![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: cars Join Date: May 2011
Corroded header bolts
Anyone else have this issue? My car has 2k miles on it. I went to put headers on it today and they fought me the entire way; every bolt was covered in corrosion and the threads on about half of them looked like crap. I'm debating if I want to chase them all with a tap and clean them out while I wait for new bolts. I thought the bolts were going to break it took so much force to get them out. I finally went and bought an air ratchet because my arms and wrists couldn't take it anymore. And then one of the headers had a cross threaded 02 port so I needed to order a tap and die for that since my kit only goes to 12mm.
Going to look tomorrow locally but will probably have to buy the bolts online somewhere. What a crappy day. |
![]() Drives: Camaro 2010 SS LS7 427ci Join Date: Nov 2009
Use Never seize , the bolts are high carbon steel in an aluminum head.
I plan on it for the replacements but these things were wrecked coming out. At this rate I never would have gotten them out if I had waited until 10k miles to do headers. It just seems odd how bad they were in this short of a time, dissimilar metals or not.
![]() Drives: 2010 2SS Join Date: Apr 2010
I had a tough time with mine. They had some sort of thread locker on the theads. I brushed the threads off and reused them.
![]() ![]() Drives: 700 rwhp 2010 SS Join Date: Sep 2010
Thats not corrision on them, its a form of loc-tite to prevent them from backing out. Im a GM technician and have never ever seen corrosion on the threads of the bolts. The loctite works great especially when you have to put new manifolds on a 6.0L suburban with 120k miles on it then its time to start drilling!
#6 | |
Blown Cool Breeze
Drives: 2011 Black on Black 2SS M6 Join Date: Jul 2010
+ one....clean the locktite off the threads. Clean the rust off the bolt heads, but not too much to remove the black the oxide finish. Punch holes in a cardboard box with a screw driver. Insert header bolts in holes and spray with engine clear coat. Apply a bit of anti-seize and re-install. Say good bye to rusty factory header bolts
Had a 2010 IBM 2SS M6 Enjoy life.Think of all the women on the Titanic who passed up dessert. |
#7 |
I've never seen a green/yellow loctite before but if thats what it is...
Although it still doesn't explain why the threads were jacked up on about half of them. I still plan on getting new ones because of how the threads looked and will cover them with anti-seize. |
#8 | |
knows 2 facts about ducks
#9 |
![]() ![]() ![]() ![]() Drives: 2016 2SS Join Date: Nov 2011
Blue Loc Tite works pretty good.
Who Dares...Wins |
#10 |
Drives: 2012 ZL1 & 2010 2SS/RS Join Date: Jul 2009
I am guessing you mean the stock bolts..yes they will rust because they are plain steal. Most new headers should come with stainless hardware.
#11 | |
Here's stainless hex head for cheap in case anyone else needs some. The standard ones jegs sells are allen head which I would never use on something like this due to torque requirements and risk of damage on the rear bolts. I think you'd have to pull the motor if one got stripped. http://www.jegs.com/i/Gardner-Westco...6-HSP/10002/-1 |
#12 |
Drives: 2010 CGM Camaro 2SS/RS 429 LSX/F1X Join Date: Aug 2011
Thats odd they gave you such a headache. The loc-tite stuff they use does make it harder, but on all the headers we've done, they usually come out without too much effort. Slow going of course, but they haven't ruined any threads.
It probably would be a good idea to chase the threads, just in case, plus would clean out some more of the loc-tite. If one is screwed up, you don't want to ruin it even more by trying to send a new bolt in it. Make sure when you install the headers, use anti-sieze on the bolts. If you think its bad taking the original bolts out, just wait; if you use more loc-tite and take them out later, it often does havoc on the threads... |
#13 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
Loctite's Threadlocker Blue 242 instructions state: for removal of bolt's between 1/4 & 3/4 use standard hand tools and apply heat if the bolts are hard to remove. Operating temp is between -65F to 300F. Heat to 482F to aid in removal.
I'm not sure of the temp in this area. But if it is high enough, I would think the threadlocker may not have much affect. Although it may prevent galling. http://www.loctiteproducts.com/p/t_l...r-Blue-242.htm Could GM have used a high temp threadlocker? I plan on installing headers in the spring and would like to know what is the best product to use? Threadlocker or anti-seize.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
#14 |
![]() ![]() ![]() Drives: 2010 M6 2SS Join Date: Mar 2011
Mine came right out...were you supporting the exhaust from below, or just letting it hang from the bolts as you loosened them?
I would be VERY cautious using a cutting tap to chase those threads in the heads...use a thread chaser, but not a cutting tap...not free hand, crooked, in an engine bay, in cast aluminum. I put my car back together with stainless ARP studs with 12 point nuts...makes it so convenient to line up the gaskets and headers, and you have any angle you can think of with the box end of a 12 point wrench...over 10K miles now, no leaks, no nuts loosening...no problems, just a happy Kooks/ARP customer.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension |
| DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) | robertway | Camaro DIY & HOW-TO instructions & discussions | 313 | 12-16-2023 07:53 PM |
| Stainless header bolts | sschevybear11 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 1 | 10-29-2011 09:15 AM |
| Thread Sealer or Anti-Sieze on Header Bolts? | BowlingSS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 7 | 07-30-2011 10:48 PM |
| header bolts | buelldude | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 10 | 12-30-2010 11:38 PM |
| Anyone had to RE-Torque header bolts? | Jeanius | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 10 | 03-24-2010 11:00 PM |
