12-15-2011, 02:46 AM | #1 |
Drives: 2010 Camaro 2SS/RS Inferno Orange. Join Date: Nov 2011
Haha and yet another muffler delete question.
So what is eveyone doing exactly? Just deleting the rear mufflers? Deleting both the mufflers and resonators. Deleting H pipe as well and having completely straight pipes from cats on back? Adding X pipe? Just curious what everyone was doing and what would the sound differences are between H pipe, X pipe, or just straight all together?
12-15-2011, 07:59 AM | #2 |
Drives: '69 SS Convertible Join Date: May 2009
This is what I did. Don't have the system any more but had it for about 8 mths.
http://www.camaro5.com/forums/showthread.php?t=64964
Build Journal |
12-15-2011, 09:06 AM | #3 |
Drives: 1SS Black w/ White Strips M6 Join Date: Feb 2011
I just cut the mufflers off and that was all I did. IMO it sounds great with just the muffler delete but so do all the other types of modification that you mentioned.
12-15-2011, 02:32 PM | #4 |
Anabolic Connoisseur
Drives: Sold - Blown Camaro 2SS/RS LS3 Join Date: Sep 2010
i had my mufflers cut off yesterday, and all i can say is wow.. totally worth the $100 i spent.
12-15-2011, 02:37 PM | #5 |
Drives: 2010 CAMARO. 10.04@133mph, 1.4 60' Join Date: Jul 2009
L99 or LS3? If its an auto you will have to tune the afm out so it doesnt go into 4cyl mode. If its an LS3 just remove the mufflers and install a magnaflow tru xpipe and you are good to go
12-15-2011, 02:40 PM | #6 |
I have a l99 and i did a resonator delete. At first i did not like it, but it has really grown on me. Its well worth the 200 bucks it cost and is great for a small mod that doesnt break the bank. The only things i dont like about it is that it is kind of irregular. To me it sounds great one day and the next not so great, but at WOT its always fun to hear the car scream. ADD a Cold Air Inductions CAI and youll like the scream it gives ya
2011 2ss/RS Summit White / Grey and Black Interior. TSP VVT-2 Cam, ARH heads and Exhaust, CAI, Ported Throttle Body, Plasti Dipped tailight bezels and rims. AAC interior lighting. Tuned by East Coast Supercharging.
12-15-2011, 02:42 PM | #7 |
||||Tuners Impression||||
Drives: Fairlady Z/LLT/LS3 Join Date: Sep 2011
I did the muffler delete the first couple couple days I brought my LS3 home. Not too loud, not too quiet, and probably the cheapest way to let the roar be heard.
12-16-2011, 12:53 AM | #8 |
The Backbone!
Drives: '11 VR 2SS/RS M6, 01 Jeep TJ modded Join Date: Jun 2011
I just cut off the ugly cans in the back.
12-16-2011, 02:13 PM | #9 |
Drives: 2011 1SS/RS , 1966 GTO Join Date: Jul 2011
Had a shop cut out mufflers and run pipe to the rear and used the factory tip again. Sounds great!
A machine for shrinking time and distance.
12-16-2011, 02:29 PM | #10 |
Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
i have an ls3. cut out the mufflers, installed an x pipe, removed the resonators, put on high flow kats and long tube headers. the thing sounds like tractor trailer (not in an obnoxious way). you definitely get some drone but it's easily avoided by changing your cruising RPM.
i love my set up and would recommend it |
12-16-2011, 03:58 PM | #11 |
1,425 hp / supercharged
Drives: (2010 2SS/L99) (1999 Corvette) Join Date: Oct 2009
As long as you leave the OEM cats on there, you can eliminate everything aft, and I promise it won't be too loud. You might want to throw an x-pipe in there where the resonator (L99) or resonators (LS3) were, although an h-pipe will give it more of a good old-fashioned muscle car rumble.
"If it's too loud...well, you know the rest."
