Banned
Iconel valves
what are the advantages of iconel valves, their cost etc.... Its something I been thinking of doing for my heads
LVL 50 Troll Stomper
Drives: 2010 Camaro Join Date: Feb 2008
Inconel valves are typically used for high heat applications- so think the exhaust side of a turbo setup...
Banned
ok i have a turbo so this means a lot to me.... also since we are on the topic...it is a good thing to get the ferrea gun drilled valves...or better to stay with a stainless or iconel for a street star that wont hit super high rpms that much. Do I really need these, or they even worth the extra money.
![]() ![]() ![]() Drives: 2010 M6 2SS Join Date: Mar 2011
How much power are you going for and with what displacement engine?
In my other car, which is a 370" iron block Gen 3 engine...with some EXTREMELY high power goals from the turbo setup, I'm running a stainless intake valve and an inconel exhaust valve.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension |
Banned
looking at 1000 rwhp down the road...about16 to 17 psi on 93 octane.
#6 |
...well...if you're going for that kind of power, you WILL need a built engine below the heads...if you want to do the heads now and the bottom end later, don't cheap out now.
#7 |
![]() Drives: Camaro 2010 SS LS7 427ci Join Date: Nov 2009
Inconel metal is best best alloy for high heat, also very expensive compared to stainless steel. If you are running high octane or racing fuel that burings bery hot you can benefit from inconel. You wont make any horsepower with inconel valves
| ls3 valves breaking becoming an issue? | 2010 SS RS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 40 | 12-29-2012 11:09 PM |
| LS3 valves | blake-b | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 3 | 10-12-2011 12:53 PM |
| Dropped valves ? | 2012 ZL1 | 5th Gen Camaro SS LS LT General Discussions | 14 | 02-25-2011 03:22 PM |
| Piston to Valve Clearance? | My First Camaro! | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 3 | 08-18-2009 08:26 PM |
| Exhausts valves on the V6? | TJ91 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 19 | 04-14-2009 08:32 PM |
