Old 11-13-2011, 07:19 AM   #1
pears2
Drives: 2011 Black/Silver Synergy Series
Am I required to re-program the ECM?
I'm thinking of installing a CAI system and a cat-back Flowmaster exhaust on my 2011 2SS M6, do I need to have the ECM re-programmed? I have been told the ECM will adjust itself for the increased air flow as I drive the car. Others have told me, I have to purchase a reprogrammer because the engine will run lean it I do not adjust the ECM. Anyone know for sure?
Thanks
pears2 is offline   Reply With Quote
Old 11-13-2011, 07:20 AM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
No. The ECM will adjust for the CAI
Click to view my build thread
Old 11-13-2011, 09:24 AM   #3
caverman
caverman's Avatar
Drives: '69 SS Convertible
Stieger is right. The computer can make enough of an adjustment to handle the intake and exchaust.
Build Journal
Old 11-14-2011, 05:56 PM   #4
Juiced1
Drives: 2012 2SS CAMARO 45th
Don't worry about a tune until you start in on headers or some internal mods. Intake and exhaust won't effect the tune much.
Juiced1 is offline   Reply With Quote
Old 11-14-2011, 06:29 PM   #5
DROPIMP
Drives: 2010 SS Camaro
Sorry guys but, if the ECM adapts to the CAI, why do they sell "No tune" CAIs??
DROPIMP is offline   Reply With Quote
Old 11-14-2011, 06:38 PM   #6
Ratt
Drives: 2ss
Hes right, if you buy a cold air intake that doesn't add any HP then you probably wont need a tune. If you buy a good one you will need to tune the car.
Don't tune the car until your done adding all the bolt on mods you want.
Don't waste money buying a programmer, take your car to a Pro and have it tuned
Ratt is offline   Reply With Quote
Old 11-14-2011, 06:40 PM   #7
leviticus88
Camaro Owner Soon!
Drives: Chevrolet Cobalt SS/SC S2 GMPP
I would tune the car.
leviticus88 is offline   Reply With Quote
Old 11-14-2011, 07:00 PM   #8
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
Because a select few intakes actually do require a tune. 95% of the intakes for the 5th gen do not. Yes you do gain a little HP even without a tune as the ECM can and will adjust for the added airflow. Vararam sells both versions and anyone here will agree they both make HP.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 11-14-2011, 07:14 PM   #9
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
An intake doesn't have to require a tune to be "good". In fact the good intakes don't generally require tuning as the manufacture spent the time engineering it correctly to work with the MAF and maintained good fuel trims..
You can always pick up more HP with a tune and remove the torque management which really wakes them up but the CAI or Flowmaster will not require tuning. I also agree with taking it to a good local tuner when that time comes.
Kind regards,
Jordan Priestley
888.308.6007
JDP Motorsports is offline   Reply With Quote
Old 11-14-2011, 07:17 PM   #10
The Stig
The Stig's Avatar
The only CAI that I know of that specifically states "no tune" is the Vararam, and that is because there is a "tuned" version and a "no tune" version.
Check out the Jannetty CAI test thread. All of the intakes they tested were "no tune" and they showed gains.
While tuning the car does free up a lot of power, it is not necessary with just a CAI and exhaust.
Old 11-14-2011, 08:29 PM   #11
Parag
Drives: 2010 camaro 2SS LS3
you get more power out of the part with a tune, but an improvement will still be seen. if you put on a CAI on a stock car you will see 10 hp. but if you tune with CAI you will see more like 20 hp. the car will run just fine without a tune, but you are losing some of the benefit you paid for.
http://www.camaro5.com/forums/showth...ndent+CAI+test
Parag is offline   Reply With Quote
Old 11-14-2011, 08:42 PM   #12
The Stig
The Stig's Avatar
20 rwhp is kind of stretching it, but yes you CAN get more out of a CAI with a tune but it is not needed.
Old 11-16-2011, 05:25 AM   #13
Ratt
Drives: 2ss
The OP’s question was “am I required to re-program the ECM?” The answer to that is no.
Many of us started out where you are or at the other end at an Axle back or Cat back add on. You won’t stop at the air intake trust me. Once you get the air intake and if it’s a good one, you will like the added power. You will want more, so it’s on to headers and cat back and so on. A tune is ties them all together and makes them operate at maximum efficiency.
A warranty is to protect you from what MIGHT happen, never let what MIGHT happen get in the way of what you WANT to happen.
Old 11-16-2011, 08:21 AM   #14
JANNETTYRACING
JANNETTYRACING's Avatar
Correct, But in the CAI Test spread sheet I Make recommendations for tuning required, or not.
So the question is open ended without knowing What CAI the OP is Referring to.
And There is a lot more to the tunes then adjusting for the CAI.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
VARARAM | 2010+ 6.2L V8 Camaro Ram Air Intake - Tune & No Tune Required Systems! AutoAgenda V8 Bolt-Ons & Tunes 29 03-12-2013 06:51 PM
Pfadt Race Engineering announces 2011 NASA Contingency Program PfadtRacing Dragstrip and Launch Techniques Discussion 0 05-04-2011 11:08 AM
Camaro Performers 5th Gen Camaro Challenge rules + link to contingency program nmcajeff Dragstrip and Launch Techniques Discussion 0 01-21-2011 10:04 AM
New Vehicle Warranty Commitment Program CamaroScotty Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 07-24-2009 06:11 AM
