Old 12-29-2011, 10:11 PM   #1
VoodooVyper
VoodooVyper's Avatar
Drives: 2012 IBM Camaro 1LT/RS
Wired DRL harness problem on 2012
I recently received the wired drl harness (fieldgoals). A friend of mine (also a mechanic) installed it for me but ran into an issue. He wrote this up to send to the guy who made it, but I figured I'd also post it here in case anyone else had a similar situation:
"I was writing to inquire about you being able to confirm *tested* compatibility on a 2012 Camaro RS. I installed the harness as per the instructions, but am running into issues. With the Ignition off, and the lights on, everything seems to work as intended. The Headlights, Halos, and the DRL all come on together. The problem starts when the car is started. It works for 5 seconds, then the drivers side halo and both the DRL shut off, along with the front side markers. All that is left on is the passenger side Halo. After approx 1 min, all the lights come back on, but the relay for the harness you supplied buzzes constantly. I tried another relay, same thing. I then tested the ground side of the relay control circuit, showed good continuity to ground. Also tried jumping the ground to the battery ground, no effect. Relay still buzzes. I then jumped the power side of the relay control to a constant 12v. That will stop the relay from buzzing. The only thing that I can conclude from this is that whatever wire from the stock harness you are using to control the relay, does not supply a sufficient constant 12v. I realize that you have advertized this for all models, but I wasn't sure if you had been able to verify on a 2012 model that it works. Please let me know if you have any insight into whats going on here. Thanks."
2012 Camaro IBM 1LT RS Auto
10/11/2011 (1102)
10/11/2011 (1100)
10/18/2011 (2000)
10/18/2011 (2500)
10/18/2011 (3000) TPW 11/7
10/29/2011 (3100,3300)
11/01/2011 (3400)
11/08/2011 (3800)
11/09/2011 (4B00)
11/14/2011 (4200)
11/18/2011 (4800)
11/21/2011 (5000)
VoodooVyper is offline   Reply With Quote
Old 12-30-2011, 07:53 AM   #2
Ph4r
Top Down Fun
Drives: 11 2SS/RS IOM Vert
He should have put a diode across the relay coil wires to prevent backflow from the PWM Signal.
2011 Chevrolet Camaro Convertible 2SS RS M6 IOM Vert! IO Interior, Factory Hurst, Painted GFX, Black Rally Stripes, Front/Rear/Bowtie Blackouts, QTP Cutouts, Extra Cupholders!
LED Tails, LED DRL's (always on!), Ghosted "Concept" LED Side Markers, LED Tag Lights, Tinted LED Reverse Lights, Chrome Front Turn Signal Bulbs!
My Build Thread
Daily Driver: 2016 Ford Fusion Titanium with 2 car seats in the back!
Ph4r is offline   Reply With Quote
Old 12-30-2011, 08:10 AM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
Click to view my build thread
Old 12-30-2011, 10:28 AM   #4
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: ...
The harness is supposed to handle all that and if it doesn't, ...
The less expensive Adaptive harness is all inclusive and works just fine without any additional diodes required or any splicing and I can't imagine that Fieldgoal00's isn't designed to be all inclusive....
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 01-06-2012, 07:41 PM   #5
asprex
Drives: 2012 2ss
I have a 2012 and am having the same problem with this harness. Anyone have the fix for this.
asprex is offline   Reply With Quote
Old 01-07-2012, 03:57 AM   #6
Neffarious
Neffarious's Avatar
Drives: 2012 SS (2SS/RS, M6, IOM/Blk Rally)
That is bad news. I have my harness standing by for when I install my break ducts.
In your next picture post, DIY guide, or advertisement thread take a moment and think of the color blind guy. Thanks.
Neffarious is offline   Reply With Quote
Old 01-07-2012, 07:09 AM   #7
fastlane2010
fastlane2010's Avatar
Drives: 2010 camaro with fast lane stage 2
it must be something with the 2012 because on my 2010 it works great i have the same harness just asking he did get the power right from the fuse block power right
12.4 in 1/4 at 117mph first time
custom 2tone paint fastlane stage 2 hydroformed carbon fiber cowl and cluster kooks headers and 3" xpipe with pypes axle back
fastlane2010 is offline   Reply With Quote
Old 01-08-2012, 08:03 AM   #8
NVMYSS
NVMYSS's Avatar
Drives: 2010 Camaro SS
I'm glad you know how my harness was designed. Actually you don't need a diode because we are not using the PWM signal to power anything in our harness, in fact we do not tie into the PWM signal anywhere. Out of over 500 harnesses that have been sold, there have been two with this problem and it just so happens that both were on a 2012. Therefore everyone wants to jump to conclusions that my harness
does not work on a 2012 model, it's funny though because when I don't have a GB to sell these harnesses I have people begging me to sell them one and they will pay almost twice the price. If you think for one second that I am selling you a harness that will not work on a specific vehicle then you are greatly uninformed and need to go back and do your homework.
NVMYSS is offline   Reply With Quote
Old 01-25-2012, 02:51 PM   #9
VoodooVyper
Got the harness back today, noticed a diode across the relay. Will install this week once I'm over this illness and post results.
10/11/2011 (1102)
10/11/2011 (1100)
10/18/2011 (2000)
10/18/2011 (2500)
11/01/2011 (3400)
11/08/2011 (3800)
11/09/2011 (4B00)
11/14/2011 (4200)
11/18/2011 (4800)
11/21/2011 (5000)
Old 01-25-2012, 03:01 PM   #10
jdenotter
jdenotter's Avatar
Drives: 2010 2SS/RS,M6,Black w/CGM Stripes
Hate to bust ya bubble. But adapative's pos harness doesn't work for my car. Alot of people have had issues with it.
Sent from my DROID BIONIC using Tapatalk
3" RDP Motorsports aggressive cat-back exhaust w/ x-pipe, Vararam CAI, Hurst's short throw shifter, Gary's Customs painted bowties, Ofer's HID DRL/Fog Light wiring harness, Kelvin 8K HID DRL bulbs, ZL1 grille. Johnson's window tint film, LSR lowering springs, Metra dash kit with Pioneer In-Dash DVD head unit.
jdenotter is offline   Reply With Quote
Old 02-01-2012, 09:23 AM   #11
NVMYSS
NVMYSS's Avatar
We originally did not use any diodes in our harnesses, only relays to prevent backfeed issues. The reason we are now using a diode relay is not to prevent backfeed issues but because on the 2012 and up Camaro's the PWM signal is getting increasingly stronger for some reason and actually causing regular 12v Relays to fail, not only was this becoming an issue in the AUTO mode portion of our harness, but even in the relay that was being supplied from a pure 12v source on the car. We have now fixed this issue with the use of a diode relay.
http://www.camaro5.com/forums/showth...87#post4410587
Old 02-13-2012, 10:14 PM   #12
VoodooVyper
Sorry for the later response, I haven't had a chance to install with being sick and catching up on everything.
Installed the harness today with the diode and everything works as it should.
10/11/2011 (1102)
10/11/2011 (1100)
10/18/2011 (2000)
10/18/2011 (2500)
11/01/2011 (3400)
11/08/2011 (3800)
11/09/2011 (4B00)
11/14/2011 (4200)
11/18/2011 (4800)
11/21/2011 (5000)
Old 04-17-2014, 07:07 AM   #13
cntryman77
cntryman77's Avatar
Drives: 2010 Camaro LS
glad I found this...I have a 2010 & I built my own harness...everything works fine most of the time....except on occasion I get this lights go out/come back on & relay buzz...I'll have to switch to a diode relay & see if it fixes the issue...I just happen to have one at home...I'm assuming it's something to do with the power from the side marker that works as a sensor wire for the relay as stated in the first post
cntryman77 is offline   Reply With Quote
Looking for a DRL Harness 2011 Camaro RS LT CAMARO DOLL Guides, Manuals, Bulletins, Documentation Archive 1 06-10-2011 12:32 PM
Fifth Major Mod - Fieldgoal 'Halo DRL Harness 2' "MY THOUGHTS" Forza Cosmetics and Lighting Modification Discussions 16 05-13-2011 12:52 AM
FS: Fieldgoal00's wireless DRL harness with LED status indicator FrankN Interior Parts & Accessories 2 11-11-2010 08:36 PM
Now Taking orders for Second shipment of Wireless DRL units for RS equipped vehicles fieldgoal00 Exterior Parts & Accessories 71 04-15-2010 06:42 PM
P0300 Misfire Code Help black-knight 4th Generation Camaros 4 02-08-2010 02:45 PM
