Old 11-30-2011, 05:49 AM   #1
melvinakshay
Vrooom Vrooom
Drives: Camaro 2011 black LS
do I need speedo calibration for going 20 inch ?
Ive got an LS with stock 18 inch, I just upgraded the wheels to 20 inch (20*9 and 275/40/20 all round).
The car does handle a lot better and I definitely feel the difference. Do I need any kind of speedometer calibration ? I think my speedo might be a bit off. The reason is now the gears feel taller. What I mean by that is earlier 40mph would be something like 4k rpm @ 3rd. Now 40 is barely 2-2.5k rpm @ 3rd. had to get used to the sudden change. I kinda change gears based on the sound though.
melvinakshay is offline   Reply With Quote
Old 11-30-2011, 05:56 AM   #2
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
No change needed... the diameter of the tires is the same. Not sure why you seem to be noticing a difference.
Sterling is offline   Reply With Quote
Old 11-30-2011, 06:22 AM   #3
formare
The Milano
formare's Avatar
Drives: 2017 Firefly ShipWorks
Is 275 40 20 the factory tire height?
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 11-30-2011, 06:45 AM   #4
n116ebo
n116
n116ebo's Avatar
Drives: 2010 2SS YELLOW TRANSFORMER AUTO
If you have any doubts about the correct speed take your GPS and go for a cruise and see if speedo and GPS match.
n116ebo is offline   Reply With Quote
Old 11-30-2011, 06:46 AM   #5
The Stig
knows 2 facts about ducks
The Stig's Avatar
For the rears yes
Click to view my build thread
Old 11-30-2011, 07:02 AM   #6
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
melvin, your LS came with 18's....with P245/55R18 all-season on them.....When you put the 20's with 275/40's (stock tire size for RS and SS equipted cars) the ROLLING DIAMETER of your wheel/tire combo didn't change.....so there should be NO DIFFERENCE due to changing the wheels/tires.
Old 11-30-2011, 05:54 PM   #7
melvinakshay
Vrooom Vrooom
does having 275/40/20 on the front make a difference ? I know the recommended size for the front is 245/45/20 and the rims would be 20*8 on the front. I've got 20*9 and 275/40/20 all round ?
20X8 and 245/45/20 front
20X9 and 275/40/20 rear (I got these all round )
hmm, I guess the rolling diameter might not have changed... but I definitely feel a difference while gear shifting. I mean now the RPM is way off compared to the speed. I think the 3rd gear now behaves like the 4th gear on the 18s. Its hard to explain but it feels different. I did miss-shift a few times cause of the change. I'm not talking about the acceleration, just the speed/gear difference.
99% of my travel is in the city so I'm usually @ 3rd or 4th gear. I rarely hit the 5th or 6th
Old 11-30-2011, 06:06 PM   #8
The Stig
The Stig's Avatar
no it doesn't make a difference. It is the same tire diameter overall.
Old 11-30-2011, 06:14 PM   #9
melvinakshay
Vrooom Vrooom
:( any guesses as to why the gears feel different now ? could it be the extra weight ?
Old 11-30-2011, 06:25 PM   #10
The Stig
The Stig's Avatar
That or it's all in your head
Old 11-30-2011, 06:49 PM   #11
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
245/55R18 = 28.6" tall....275/40R20 = 28.7" tall....So, no real difference in your overall diameter.
Your stock18" wheels = 32.0lbs each.....Your 20" 20x9 wheels = 32.0lbs each
Your stock 18" tires = 30 lbs each.......Your 275/40R20 tires = 36 lbs each
So the only measurable difference is that the 275's add 6 lbs on each corner.
nancygrl is offline   Reply With Quote
Old 11-30-2011, 07:37 PM   #12
melvinakshay
Vrooom Vrooom
:( well... ha ha idk but I could swear it feels different.
That is VERY helpful information. I was a bit bothered about that extra weight ! but I guess 6 pounds of rotational mass on a 3750 pound car wont be much of a difference
Old 12-01-2011, 07:59 AM   #13
DraggnFrameGMC
DraggnFrameGMC's Avatar
Drives: 2011 Synergy Green Camaro LT
If you change your tire sizes and it is bigger than factory does it throw off just the speedo or does it mess with the mileage, mpg and fuel trip #'s as well? I know I should have lost some mpg with a bigger tire but 5mpg for a 1.5" taller tire. That didnt even affect my duramax that much when i lifted it and went with a 10" taller tire.
DraggnFrameGMC is offline   Reply With Quote
Old 12-01-2011, 10:43 AM   #14
Sir Nuke
Sir Nuke's Avatar
YES IT WILL....it will effect them all..........If you put on TALLER tires (1.5" larger diameter) you speedo will be registering 60 MPH.....when you are ACTUALLY running 63 mph......and for every hour you drive at 60....you would have actually gone 63 miles.
so you heve two different effects going on. Although you will be thinking your going slower than you really are......your also showing fewer miles on the odometer than you have actually put on your car.
CNT Racing Chevy Camaro V8 3 inch Catback Exhaust with X pipe 439 shipped ERZperformance V8 Bolt-Ons & Tunes 33 06-13-2011 06:09 PM
Do 19 inch polished rim lugs fit with 20 inch rs midnight silver wheels? ihaveacamaro Wheels and Tires Talk Sponsored by The Tire Rack 8 02-26-2011 09:26 PM
Speedometer Calibration hooded V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 1 08-28-2010 04:35 PM
Your thoughts on the Speedo and Tach in the 2010 Camaro dash? SlasherMcGee 5th Gen Camaro SS LS LT General Discussions 51 03-06-2010 10:13 AM
Speedo Calibration Batman0837 Wheels and Tires Talk Sponsored by The Tire Rack 6 11-04-2009 09:30 PM
