![]() Drives: 2011 Black 2LT RS Join Date: Oct 2011
Temp or gas
I got my Maro in August, 100+ degrees. The car was fast but wouldnt spin the wheels. Oh yeah, its the Auto V6. This past week the temp changed and we are now in the 60's and 70's during the day. I can now smash it and actually spin the tires, not only spin 'em but the car even skids sideways! I have ran 87 in it until the last fill up when I switched to 91. What has helped the most, gas or temp, or is it both?
![]() Drives: 2010 2SS and 2011 LS Join Date: Aug 2011
Both
Around here we like baseball, hot dogs, apple pie, and Chevrolet
086YN
Drives: Black 2SS/RS Demon of Madness Join Date: Aug 2011
Just a warning you are going to get flamed for referring to your Camaro as your Maro....
There really is no gain in performance from switching fuel with the V-6 it is a waste of money for you. It was probably the temps. Tires like the P-Zeros are not as grippy in cold weather and they need the heat to stick. Tire pressure also can change the way your tires grip. For you to use higher octane fuel you need to start modding your engine to the point where you need to use high octane fuel, but if your car is stock just save the money with regular. |
![]() ![]() ![]() ![]() Drives: 2010 camaro 2SS LS3 Join Date: Aug 2011
And the air is denser at colder temperatures adding a noticable power increase
well then, no more Maro, back to cheap gas and need to move back home (Ohio)!
| Tags |
| gas, power, temp, torque |
| Diagnostic Trouble Codes (DTCs) for OBD II equipped GM vehicles | steeleshark2 | Tuning / Diagnostics -- engine and transmission | 11 | 04-08-2020 10:49 PM |
| CEL - P1682 | PSU SS | Tuning / Diagnostics -- engine and transmission | 4 | 09-29-2011 07:27 PM |
| Bad gas! Camaro sputtered & died | gzartman | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 8 | 09-07-2010 05:45 PM |
| using higher octane on v6 | need4spd | 5th Gen Camaro SS LS LT General Discussions | 66 | 06-02-2010 02:24 PM |
| Fuel pump or bad tank of gas? | Boomer Sooner | 4th Generation Camaros | 25 | 01-02-2009 06:34 PM |
