Old 12-29-2011, 02:50 PM   #1
Bad Dad
Bad Dad's Avatar
Drives: 2010 2SS/RS , 2011 C6 Base Corvette
Question Has Anyone Tried This Cam Spec....
Has anyone tried this cam my buddy is installing it in his C5
231 243 .617 .623 114 LSA the shop he is using spec it and is getting a Whipple etc. Just wondering how that will perform and sound?
SUICIDE BY RACECAR
Bad Dad is offline   Reply With Quote
Old 12-30-2011, 11:25 AM   #2
east TX Muscle cars
east TX Muscle cars's Avatar
Drives: 2x 05 Vettes/65'AC cobra/68 camaro
thats really wouldnt be anything close to what we would spec for a PD blower car.
what other mods does he have other than the blower?
east TX Muscle cars is offline   Reply With Quote
Old 12-30-2011, 12:09 PM   #3
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
thats pretty close to my cam. Promised not to reveal the specs. when it was installed i wasnt thinking of FI. But when we slapped on the Procharger and got 637RWHP at only 6-7psi boost we were kind of surprised. My cam plays well with the blower.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 01-02-2012, 05:12 PM   #4
Go Fast Kid
Drives: Camaro 2010 SS LS7 427ci
CAM specs
Actully that cam spec was developed by Comp Cams and Ted Jennetty, a friend of mine runs that cam with a TVS 2300 blower and produces about 700 hp and is an everyday driver.
Contact Comp Cams or Jennetty about that cam spec.
Go Fast Kid is offline   Reply With Quote
Old 01-02-2012, 06:32 PM   #5
cammed06
cammed06's Avatar
Drives: '09 G8 GXP A6
I spec'd a similar setup for my whipple car, wanting mean muscle car sound, sounds great, under 1500-1600 rpms with a clutch leaves a little to be desired, but everywhere else is sick. It is a large cam for that blower, but I achieved my goal all around. In the end there is always one close or even dead on to what I want. This time I came close to a big N/A cam of Vengeance's and tweaked it for a blower. Turned out exactly how I wanted.
By the way I made my numbers in sig on 9.5ish psi, rich, conservative tune, with rev limiter set at 6500. 11.2 AFR, 15* timing total, and it will hit 10 psi at max, belt is still rubbing itself at WOT...
Obviously a couple more pounds of boost and some leaner afr tuning would send it over 700... and add meth, who knows?
2014 Silverado 2wd, rcsb, 5.3, Cam, LT's, 3600 Stall, 1/8 - 8.28 (1/4 - 12.91 @ 106, 1.80 60ft, 4700+lbs, 2700da, so far)
1989 Turbo T/A / Mint / All original / 16K miles / FOR SALE
cammed06 is offline   Reply With Quote
Old 01-03-2012, 01:42 AM   #6
JMAC2011
MONGOOSE
JMAC2011's Avatar
Drives: 2011 SS Camaro M6
I'm not an expert, but I might ask everyone while we are talking about this. For the SAME intake and exhaust duration mentioned above, doesn't it make sense to increase the lobe separation angle to about 116 degrees and only grind in about 2 degrees advance as opposed to the standard 4. You might gain a better idle quality and low speed driveablity (think below 1800 rpm while managing the clutch). You would also use more of your intake duration for building boosted cylinder pressure as opposed to blowing it out the exhaust... and you might gain slightly more torque at the top where you are shifting gears and trying to win a race, while also making the same if not more horsepower. I'm pretty sure the camshaft will still sound awesome and.... just might get better gas mileage too....
I'm also asking this question because I will soon be in the same whipple situation and a wrong camshaft decision for your intended goals can be a big mistake. It seems like this specific intake duration (around 227-231 degrees for LS3's) is right at the point of trade off between the greed of making more power and sacrificing the quality of low speed driving (parking lots with speed bumps, stop lights etc...) I know with the camshaft that I have right now, every now and then it gets me into a slight lugging situation on the interstate at normal speeds.
Is your buddy with the C5 planning on driving the car on a road track or dragstrip? That would make a difference on the decision as well.
As far as sound goes, my 227/239 has got just enough lope to make me crack a smile. I can only imagine how much better 4 more degrees of both intake and exhaust duration will sound in a slightly smaller engine- it surely will not disappoint in the sound department!
_________________________________
MODS: 470 RWHP / 447 RWTQ
Lethal Racing Night Fury 231/242 113-111, C5R chain, dbl springs, Comp pushrods.
ARH 1-7/8" Headers and complete exhaust - NO cats!
Varraram CAI - Vmax throttle body, ATI 10% underdrive pulley
RPS Street Twin - MGW Shifter
3.91 gears + DSS 1000hp axles
PFADT - Stage 4 Camaro Road Racing Kit - 8" springs 325# and 600# - ZL Spec Sway bars - Strut Tower Brace - Camber plates.
CTSV front calipers - Hawk DTC 30 pads
Street: Forgestar F14 20x9 and 20x11, 275/315 Nitto Invo's, Track: TOYO R888 285/35/20 on 4 corners
JMAC2011 is offline   Reply With Quote
Old 01-03-2012, 05:32 AM   #7
tkrupinski
Hugger Orange
tkrupinski's Avatar
Drives: 2010 Hugger Orange 2SS/ RS YSI/4l80
I went with Total Performance Engineering 's blower cam and it put down the HP numbers he claimed it would. 635RWHP @7PSI with a Maggie and it sounds very good at idle. My car is an LS3.
tkrupinski is offline   Reply With Quote
Old 01-03-2012, 09:05 AM   #8
Slowhawk
Drives: 1999 Trans Am
Thats pretty much a Cam Vengeance Racing offers and have been for years. Nobody on this board designed it,just copied which is common in this industry.
It could work pretty good on a PD setup.
Slowhawk is offline   Reply With Quote
Old 01-04-2012, 12:45 AM   #9
cammed06
cammed06's Avatar
Exactly. I tweaked that n/a cam more for my desire. It's nice, a little low rpm drive issues, but its a trade off for a sick sounding blower car. The toll collector thought my car was broke the other night...
Old 01-04-2012, 01:40 AM   #10
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
I just put the same cam in mine. I haven't got it back together yet. You have any video? How's your drivability?
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 01-04-2012, 10:34 AM   #11
tkrupinski
Hugger Orange
tkrupinski's Avatar
Sorry no video. The low speed drivability is very good "better than i thought it would be" with the proper tune and open road driving is even better. Idle is very noticable with a little car shake. Hope this helps.
Old 01-04-2012, 11:00 AM   #12
Parag
Drives: 2010 camaro 2SS LS3
For a blower that cam spec is great only you should be 116 lsa
Parag is offline   Reply With Quote
Old 01-04-2012, 11:07 AM   #13
Slowhawk
I have one in a NA car we did in 08. Almost no lope at all idling at 800rpm and no drivability issue's. It was an ok cam but we tighten the split up alot nowadays.
Old 01-04-2012, 12:02 PM   #14
JANNETTYRACING
JANNETTYRACING's Avatar
I may have used that cam at one time or another but is not my Blower cams.
It is Not what I would suggest for a Whipple.
My Blower Cams will have my Name on the Cam card and will only be available throught JRE.
Thanks for the Recommendation though
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
ULTIMATE CAM Specs/ Info thread for the LS3/ L99!! mike25 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 31 04-29-2014 12:09 PM
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
Need help with a cam spec sixd8z Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 09-24-2011 08:14 AM
Vector Motorsports Stage 2.5 cam kit installed! pics and video topgun1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 38 12-18-2010 11:28 PM
Camshaft Basics Milk 1027 Wiki 1 12-09-2009 01:00 AM
