Old 11-24-2011, 12:50 PM   #1
SSTG
Drives: 2014 Z51 Corvette
LS3 and L99 Exhaust compatible?
Did a search with those keywords and nothing came up, so before anyone flames me.
Will one work on the other? Are they the same?
Thanks and Happy Thanksgiving!
SSTG is offline   Reply With Quote
Old 11-24-2011, 12:53 PM   #2
Nucorman
nucorman
Drives: 2011 Camaro SS
Yes.
Nucorman is offline   Reply With Quote
Old 11-24-2011, 01:03 PM   #3
VADR_H8R
VADR_H8R's Avatar
Drives: 2011 camaro 1ss synergy green
I could have sworn the L99 exhaust was completely different.
VADR_H8R is offline   Reply With Quote
Old 11-24-2011, 01:05 PM   #4
SSTG
That is what I thought I remembered reading once upon a time. But....
Someone will confirm
Old 11-24-2011, 01:12 PM   #5
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
The stock exhaust systems are different but follow the same "path". Aftermarket systems generally fit both unless otherwise noted. What systems are you looking at?
Old 11-24-2011, 01:15 PM   #6
SSTG
Thanks Chase. I sold The Borla ATAK Axel back I got from you and need to replace them.
Got any Black Friday deals on Flowmaster catback for GFX?
Old 11-24-2011, 01:42 PM   #7
VADR_H8R
VADR_H8R's Avatar
here is the pic I was referring to... but if your wanting to go the aftermarket route I do think they will work on either engine because their paths are indeed similar
Old 11-24-2011, 02:18 PM   #8
SSTG
No, I am talking about stock. But I am not against an aftermarket system.
Old 11-24-2011, 02:38 PM   #9
Synner
Drives: cars
The resonator on the L99 exhaust is massive to deal with the AFM noise. Both should fit though although I see no point in replacing one with the other if you're looking for sound or weight savings. You can get a budget exhaust like cherry bomb or something along those lines for not much money.
Old 11-24-2011, 03:42 PM   #10
MikeOD
Drives: 2010 M6 2SS
Yes, the stock catback exhausts ARE interchangeable...No they are not the same. The LS3 exhaust is a pretty conventional exhaust because it's a pretty conventional V8...the L99 exhaust has a different setup in it to avoid having the car sound "weird" when AFM is on.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 11-24-2011, 03:51 PM   #11
L99CAMA2011
L99CAMA2011's Avatar
L99 has a resonated x pipe setup and LS3 has an H pipe. I had both on my L99 and they perform different as well. You can feel the delay in flow with the stock H pipe on an L99 vs the L99 resonated x pipe setup. Don't put H pipes on L99s.
Old 01-21-2019, 11:50 PM   #12
jlsat3
Drives: 2013 Camaro
What if you turn off your AFM?
jlsat3 is offline   Reply With Quote
Old 01-25-2019, 06:58 PM   #13
oslouie
oslouie's Avatar
Drives: 2018 2SS M6 Redline
I think you would be fine. Again, the only difference is the resonator on the L99 when AFM kicks in. If you turn AFM off then I don't see why you would have to worry about having the resonator.
oslouie is offline   Reply With Quote
V8 Camaro Aftermarket Exhaust Video Clips Compilation tjbusa Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 591 07-06-2022 08:38 AM
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 10:40 AM
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 12:26 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 01:00 PM
