Old 11-07-2011, 06:35 PM   #1
cam fan
cam fan's Avatar
Drives: fast
Exclamation do i just pull out the nail?
Found this tiny nail in my tire. Do I just pull it out or would i need to plug it too?
cam fan is offline   Reply With Quote
Old 11-07-2011, 06:36 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
You need to pull it out and plug it
Click to view my build thread
Old 11-07-2011, 06:36 PM   #3
when in doubt pull it out
Old 11-07-2011, 06:37 PM   #4
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
It only took two posts to go there...
My VIN = 2G1FK1EJ9A9105017
Old 11-07-2011, 06:38 PM   #5
Jrichards73
Jrichards73's Avatar
Drives: 2011 2SS/RS Victory Red
may just be a short tack and not do all the way in, just stuck in the tread block. Don't know till you yank it out.
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB.
Jrichards73 is offline   Reply With Quote
Old 11-07-2011, 06:41 PM   #6
EMB135Driver
Jedi Master
EMB135Driver's Avatar
Drives: Boeing 757/767+2010 IBM 2SS
I think I'd pull it out in the parking lot of a tire shop.....spray some water on it and check for leaks before driving away. It might not have pierced the tire and just got stuck in the rubber.
EMB135Driver is offline   Reply With Quote
Old 11-07-2011, 06:48 PM   #7
cam fan
cam fan's Avatar
Drives: fast
im not ready to be a father
on a serious note, i will wait to get to a tire shop (but its probably a tack considering the head is so small)
Old 11-07-2011, 06:50 PM   #8
Sevn86
Sevn86's Avatar
3100 Sequenced:10/12/09
3400 Broadcast:10/22/09
3800 Produced:10/27/09
4200 Shipped:10/29/09
Old 11-07-2011, 06:51 PM   #9
EricSS
EricSS's Avatar
Drives: 2010 Camaro 2SS LS3 M6
Discount Tire will pull it out for free and even plug your hole.
__________________________
2010 2SS LS3 M6
Inferno Orange Metallic / Black
EricSS is offline   Reply With Quote
Old 11-07-2011, 06:59 PM   #10
insidethreat07
insidethreat07's Avatar
Drives: 2001 Camaro 3.8
or you you have plug kit just pull it out at home and plug your hole if it went deep enough
2001 Camaro V6
2016 Camaro 2SS
insidethreat07 is offline   Reply With Quote
Old 11-07-2011, 07:19 PM   #11
IBM
IBM's Avatar
Drives: '11 2LT/RS IBM
Check your DIC after you take the it out, then plug the hole.
IBM is offline   Reply With Quote
Old 11-07-2011, 07:34 PM   #12
cam fan
cam fan's Avatar
Drives: fast
truth be told my DIC stopped working a few days before I noticed this
Old 11-07-2011, 07:36 PM   #13
IBM
IBM's Avatar
You better get your DIC checked out then.
Old 11-07-2011, 07:39 PM   #14
Drew10
Enjoys a good train wreck
Drew10's Avatar
Drives: 2010 IBM Camaro 2SS/RS
Pull and pray......that it didn't cause a leak. Do it in a tire shops parking lot.
Drew10 is offline   Reply With Quote
Fuse Pull: Low Octane Fuel Fix For L99 and LS3. Reset Fuel Map for High Octane Fuel. radz28 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2838 05-12-2024 12:42 AM
Lone Star Camaro Club Discussions (DFW) Camaro21 USA - Texas 576 03-31-2017 06:08 PM
Fuse Pull Still Needed? raider8654 5th Gen Camaro SS LS LT General Discussions 15 12-20-2010 02:34 PM
Stock baseline pull vs. Cammed pull dyno graph Huggerorange73 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 09-13-2010 10:11 AM
Fuse pull? Rage 5th Gen Camaro SS LS LT General Discussions 22 06-06-2010 02:08 AM
