Old 12-08-2011, 09:21 PM   #1
Maxspeed
~COTW 6/30/14~
Maxspeed's Avatar
Drives: 2011 Camaro SS/RS
My first winterization
I have it on a moisture barrier. Waiting for cover to arrive. When the green cap hits the windshield my car is in the perfect spot and I have just the right amount of room in front and behind the car.
Mods: Heritage Grill, Blade Spoiler, Corrado Hoodliner Mural, Premium Engine Boxes, Radiator Shroud, Custom Painted Bowties, Dipstick & Engine Caps, RX Catch Can, Corsa cat back exhaust, CAI black powder coat cold air, Apex cold air intake scoop and Apex washer tank relocate kit, Dynatech SuperMAXX Ceramic Coated LT Headers, High Flow Cats, JRE470 Rough Idle Cam Package, DSS 1,000 RWHP Axels, Slowhawk Mustang Dyno Tune, QTP QTEC 66 Low Profile Cutouts and iTSX. 453 RWHP 427 RWTQ
WEB LINKS
BUILD
TIMING CHAIN FAILURE
TRANSITION FROM STOCK TO CAM VID
Maxspeed is offline   Reply With Quote
Old 12-08-2011, 09:23 PM   #2
Maxspeed
~COTW 6/30/14~
Maxspeed's Avatar
Steel wool in the exhaust.
WEB LINKS
BUILD
Old 12-08-2011, 09:24 PM   #3
Maxspeed
~COTW 6/30/14~
Maxspeed's Avatar
Mothballs in a sock. Also have dryer sheets resting onn a plastic bag in the cabin and trunk.
WEB LINKS
BUILD
Old 12-08-2011, 09:29 PM   #4
Maxspeed
~COTW 6/30/14~
Maxspeed's Avatar
Here is my Battert Tender Junior. I tied a washer to a string and dropped it down the front of the engine and tied it to the cable and pulled it up thru the engine and connected it to the clamp wire. I didn't want the wire coming out of the front of the grill resting on the paint. I then connected the battery tender to an extension cord and pushed the tender under the front end. I duck taped the extension cord to the ground so it doesnt get pulled or kicked.
http://www.amazon.com/Battery-Tender...3397582&sr=8-1
WEB LINKS
BUILD
Old 12-08-2011, 09:34 PM   #5
Maxspeed
~COTW 6/30/14~
Maxspeed's Avatar
Things I have left to do is place some moth balls under the car and some mouse traps on either side of the tires. When my Coverking Satin Stretch cover arrives I will Detail Spray the car and cover it. I also inflated the tires to 50 PSI. I printed out a word document of exactly what I need to do in the spring so I will remember what I did today and left it on the seat. I tucked the car close to the wall so that I have more room between the drivers side and my wifes van. I made special note to be carefull backing the car out next spring to I dont clip pthe right side mirror on the garage.
WEB LINKS
BUILD
Old 12-08-2011, 09:49 PM   #6
MIT'13
MIT'13's Avatar
Drives: 2010 IBM Camaro 1LT / RS
You are a very thorough fellow! I'm sure the cover and your other precautions will keep it very safe. The winters here in Mass get pretty brutal, but so far this year has been alright.
1944 Willys Jeep
2010 Camaro RS IMB w/ Sound System upgrade + Sunroof, Chrome gills
MIT'13 is offline   Reply With Quote
Old 12-08-2011, 09:57 PM   #7
Maxspeed
~COTW 6/30/14~
Maxspeed's Avatar
I just read what other owners did here and did the same. This is my first toy car. Actually what I did today only took about an hour. I did have to go to Ocean State Job lot and buy the tarp.
WEB LINKS
BUILD
Old 12-08-2011, 10:30 PM   #8
montreal2010yellow
montreal2010yellow's Avatar
Oups. looks like you forgot to put some :
Old 12-08-2011, 10:31 PM   #9
Maxspeed
~COTW 6/30/14~
Maxspeed's Avatar
Nope, topped it off and plenty of Sta-bil. Just forgot to mention it. I knew I was leaving something out.
WEB LINKS
BUILD
Old 12-08-2011, 10:51 PM   #10
hightower
LS3 Black Widow
hightower's Avatar
Drives: 2012 45th 2SS LS3 and 1968 Mustang
Brilliantly done. Best winterization I've ever seen. Bravo to you!
Moments like these are when you can tell that someone truly loves their ride.
hightower is offline   Reply With Quote
Old 12-08-2011, 11:20 PM   #11
Dznts
Anabolic Connoisseur
Dznts's Avatar
Nicely done
Old 12-08-2011, 11:45 PM   #12
AngelSpeedFreak
Most hated in NM....
AngelSpeedFreak's Avatar
Drives: Sold the 6POINT2, went to a 50THZ06
very good... sorry you have to do it however. I cant imagine not being able to drive my car for a few months...
AngelSpeedFreak is offline   Reply With Quote
Old 12-09-2011, 12:15 AM   #13
VoodooVyper
VoodooVyper's Avatar
Drives: 2012 IBM Camaro 1LT/RS
I live in MA too, just got the car a few weeks ago. My winterization consisted of Pirelli Scorpions and a new set of wheels.
2012 Camaro IBM 1LT RS Auto
10/11/2011 (1102)
10/11/2011 (1100)
10/18/2011 (2000)
10/18/2011 (2500)
10/18/2011 (3000) TPW 11/7
10/29/2011 (3100,3300)
11/01/2011 (3400)
11/08/2011 (3800)
11/09/2011 (4B00)
11/14/2011 (4200)
11/18/2011 (4800)
11/21/2011 (5000)
VoodooVyper is offline   Reply With Quote
Old 12-09-2011, 12:15 AM   #14
Supercamaro64
Right, right.
Supercamaro64's Avatar
Drives: 79 Z28, 86 Camaro, 94 Burb 4x4
Yea i just got the cover for mine today! Put a bunch of dryer sheets in it, set up the battery tender, set the mousetraps around the garage, etc. I still need to do a few things, but shes almost tucked in for the winter!
"You wanna lay the fate of the world on the kids camaro? Thats cool."
"When reporters asked what it was, one official stated, 'It's a small, vicious animal that eats Mustangs.'"
The Creampuff Fleet-
Supercamaro64 is offline   Reply With Quote
Winterization fail Rock-It Man 5th Gen Camaro SS LS LT General Discussions 6 10-30-2011 06:39 PM
