Old 11-30-2011, 08:39 PM   #1
king pin
king pin's Avatar
Drives: 2011 Camero 2SS RS Conv
Got the Headers on and Tuned
Here is the Dyno sheet with catback only and with the Headers on
king pin is offline   Reply With Quote
Old 11-30-2011, 08:55 PM   #2
AngelSpeedFreak
Most hated in NM....
AngelSpeedFreak's Avatar
Drives: Sold the 6POINT2, went to a 50THZ06
380 to 417 - real nice... You must have one of the faster cars from the factory.
AngelSpeedFreak is offline   Reply With Quote
Old 11-30-2011, 09:05 PM   #3
Juiced1
Drives: 2012 2SS CAMARO 45th
Nice, what system did you go with?
Juiced1 is offline   Reply With Quote
Old 11-30-2011, 09:07 PM   #4
Jcobra
Jcobra's Avatar
Drives: 2010 2ss/rs M6
4000lbs
Jcobra is offline   Reply With Quote
Old 11-30-2011, 09:13 PM   #5
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
Originally Posted by Jcobra View Post
4000lbs
Sad isn't it.
bannonm is offline   Reply With Quote
Old 11-30-2011, 09:15 PM   #6
Jcobra
Jcobra's Avatar
I just saw its a vert, now I get it.
Old 11-30-2011, 09:17 PM   #7
king pin
king pin's Avatar
Billy Boat.
Old 11-30-2011, 09:23 PM   #8
bannonm
bannonm's Avatar
If it's a vert, then that might explain his higher numbers. 4,000 for the coupe is what is used for the Mustang Dyno. Yes, your coupe weighs in at 3,900 to 4,000. The Mustage Dyno applies force on the drum to simulate the weight of the car so you get a more real world HP number. The HP value you get is what the HP would be pushing 4,000 lbs on the road. I'm simplifying this, but that's pretty much the way the Mustang represents RWHP numbers. So, if you use a lighter weight for the car your numbers would look higher. A vert would be somewhere around 4,300 lbs I think?
Old 11-30-2011, 09:26 PM   #9
Jcobra
Jcobra's Avatar
Coupe 3850 and vert is 4200 I believe.
Old 11-30-2011, 09:31 PM   #10
Ivan @ Southwest Speed
Excellent Baseline numbers. 37 is a good average gain from LT's across the board.
Ivan
Old 11-30-2011, 09:37 PM   #11
bannonm
bannonm's Avatar
Coupe
3913 / 1779 - SS automatic
3860 / 1755 - SS manual
My tuner set my coupe at 4000 lbs. So my numbers are based on that weight. So setting a vert at 4,000 lbs would give slightly higher numbers for a Mustang. That's my point.
Old 11-30-2011, 10:50 PM   #12
king pin
king pin's Avatar
Ivan
Thanks
Old 11-30-2011, 10:53 PM   #13
king pin
king pin's Avatar
Originally Posted by bannonm View Post
Coupe
Not that I care my Verts weight is 3980 as it sitsThats why my Tuner set at 4000 lbs
Old 11-30-2011, 11:50 PM   #14
Madness11
086YN
Drives: Black 2SS/RS Demon of Madness
So on the second page correct me if I'm wrong but the max hp is 417 and 438 tq at the wheels? I just want to gauge what kind of power I might be putting out since I just out my headers on yesterday and have had my cai for a while.
Madness11 is offline   Reply With Quote
