Old 12-11-2011, 12:14 AM   #1
NateHodor
Drives: 2011 Camaro 1SS w/ RS Package
Removing 2011 SS Brembo Noise Dampeners
Hey everyone
I Bought 19" MSW Type 16 Wheels with Pirelli Scorpion Ice and Sow tires (<1000 miles) on them. Went to put them on today and they don't fit over the Noise Dampeners that they instituted this year on the SS. I will be calling the dealer on Monday to see if they can take these off, or swap them or something. Have anyone had success with taking them off? If it isn't possible, I'll be looking to sell the setup if anyone is interested. Thanks.
NateHodor is offline   Reply With Quote
Old 12-11-2011, 12:18 AM   #2
Rogue Leader
Iatefiberglassinsulation
Rogue Leader's Avatar
Drives: 2010 Camaro 2SS M6
I believe those are attached through the pins that hold on the brake pads. Pop out those pins and they can be removed then put the pins back in (make sure you don't lose the spring loaded tab that holds in the pads.
2010 Chevrolet Camaro SS - was daily driver, now toy
2020 Alfa Romeo Giulia Quadrifoglio - Daily Driver
2017 Mercedes Benz GLE 350 - Wifes Car
2008 Chevy Silverado 2500 HD LT 6.0 - Tow Vehicle
1991 Alfa Romeo 164S - Project Car
1994 Volkswagen Golf - Race Car
"Like" my race team on Facebook: http://www.facebook.com/farfrumwinnin
Rogue Leader is offline   Reply With Quote
Old 12-11-2011, 12:23 AM   #3
MRGOODWRENCH3
Drives: 2010 Camaro 2SS/RS
They actually started coming on the mid year 2010's. They are part of the brake pad and cannot be removed with the pins. Try a aftermarket pad from Hawk.
MRGOODWRENCH3 is offline   Reply With Quote
Old 12-11-2011, 12:29 AM   #4
bajamoon
bajamoon's Avatar
Drives: 2014 Subaru WRX
Thank you
bajamoon is offline   Reply With Quote
Old 12-11-2011, 12:59 AM   #5
TAPSHIFT
TAPSHIFT's Avatar
Drives: '11 IBM 2SS/RS '16 1GB Z51 ragtop
I am running 19" OEM Camaro wheels with my winter rubber and the noise dampeners did not have to be removed as there is sufficient clearance. I did have to use a 3mm spacer on the fronts in order to clear the calipers however.
TAPSHIFT is offline   Reply With Quote
Old 12-11-2011, 01:26 AM   #6
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
Angle grinder works. I hacked mine off in about 10 minutes per side. No issues or strange noises or squeaks.
DietCoke is offline   Reply With Quote
Old 12-11-2011, 01:52 AM   #7
hightower
LS3 Black Widow
hightower's Avatar
Drives: 2012 45th 2SS LS3 and 1968 Mustang
This^
Completely off topic but I love your avatar and sig quote. What else do I love? I love lamp.
hightower is offline   Reply With Quote
Old 12-11-2011, 10:14 AM   #8
Li0nel1234
What should I name my car
Li0nel1234's Avatar
Drives: 2010 Camaro 2SS RS IOM
Send a message via AIM to Li0nel1234
Most people just remove the pads and chop em off. A dremel, tinsnips, etc should work from what people have posted.
Performance: ARH 2"/"3 headers + ARH 3" HF catback system, SS brake lines, hawk HP+ pads, motul RBF 600 fluid, K&N CAI (w/custom insulation), plug wires, air scoop, Hurst STS, Pedders Track II suspension, 18x10 wheels, 295/45/18 Nitto NT05s
Looks: powder coated iom calipers, LED foglights w/ always on harness, custom painted bowties, window tint, smoke tinted tail lights etc, oem gfx w/ custom outlets, painted taillight bezels, all weather trunk mat
Li0nel1234 is offline   Reply With Quote
Old 12-11-2011, 09:28 PM   #9
Nessal
Drives: Exige, Miata, Ghia
Do the rollerskates actually dampen the noise?
Nessal is offline   Reply With Quote
Old 12-11-2011, 09:29 PM   #10
bajamoon
bajamoon's Avatar
Not on mine. You can heat me coming a block away lol
Old 12-11-2011, 09:31 PM   #11
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
I want to see the tin snips that can cut these things off.
SUX2BU is offline   Reply With Quote
Old 12-12-2011, 10:49 PM   #12
hightower
LS3 Black Widow
hightower's Avatar
Tins Snips?
Old 12-12-2011, 11:05 PM   #13
The Stig
knows 2 facts about ducks
The Stig's Avatar
Originally Posted by hightower View Post
Tins Snips?
The one on the left is a hydraulic spreader and the right is a hydaulic cutter. They use 10,000 psi when powered up.
Click to view my build thread
Old 12-12-2011, 11:10 PM   #14
JusticePete
Drives: Camaro Justice
High performance brake pads make noise. On the SS the only way to reduce the noise is to dumb down the pads You'll hear many disagree and claim they have replaced pads and the brakes are no quieter and makes less dust while stopping better. Being politically correct, I'll just say I have yet to see any data that supports this claim
The roller skates are there to add mass to the caliper and pad assembly. The greater mass alters the harmonic and reduces noise. Yes they do work, but not to the satisfaction of many. The real question is why is the brake noise a problem? The best brake pads money can buy squeal like a stuck pig. Check any SCCA road course or autocross event to verify this with your own ears.
In the 5th Gen community an engine growl is well received, but performance brake noise is not welcome. If you check forums for other respected brands using Brembo brakes you'll find similar issues, so the 5th Gen community is not alone in this.
2011 ss, brembo, noise dampeners, wheels
Is this the correct DRL harness for a 2011 SS? bumblebeecamaro Cosmetics and Lighting Modification Discussions 5 11-28-2011 07:12 PM
2011 ss brembo brake setup davidsonmotorsports Suspension / Chassis / Brakes 3 08-15-2011 10:42 PM
My Shootout: 2010 Camaro SS vs. 2011 Mustang GT nester7929 Chevy Camaro vs... 13 06-02-2010 10:37 PM
My Shootout: 2010 Camaro SS vs. 2011 Mustang GT nester7929 General Automotive + Other Cars Discussion 15 06-01-2010 07:45 PM
