Old 10-29-2011, 04:12 PM   #1
Raptor626
Drives: 2011 Camaro SS Summit White
Question Replacing the trunk weather stripping channel
My friend and I were moving some hardware to his house and one of the things we had to move was a 100lbs. lo-pro floor jack. I'm not the strongest of people so I asked for his help in getting the jack into the trunk. So, as we're lifting the jack into the trunk my friend accidentally lets one of the jack's wheels nip the edge of the trunk weather stripping channel/frame/whatever you want to call it. I subsequently removed the weather stripping to check for a dent, but thankfully it would appear as though I got lucky. I even posted a picture of the area in question so you guys can see what I'm talking about.
****NOTE: I DID NOT ACTUALLY SUFFER DAMAGE. I'M JUST POSING A QUESTION.****
This, however, got me thinking. If any such damage occurred to the channel, how would you go about replacing it? I've seen on some sites that a person will either use new materials to mimic its shape, or cut off the required area from a donor car. Can you do this for these cars? Thanks. Btw, here's my trunk with the stripping removed so you can see what I'm talking about:
Raptor626 is offline   Reply With Quote
Old 10-29-2011, 08:36 PM   #2
Raptor626
Bump.
Old 10-30-2011, 11:56 PM   #3
Raptor626
Old 10-31-2011, 12:15 AM   #4
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
If it were dented it could easily be straightened to the correct shape. Simply remove the rear fascia to gain the best access to both sides and heat / hammer back to shape. Crushed in from a collision would require more work but still could easily have a new section put in place.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 10-31-2011, 12:19 AM   #5
Raptor626
THANK YOU!! God sometimes it's so hard to get some attention around here! lol
Old 10-31-2011, 12:36 AM   #6
ffrcobra_65
next time, put "mustang" or Camaro V6 vs. SS in the title and you will get 100 instant replies.
channel, damage, repair, trunk, weatherstripping
Replacing the trunk light? DevilKnightFalcon Camaro DIY & HOW-TO instructions & discussions 8 04-03-2011 04:06 PM
Can't get into my trunk... KenH Canada 15 02-16-2011 02:14 AM
Any hints on how to remove nuts from inside trunk lid? OHIOSS 5th Gen Camaro SS LS LT General Discussions 25 06-09-2010 11:49 PM
Replacing hood or trunk shock rods chrislhardin 5th Gen Camaro SS LS LT General Discussions 1 05-07-2010 03:55 PM
Carbon Fiber Cowl Hood, Trunk, and more! PHASTEK Peformance Sean@Phastek Exterior Parts & Accessories 3 01-29-2010 03:44 PM
