Old 11-30-2011, 03:31 PM   #1
scorpion1206
scorpion1206
Drives: 2011 Camaro 2SS
ADM Scoop difference?!
So I installed my Cold Air Inductions CAI, and didn't even know about the scoop. Does it really make that much of a difference?? I know I would have to relocate the washer, which looks pretty straight forward, but is it worth it to get the scoop?
scorpion1206 is offline   Reply With Quote
Old 11-30-2011, 03:49 PM   #2
JANNETTYRACING
JANNETTYRACING's Avatar
5-6 HP in our Testing.
Give me a shout I will set you up with one.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 11-30-2011, 03:56 PM   #3
LittleMT
user bann'd
LittleMT's Avatar
Drives: Chevy SS
I say do it.....a minimal hp gain, but every bit helps, and if you get 6hp for the price of the scoop, it's not to bad of a deal...
Chantilly Lace, the 2011 Rockabilly Jukebox..ADM built..617rwhp, geared A6.
LittleMT is offline   Reply With Quote
Old 11-30-2011, 07:23 PM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
You will make more power, not a ton, but it is a pretty good bang for your buck considering how inexpensive it is. Here is an outstanding install thread.
Old 11-30-2011, 09:23 PM   #5
caverman
caverman's Avatar
Drives: '69 SS Convertible
I you look at the before an after air space that the washer bottle is blocking you'll realize there is no way it can't be a big help.
The first pic shows the area clogged with a washer bottle. Very little if any air getting in. The next two show the big whole for air. Then realise that you cut an area on the inside of the grill for the scoop to grab air and direct it towards the intake.
Build Journal
Old 12-01-2011, 08:19 AM   #6
scorpion1206
scorpion1206
Thanks for the pics caverman, I guess it would make sense to get one then and move the bottle.
Old 12-01-2011, 08:35 AM   #7
snizzle
Recalled user
snizzle's Avatar
Drives: '12 Camaro SS, '18 Colorado Z71
Moving the bottle is a requirement, correct? So is breaking out the dremel and cutting a hole.
Old 12-01-2011, 08:54 AM   #8
caverman
caverman's Avatar
Yes.
The scoop goes basically right where the washer bottle is. It even uses the bolt location of where the washer bottle's bolt is. You'll also need to use something (dremel usually) to cut a section of plastic right behind the grill. This is where the front opening of the scoop will pick up air from.
Build Journal
Old 12-01-2011, 11:16 AM   #9
AngelSpeedFreak
Most hated in NM....
AngelSpeedFreak's Avatar
Drives: Sold the 6POINT2, went to a 50THZ06
agreed.... 6hp here and there will add up fast..
AngelSpeedFreak is offline   Reply With Quote
Old 12-01-2011, 12:37 PM   #10
Jekyll-N-Hyde
I put the FU back in FUN
Jekyll-N-Hyde's Avatar
Drives: 1969 SS 396 , 2010 Camaro SS
Its very noticable as well on cool days after adding the airscoop.
Jekyll-N-Hyde is offline   Reply With Quote
Old 12-01-2011, 12:44 PM   #11
AutoAgenda
AutoAgenda's Avatar
Drives: 69 Camaro, 02 Escalade, 67 Eleanor
+1, Some of our customers have also told us it also sounds better.
AutoAgenda is offline   Reply With Quote
Old 12-01-2011, 06:16 PM   #12
Apex Motorsports
Correct. The material that has to be cut is just a piece of plastic behind the lower grill.
Disassembling the front end of your car is not necessary for this install. It was done to the car in the photos because it was having other modifications being done and it made for better pictures.
Old 12-12-2011, 09:01 AM   #13
NateSS
1337 AH64D driver
NateSS's Avatar
Drives: 2010 Camaro 2SS/RS L99
i understand its only a 6 hp gain, but does the tune need to be tweaked at all or is it just install and good to go?
Cam/Heads by ARD, Tune by G-Force, Transmission/Gears by Circle D
NateSS is offline   Reply With Quote
Old 12-12-2011, 09:06 AM   #14
The Stig
knows 2 facts about ducks
The Stig's Avatar
It's good to go
Click to view my build thread
$40.00 OFF Cold Air Inductions Packages! ADM Performance Scoop | Roto-Fab Reservoir! AutoAgenda V6 Bolt-Ons & Tunes 119 06-17-2013 01:18 PM
My review of ADM scoop and Roto-Fab WW kit ssmike Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 01-30-2012 08:53 PM
SEPTEMBER SPECIAL: $40.00 OFF Cold Air Inductions Packages! ADM Scoop | Roto-Fab Kit! AutoAgenda V8 Bolt-Ons & Tunes 51 10-04-2011 10:26 PM
ADM Scoop with a supercharged car? Darth_Emma Forced Induction - V8 44 06-26-2011 12:59 PM
