Old 12-11-2011, 03:03 PM   #1
goval
Anderson B.
goval's Avatar
Drives: 2011 Chevy Camaro 2SS RS
gas pump nozzle "stopping" all the time while fueling; before the tank is even full.
I'm having a problem with the gas pump nozzle stop pumping gas while I'm pressing the handle... I have to force the pump nozzle inside the Camaro's fuel tank opening while holding the handle, and it's hard to keep it from stopping. I thought it was this particular gas station and it was just the pump nozzles there, but it happens everywhere... wondering if anyone have this problem...?
2011 IOM SS/RS
goval is offline   Reply With Quote
Old 12-11-2011, 05:04 PM   #2
lbheat
Echale Gas [COTW 3/10/14]
lbheat's Avatar
Drives: 2010 Camaro SS/RS Supercharged
same issue with my car....really annoying...i always fill up at shell and occasionally at chevron
Kenne Bell
502 rwhp/ 471 rwtq at 9psi (daily driver...for now)
Performance: Corsa catback, JRE Super Tensioner, dual pass heat exchanger, R1 slotted & Dimpled rotors cryogenically treated
Cosmetic: Giovanna kilis 22", zl1 mailslot bumper, Custom Emblem Pro Badge, painted calipers
lbheat is offline   Reply With Quote
Old 12-11-2011, 05:07 PM   #3
bill2129
Drives: 2085 Trans AM COBRA
Looks like you gotta hold it down now
bill2129 is offline   Reply With Quote
Old 12-11-2011, 09:38 PM   #4
Nessal
Drives: Exige, Miata, Ghia
I used to be able to fill up my VW without holding the nozzle. Then one day it decided that it didn't like it and wouldn't even fill up that way ever again. Still don't know what is going on.
Nessal is offline   Reply With Quote
Old 12-11-2011, 10:40 PM   #5
GARYSSS
GARYSSS's Avatar
Drives: 2010 2SSRS M6 Rally Yellow
I just had this happen this weekend for the first time.
TEAM LS3
GARYSSS is offline   Reply With Quote
Old 12-13-2011, 09:25 AM   #6
BigBlock427
ConceptZer0
Drives: 68 427 Camaro, 11 2SS/RS, 13 ZL1
This happens to me allot...
BigBlock427 is offline   Reply With Quote
Old 12-13-2011, 09:56 AM   #7
scuba264
scuba264's Avatar
Drives: Manual 2011 CGM LS
Try backing the nozzle out just a bit so its not completely flush. I haven't had any issues with my Camaro, but there is a hole on the nozzle of a gas pump, and when the gas reaches it and blocks the hole it stops the pump.
Sometimes when I get to a random pump (with any car) that keeps kicking off I just back it out a little. Not sure exactly why, maybe its the shape of the gas inlet and the location of the hole that is blocking it enough, or there is enough fluid to screw it up or something. That usually helps.
scuba264 is offline   Reply With Quote
Old 12-13-2011, 11:12 AM   #8
fishbrownie
fishbrownie's Avatar
Drives: 2010 2LT/RS White w/ Black Stripes
the only gas station where I don't have to jockey around with the pump is at QT. Everywhere else is a pain.
"Roads? Where we're going we don't need roads."
fishbrownie is offline   Reply With Quote
Old 12-13-2011, 12:11 PM   #9
SoCal Swagger
SoCal Swagger's Avatar
Drives: RS
same here i have to hold it down and upward no more having a smoke when i fill up :(
SoCal Swagger is offline   Reply With Quote
Old 12-13-2011, 12:21 PM   #10
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
I've notice the problem to be more when the car is hot. Like at the end of theday after a long commute. Vapor lock type issue??
Old 12-13-2011, 04:28 PM   #11
Nessal
God I hope you're smoking AWAY from the pump...
Old 12-13-2011, 04:37 PM   #12
formare
The Milano
formare's Avatar
Drives: 2017 Firefly ShipWorks
A solution was posted a long while ago. It will take some diggin to find the detials. Short answer - push in on the nosel until it "latches". Newer model cars hav a lip that catches a hook on the nozel that holds it in place.
I was really frustrted until I learned this.. now easy as it is ever was.
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 12-14-2011, 01:29 PM   #13
kalimus
kalimus's Avatar
Drives: '14 Z51 3LT Stingray and '13 Cruze
All pish posh. You can put a lit cigarette out in a barrel of gasoline
kalimus is offline   Reply With Quote
PERRIN Performance Water/Methanol Injection Kit PERRIN_JOHN Forced Induction 4 03-17-2010 10:57 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 10:03 PM
Best MPG on a full tank of gas for an SS? O2BQIK 5th Gen Camaro SS LS LT General Discussions 27 09-21-2009 05:40 PM
Payment and Shipping info for 1st Edition Camaro5 shirts TAG UR IT Camaro5 Store Merchandise 154 10-18-2008 04:00 AM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
