Old 12-12-2011, 12:47 AM   #1
SixCyl
SixCyl's Avatar
Drives: 2010 Camaro CGM V6
Roto-Fab CAI gas mileage
Alright so before I bought my cold air intake I looked around for gas mileage numbers. Finally I decided they were all pretty much comparable, but being the researcher that I am.....I couldn't let it go.
So I went ahead and did a semi scientific study to see what kind of mileage I would get at different speeds.
Drive settings:
-Tampa to Melbourne
-150 miles
-88 degrees Fahrenheit
Car variables:
-92 octane gas
-35-38 psi in tires (heat varied)
-Roto-Fab cai
-Nitrogen filled tires
Procedure:
The following speeds were sustained for a minimum of five minutes to measure miles per gallon: 50, 60, 65, 70, 75, 82
I began at 82 miles per hour (mistakenly) and worked down to 50 mph.
The results were as followed:
50 mph = 35 mpg
60 mph = 32 mpg
65 mph = 30 mpg
70 mph = 27.5 mpg
75 mph = 25 mpg
82 mph = 22.5 mpg
The results are shown below, it is very nearly linear, which is why I skipped 55 mph. I wanted to see how well my data would account for a missing data point and was pretty satisfied by the results.
The variations in the graph may be due to extraneous variables that may have affected the driving at the time, I do recall the 60 mph setting having rough roads where the pavement was uneven and peeling.
Though I have not replicated this without the cold air intake to make a comparison, I do recall seeing 23.4 mpg at 75 mph and 29.5 mpg at 60 mph. So the difference is between 1.5 and 2.5 mpg. Hopefully this gives you an idea of what to expect on the highway, but again this is a study with an n of one so it can't be considered truly reliable.
PS. The nitrogen filled tires did nothing, just from comparing it to my mpg before I got the nitro. It did however significantly smooth the ride. I ran over a pothole that in the past jarred me a little, this time around was barely noticeable. I was honestly having trouble believing it was the same pot hole.
El gato. Mods: Eagle eye headlights, 18" Axis Sport graphite, Roto-Fab cold air intake, Vmax ported TB, 3/8" Vmax Black-Ice, RX single valve catch can, RX breather, Pedders inserts, Trifecta tune, BBK LTH 304 SS.
art/ärt/Noun. Definition: 5th generation Camaro.
SixCyl is offline   Reply With Quote
Old 12-12-2011, 12:54 AM   #2
Mach
Mach's Avatar
Drives: White M6 1LT RS
Very Cool experiment. Today, I did 250 miles at an avg. of 70mph.. got a 27.5. Exactly what you got.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 12-12-2011, 06:02 AM   #3
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Great idea. I will have to plot the MPG points I have gathered. Compare notes.
Old 04-06-2012, 09:34 AM   #4
SixCyl
SixCyl's Avatar
I have been using 89 octane for the past two tanks and interestingly, there was no difference in mpg at worst and at best, maybe a .5 drop at 75 mph+. Curious what 87 octane will do but my mind just screams don't put anything other than premium in it....
Old 04-06-2012, 10:22 AM   #5
TooCool5
TooCool5's Avatar
34 MPG 50 MPH 87 Octane. Stock intake.
Old 04-06-2012, 05:46 PM   #6
TastyBake
TastyBake's Avatar
Drives: 2011 Camaro 2LT/RS Black
Excellent experiment.
Those numbers make sense. My avg MPG goes down if I go 75 mph or so constantly on the highway (20 mpg)
I tried going 64 and I was avg 24. It was kinda nice. Got to enjoy the drive more.
TastyBake is offline   Reply With Quote
Old 04-06-2012, 06:37 PM   #7
SixCyl
SixCyl's Avatar
Yeah? Ok I'll fill her up with some 87 next time. I just grew up being told premium is better for the engine overall but I feel like maybe today that's not as important.
I feel like that's low, going from premium to mid grade I experience maybe a 0.5 drop at anything above 75 MPH. Are your tires properly inflated? I don't think 5 mpg would fall under a normal deviation but I suppose you could be one of the few cars at 2 or 3 standard deviations below the norm?
I know they check for that but Idk
Old 04-06-2012, 07:15 PM   #8
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
When I had Blackbee and stock thats what I got also.
VR Baron is offline   Reply With Quote
Old 04-30-2012, 04:49 PM   #9
SixCyl
SixCyl's Avatar
Been using regular and no difference in mileage, got 40 mpg actually at 50 mph. Not sure how to explain that.
Old 05-02-2012, 11:44 AM   #10
DJ ATOMIX
<< CRAZY BEE >>
DJ ATOMIX's Avatar
Drives: 400HP 2LT/RS
Do you have the windshield bottle relocation kit installed and the ADM Scoop? I noticed a differance right away after complimenting the Roto-Fab CAI with this mod. My MPG went from the same as yours (30MPG) at 110KM/h (65MPH) to 65 mph = 32 mpg. So I gained an additional 2mpg from adding the adm scoop and relocating the windshield bottle. Thats about a savings of $4-$5 at the pump each time you fill up here in Edmonton where gas is at $1.13/litre atm.
Shaun
CRAZY BEE - IOM 2LT/RS (more)
Cosmetic Mods - 24 | Performance Mods - 14
ROTO-FAB CAI - DT HEADERS - CUSTOM 3-INCH PIPE EXHAUST - RES DEL - R-CATS DEL - MAGNAFLOW RES X-PIPE - 91 OCTANE TUNE - FULL ADM KIT - PORTED IM - PORTED TB - PORTED CH - BLACK 3/8 ISOLATOR - TRIFECTA TUNED
DJ ATOMIX is offline   Reply With Quote
Old 05-02-2012, 11:55 AM   #11
SixCyl
SixCyl's Avatar
No I haven't done that mod, I forgot about that mod actually. I've been trying to figure out why the mileage was so high down the road I went and I realized it has a very slight downward slope in the direction I went. That's my best guess. Other than mpg did you notice any difference in power?
Old 05-02-2012, 11:56 AM   #12
Bo White
Bo White's Avatar
Mine being a ls3 and not a v6 take this as you will. The highest I ever seen my instant mileage stock was 27.7 and after the rotofab I seen 29.1 both at 70mph.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 05-02-2012, 02:12 PM   #13
pgustavson
Stop writing "vert", ffs!
pgustavson's Avatar
Drives: 2011 2LT Convertible
I recently did a 351mi drive in my totally stock car - averaged 58mph, 87 Octane, temps ranged from about 40deg to 58deg, with the trunk packed with heavy tools. A lot of highway cruisng at 75mph+, a couple of "just-for-fun" blasts of likely-high$-ticket speeds , and around 140mi of rural highway driving at 40-60mph. Also, 55mi with the top down. Result: 27.5 MPG. I am considering the Roto-Fab intake, along with two others, so maybe I can repeat the trip someday with the mod.
Vararam | Vmax Ported TB | Ported IM | Vmax Black ICE-olator
pgustavson is offline   Reply With Quote
Old 05-02-2012, 02:16 PM   #14
DJ ATOMIX
<< CRAZY BEE >>
DJ ATOMIX's Avatar
Yes, the car notices much more pull when your on the highway and freeways. 5th gear and 6th has the most noticeable gains for me with 5th gear having much more balls than before.
The faster you go, the more performance will be noticed with this mod.
In the city, you clearly notice a differance once your close to 60kmph (40mph). I can now easily chirp going into 2nd off the line in manual mode. This was something I always had problems doing and could only do in sport auto mode.
The adm and relocation provides anywhere from 5-20hp depending on what speed your doing.
Shaun
cai, cold air intake, gas mileage, mpg, roto-fab
Roto Fab CAI chrisx66 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 1 07-13-2011 11:10 PM
WTB CAI intake or Roto Fab LS3`or ADM bajamoon V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 1 05-25-2011 09:15 AM
Stop complaining about your gas mileage!! RunningOnEmpty 5th Gen Camaro SS LS LT General Discussions 51 05-21-2010 12:58 AM
roto fab cai photos any out there camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 05-11-2010 10:13 PM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 10:10 PM
