![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS RS L99 Join Date: Jan 2011
Question on battery disconnect for storage
Putting my car up for winter this weekend
+ & -, should I disconnect one or the other or both?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
Just get a battery tender and hock it up. It will keep the battery charged. Disconnecting the battery won't keep it charged.
I rent a storage unit for winter storage so I won't be able to keep a trickle charger on it. I'm not concerned with keeping it charged, I'm just not sure if leaving it hooked up for 4-5 mos will drain any significant amount of juice. It won't be started at all. I've heard of people disconnecting the neg & some doing both.
![]() Drives: 1969 Camaro 2018 ZL1 Join Date: Aug 2011
There is parasitic drain which will discharge the battery over the course of 4 months. Disconnect the negative.
Cool, thanks!
#6 |
Drives: 2011 1SS M6 Green 1993 Custom Eldo Join Date: Jul 2011
Or pull the battery take it home and put it on a tender.
#7 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
Get a trickle charger that way it'll stay up and be ready when you're ready to start back up in spring.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS/RS - 2004 Silverado Join Date: Mar 2010
I believe the owner's manual says to disconnet the negative if the car will be stored for more than a month.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80 2004 Black Silverado 1500 2WD Regular Cab, Short Bed -5.3 LM7, 4L60E, 3.42, G80 2014 White Caprice PPV -6.0 L77, 6L80E, 2.92, G80 |
#9 |
![]() Drives: 2017 Camaro SS Join Date: Oct 2009
Take the battery out and put on a charger. A discharged battery will freeze. A frozen battery will leak acid and cause damage. Five months is a long time.
#10 |
376 cubic inches of fun
#11 |
![]() Drives: Red 1SS Join Date: Oct 2010
Take the battery home!
Kooks LT Headers/catback exhaust, E-force supercharger, JRE fuel line upgrade, JRE differential, 3.91 LPE gears, Roto-fab intake, JRE tune, DSS Carbon Fiber driveshaft, MGW shifter, Hotchkis chassis braces |
#12 |
#13 |
If and when you take off the negative terminal, then put on a "battery disconnect" device that has a green knob and you turn the knob to disconnect the circuit in the future....when my car sits longer than a month I disconnect it, and for the winter I put on a battery tender type product plugged in...good luck
#14 |
![]() Drives: 2011 Red Jewel 2SS RS Join Date: Mar 2011
I will be storing in a climate controlled storage 55*...should I just disconnect the neg terminal then?
![]() 2011 Camaro 2SS RS Black Stripes w/graphics Heritage Grille Splash guards Embroidered headrests Show and go license plate bracket Gill Decals |
| Ginger gets a Braille light weight race battery! | SUX2BU | 5th Gen Camaro SS LS LT General Discussions | 85 | 02-18-2025 02:27 PM |
| Battery Disconnect For Cold Air Induction ? | Tony's Jewel | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 8 | 07-17-2011 01:01 PM |
| Regarding battery location | route66dan | 5th Gen Camaro SS LS LT General Discussions | 4 | 09-14-2010 10:29 AM |
| Battery question | armando416 | 5th Gen Camaro SS LS LT General Discussions | 2 | 01-02-2010 08:06 PM |
| LS3: fuse pull or battery disconnect?? | g-townmach | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 9 | 12-28-2009 09:31 PM |
