sometimes called out by part # EL-50448, but that part doesn't seem to exist within GM. If you search online it will show an aftermarket tool, but I want to know if anyone has actually used one successfully. The dealer claims there isn't anything they can sell me, obviously they have their own tools to do it, but they are expensive and not GM products.
I know the dealer will do it for me for free, but I'd like to at least be able to change my tires myself without a trip to the dealer - even just for the 2 minutes to reset TPMS.
SO - have any of you done it with a tool and not the tire pressure method?
Flashpoint135 is offline   Reply With Quote
Old 10-28-2011, 05:26 PM   #2
Dogditcher
Dogditcher's Avatar
Drives: 2011-1LT RS COUPE
You have to phone in the order
https://gmspecialservicetools.spx.co...s.aspx?id=5677
Dogditcher is offline   Reply With Quote
Old 10-28-2011, 05:30 PM   #3
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
Don't the 2011's have the same "re-sync" procedure in the Owner's Manual as my 2010? Or is it something else you're trying to do here? I guess I'm not understanding. I installed new aftermarket sensors in my wheels and just did the re-sync procedure in the manual, and everything works fine. I didn't need any big fancy electronic gizmo!
blazzin1 is offline   Reply With Quote
Old 10-28-2011, 05:36 PM   #4
Flashpoint135
Drives: 2016 SS
Nope - our manuals have changed. You can look at the 2011 manual on the chevrolet site under the "owners" tab. That part has been changed, and others here have tried the old method - on earlier 2011 cars it worked but not later models. The new re-sync or re-learn process says you must have the tool, but it also says you can get it from the dealer (which I can't).
Old 10-28-2011, 05:37 PM   #5
Flashpoint135
Drives: 2016 SS
Originally Posted by Dogditcher View Post
Thanks - have you used this?
Old 10-28-2011, 05:45 PM   #6
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Have you tried the tire pressure method?
Why the hell would they change that?
I didn't know they did. Kinda stupid if you ask me...........
Old 10-28-2011, 06:08 PM   #7
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
i have that same tool at work and it works fine.
Old 10-28-2011, 07:31 PM   #8
Flashpoint135
Drives: 2016 SS
Thanks - exactly what I wanted to hear -I'll buy one.
Old 10-28-2011, 08:09 PM   #9
Dogditcher
Dogditcher's Avatar
Switching to winter wheels this weekend
will know if it works then
Like others have said early 2011's old method works
my car was built in May and manual states relearn tool needed
Old 10-28-2011, 08:20 PM   #10
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
Amen! Just saw this post...Can't believe you need a tool to do this. Why would they change it? On my 2010 LT I did the manual re-learn and never failed me through two winters (so 4 tire changes in 2 years).
Guess I'll have an error message after the winters go on tomorrow...
1968 Camaro Convertible LS1, T56
ckaram is offline   Reply With Quote
Old 10-28-2011, 08:36 PM   #11
Flashpoint135
Drives: 2016 SS
My only guesses as to why they would change this:
1) Maybe some corporate lawyer thought there might be some liability from someone running through the reduce pressure process a couple times and then running on soft tires.
2) Somebody decided that some component of the system would be cheaper without this functionality and suggested they would save Y cents times Z units.
At first I thought maybe they just decided to stop publishing the pressure method, but I've seen enough posts and other online comments to believe they did actually change something sometime in 2011. Several people with later 2011's have said they tried and it doesn't work at all. Others in the middle have said the manual didn't show the pressure method but it did work. No info anywhere from GM on the subject (other than the Manuals).
Old 10-28-2011, 08:46 PM   #12
PQ
Booooosted.
PQ's Avatar
Interesting.
I didn't know they changed it. I like it better the old way.
Old 10-28-2011, 10:18 PM   #13
Rogan
No Pain No Gain
Rogan's Avatar
Drives: Yellow 5th Gen 2SS RS
I'm lost - the TPMS is to monitor pressure in your tires? If so can't you just hit the reset button to relearn? I had mind come on yesterday and I saw the option to hit reset to relearn. Worked fine.
2010 2SS/RS/L99 - Headers/CAI/SWAYs/CoilOvers/Tune/Steel Braided Brake Lines/Frozen Slotted Rotors
Rogan is offline   Reply With Quote
Old 10-28-2011, 11:00 PM   #14
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
I think the TPMS relearn tool is not needed.
I have two sets of wheels with TPMS and when I swap them out, they seem to automatically relearn each set of TPMS's. Has anyone else experienced this?
Otherwise, it's no problem to air down your tires a bit to do the manual relearn. It only takes a bit of muscle to pump the tires back up with a bicycle pump.
Besides, I find our TPMS's way off in terms of accuracy.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
gm tpms reset tools cheap camaro1 Wheels and Tires Talk Sponsored by The Tire Rack 13 11-24-2017 03:32 PM
2011 SS Tire relearn TPMS JKEP44 5th Gen Camaro SS LS LT General Discussions 34 05-18-2011 08:32 PM
Cant get my SS to relearn TPMS Sensors Jeanius Wheels and Tires Talk Sponsored by The Tire Rack 82 03-20-2011 09:24 PM
