Old 11-30-2011, 10:32 AM   #1
cam fan
cam fan's Avatar
Drives: fast
power hungry (cai talk)
Here in v6-ville we aren't exactly starved for horsepower but i'm sure we can all agree more is better (in this case)
looking over the Jannetty testing results CAI makes the most HP/torque gain from a cold air intake...
https://docs.google.com/spreadsheet/...VE&hl=en#gid=0
DUE TO "adm scoop"
- are these resulting gains relative for our v6? (aka they gained 13hp/9tq...do we?)
- wasn't injen the most powerful cai?
- do we get CAI inc/Vararam cai discounts here?
cam fan is offline   Reply With Quote
Old 11-30-2011, 10:39 AM   #2
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
ADM scoop. There are tons of post on this, in fact I just intalled one. Do a seach, you'll find many posts.
Here is some:
http://www.camaro5.com/forums/showthread.php?t=184696
http://www.camaro5.com/forums/showthread.php?t=168519
http://www.camaro5.com/forums/showthread.php?t=184693
FSP tuned: 377/389
Old 11-30-2011, 10:49 AM   #3
UT-Engineer
Just Cruisin'
UT-Engineer's Avatar
Drives: 2010 Synergy Camaro
The Vararam intake makes 25-30 hp, per the vendors here. It was released after the Jannetty testing i believe.
2010 Synergy Green Camaro
25% Tint - CGM Painted GM GFX - 20" Niche M102 Wheels
UT-Engineer is offline   Reply With Quote
Old 11-30-2011, 11:05 AM   #4
h2oplay
Winners find a way
h2oplay's Avatar
Drives: 2010 2LT/RS M6
I would have to see actual before and after dyno results to believe that figure...... seems unlikely from any CAI on a V6
h2oplay is offline   Reply With Quote
Old 11-30-2011, 11:11 AM   #5
UT-Engineer
Just Cruisin'
There are some threads here with the dynos. Its impressive actually.
EDIT: http://www.camaro5.com/forums/showth...m+dyno+results
Old 11-30-2011, 11:20 AM   #6
cam fan
cam fan's Avatar
Drives: fast
so what was the official vr hp/tq gains? (didnt see a distinct claim)
Old 11-30-2011, 11:23 AM   #7
UT-Engineer
Just Cruisin'
From what ive seen, several members have gained 20hp/20tq solid over stock. That was at a minimum. As vendors and VR claims, results have been as high as 25HP/TQ. I asked a vendor on here last week if this was at the wheels or crank. He stated wheels. Which would make sense since the dyno results are HP/TQ numbers at the wheels. You'll pay more for the VR but get more IMO.
Old 11-30-2011, 11:26 AM   #8
bmorecam
I don't know if I would believe as far as 30+ hp but there is definitely a boost in power at high speed pass 80mph. When ram air is effective there are a few key things that need to be incorporated. The time it take the air to travel from outside to the cylinders and a straight path, vararam has both in the design which also has its advantages over the others on the market.
Old 11-30-2011, 11:27 AM   #9
cam fan
cam fan's Avatar
Drives: fast
isn't there less air going to VR relative to the race scoop?
look at this package!
http://autoagenda.com/2010-camaro-v6...-scoop-package
so....with respect to the initial goal of this post VR wins(?)
haha i've gone from injen faithful, to CAI inc/ADM scoop die-hard to VR fanboy in less than an hour :/
Old 11-30-2011, 11:36 AM   #10
Aequitas & Veritas
Aequitas & Veritas's Avatar
Drives: 2010 Camaro 2LT RS, 2009 GTR
I went with the Injen long tube since at the time it had better numbers and Scrming did an air temp/pressure test and the injen cools down faster and such. Just food for thought.
Aequitas & Veritas is offline   Reply With Quote
Old 11-30-2011, 11:41 AM   #11
JDP Tech
JDP Tech's Avatar
Drives: 2010 CGM Camaro 2SS/RS 429 LSX/F1X
Not sure about the Vararam, but utilizing the stock intake scoop, we tested a bone stock auto V6 car before and after an Airaid Intake System install, same day, car stayed strapped down to the dyno, no heat soak before or after, so there was no fooling with numbers. The intake gained 12hp and 7tq. So compared to his data sheet the V6 model had a large gain over his tests.
JDP Tech is offline   Reply With Quote
Old 11-30-2011, 11:45 AM   #12
UT-Engineer
Just Cruisin'
Like any other performance part there are pros and cons vs other products. Some CAIs will perform slightly better than others, some visually look better than others, but they will come at a cost. Injen, Airaid, CAI, VR, & Roto-fab are all great intakes. Just a matter of how much u want to spend.
Also, the HP/TQ gains seen are usually "peak" hp gains. And this is usually at higher RPMS under WOT. I personally would go with an intake that had larger HP/TQ gains over stock in the mid RPM range, since this is where you will usually be under acceleration (even for normal driving). I mean, how often do you really hit 6000+ RPMS?
Old 11-30-2011, 11:55 AM   #13
cam fan
cam fan's Avatar
Drives: fast
verrrry true! and good point...so which of the intakes takes the mid-range cake?
what is WOT?
check this out
http://www.camaro5.com/forums/showthread.php?t=184937
post #18
Originally Posted by sschevybear11 View Post
Maybe some gain by leaning the system at first but very little if any after computer relearns. There is not that much gain folks. I really liked the vararam,seems to improve throttle response and pull harder but WOT wasn't as good. The track confirmed it. Its for looks, choose the pretty one or get a real gain with a scoop, washer bottle relocate and modify the stocker to accept the air.
Old 11-30-2011, 11:58 AM   #14
nyrfan
Let's go Rangers!
nyrfan's Avatar
what is WOT?
check this out
post #18
WOT = Wide Open Trottle.
I love my CAI, CAI with ADM scoop and Roto-Fab washer relocator. All 3, along with a ported TB made a hugh difference in my V6's preformance and trottle response.
FSP tuned: 377/389
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3656 11-01-2025 02:41 PM
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 273 08-15-2023 05:44 PM
Acronyms at C5 hokie2012 5th Gen Camaro SS LS LT General Discussions 34 08-10-2011 04:56 PM
just installed CAI (brand) not noticing power increase black79ta Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 06-30-2011 09:51 AM
Well sunroof question answered (PIC) Black5thgen 5th Gen Camaro SS LS LT General Discussions 152 08-29-2009 11:23 PM
